To fit to a Ph1 Xsara VTS.
| Author | Subject: Lucas Front brake calipers |
Carl GTI
Junior User Location: Tripoding at Brands Hatch Registered: 11 Aug 2015 Posts: 85 Status: Offline |
Does anyone have a pair of Lucas 57 brake calipers for sale? Obviously must be in good condition and in full working order.To fit to a Ph1 Xsara VTS. |
Carl GTI
Anyone? |
bigcw
Newbie Location: Buckinghamshire Registered: 25 Sep 2019 Posts: 34 Status: Offline |
Excuse my lack of knowledge.... I have ph1 GTi6 calipers for sale. Is that what you are looking for? |
eiei0
Regular Location: Kildare Registered: 08 May 2020 Posts: 193 Status: Offline |
Think he is after ph2/3 Calipers at least mine have 47 on them,Doesn't the ph1 have a slightly smaller diameter discs and possibly different calipers |
Joep
Senior User Location: Urmond (The Netherlands) Registered: 19 Sep 2013 Posts: 501 Status: Offline |
All phases of the GTI6 and Rallye had the same brakes if I recall correctly.________________________________________ My car park:'96 Sigma Blue XSi6 '98 Diablo Red GTi6 '99 Onyx Black S16 All RFS powered! Plus various other Peugeots |
eiei0
I was told that Lasers that came on the s16 won't fit a GTI 6 so I assume there is a difference, |
S8-Tom
Regular Location: Chichester Registered: 02 Feb 2018 Posts: 356 Status: Offline |
Pretty sure the UK S16 had smaller disc & calipers.There's a pair of 57mm calipers on Gumtree at the moment. ________________________________________ 1343Z4 coolant hose o-rings for sale198131 injector o-rings for sale |
Carl GTI
I believe only the GTI-6 and the PH1 VTS share these calipers, Lucas 57mm. I'll check the Gumtree ad, cheers |
bigcw
Still not sure if what I have is what you want! But if they are, £80 the pair, collect from just outside Aylesbury, Bucks. |
Carl GTI
Sourced some now, thanks all |
ad
Regular Location: High Wycombe Registered: 15 Aug 2004 Posts: 284 Status: Offline |
eiei0 wrote: I was told that Lasers that came on the s16 won't fit a GTI 6 so I assume there is a difference, The S16 laser wheels will fit over Gti6 brakes as I had one with that set up on. S16 brakes as standard are 266mm, the same as hdi' and xsi's I think. Phase 1, 2 and 3 Gti6's all have the same brake set up with 283mm disc's. I'm sure there is a Lucas caliper and Bosch one for the Gti but not 100% sure. |
