Author Subject: Cooling fan OEM brands?
iplay
I have a Gti6 P3 with aircon.
It needs a new cooling fan.
I think it is OEM part 1253J2
What is the best replacement for the entire fan and shroud?
Nissens?
NRF?
Any others?
Posted 13th Feb 2023 at 21:48
ecia or gate was the brand marked on them from memory, ecia was a psa subsidiary, motor is different between them.
Posted 14th Feb 2023 at 11:28
Autodoc have the nrf complete item at £118 today for the ecia variant
Posted 14th Feb 2023 at 11:30
iplay
once again thank you so much for you help.
do you have a link for your £118 one?
Posted 15th Feb 2023 at 21:53
https://www.autodoc.co.uk/nrf/2389404
Posted 16th Feb 2023 at 13:14
iplay
I realise now that the ECiA motors are generally higher 310w vs Gate 200w.
I think the 310w versions are for hot countries?
My reg brings up the 200w Gate version.
Would a 310w rated front fan run the engine too cool in the UK.
or is it better to have a higher rated fan?
Posted 16th Feb 2023 at 17:58
fans wont run it too cool, that's the thermostats job, it'll just cool faster.
interesting you found it listed as 200w, the parts data doesnt list a power for the ECIA variant, nor is there any specific data to notify which type is fitted where.
Posted 16th Feb 2023 at 19:42
iplay
Some where in the forum at 'euro gti6' owner discussed the difference between 300w and 200w fans. Apparently the 300w version was for hot countries. And Auto doc lists the NRF for my reg with 200w Gate.
Posted 17th Feb 2023 at 16:38
woody.
FYI, I've just fitted the NRF fan and shroud from autodoc and as expected it isn't a direct replacement. When you swap the wiring over to the new one it just about reaches but the connectors on the new fans don't quite fit like original. I haven't fired it up yet but hopefully it all works
Edit: seems to be working fine!
Posted 26th Mar 2023 at 18:42
woody.
Edit again: fans seem to have lasted 2 years. The motors are spinning but the fans are not! So I think where the plastic fan blade fits on the motor shaft and should be keyed to it, this must have rounded so need remove the plastic fan and have a look.
Bit annoying as the OE ones lasted 23 years compared to 2 years for the NRF ones
Posted 25th Jun 2025 at 18:15
