Author Subject: radiator hoses for heater matrix
jwilshere6
Hi, i've got a coolant leak that looks to be around the heater matrix hoses, does anybody know the part number for these? thanks
Posted 18th Nov 2022 at 03:16
alcon
6464LH
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 17th Nov 2022 at 09:09
Not been available in a long time and specific to a git6/wallye/vts, there are 2 o-rings where its located into the heater mstrix, that appears to be cracked though
Posted 17th Nov 2022 at 12:35
S8-Tom
The plastic part is the same on all 306's (+ Xsara, early Berlingo/Partner) but the rubber hoses are specific to the GTI-6/VTS as Welshpug! says.
I got the plastic part from a donor car, cut the rubber in a suitable place and joined to the GTI-6 hoses with a 20mm pipe joiner and some clips. It's all hidden behind the heatshield so never seen.
Alternatively, remove all of the rubber from the donor plastic bit to expose a barbed end and join to the silicone hoses available from Baker BM
Posted 17th Nov 2022 at 15:51
jwilshere6
i was going to try this also, just wasn't sure if the plastic part is the same on all cars as i went to a wrecker to check a convertible which looks like this:
the plastic bit has an extra little hose for the bleeder valve which i'm not too sure about.
pug_306
Yes that's fine, that's just a difference in bleed screws for earlier and later models
1992 205 GTi6
205 Turbo 340bhp
Posted 18th Nov 2022 at 10:13
