Author Subject: Quaife diff removal
99rallye
Hi all, looking for some advice.
Can a Quaife diff be removed from a gearbox and run like it did before the diff was fitted? Or does something need replacing to let it run without the diff?
Posted 19th Feb 2023 at 09:11
you need a standard Peugeot BE large planet gear diff.
not sure why anyone would take a quaife out, unless it was to put a plate LSD in...
Posted 19th Feb 2023 at 10:17
99rallye
Thanks for the advice.
I've got a donor car with a diff in it and I was figuring out if I could just remove the Quaife before I got my Rallye box out.
What it sounds like I need to do is get both boxes out and do them at the same time. Quaife into Rallye and planet gear diff into donor car.
Posted 19th Feb 2023 at 10:23
Easier to just swap the box, saves buying diff bolts
Posted 19th Feb 2023 at 23:33
99rallye
Ok, that makes sense.
I don't think the donor gears are as good as mine, having driven it. If I want to keep my gears I presume I'll have to remove the diff?
Posted 20th Feb 2023 at 06:12
99rallye
What's the name of the bolt set that I'd need if I do need to replace the bolts?
Posted 20th Feb 2023 at 06:36
Diff/Crownwheel bolts.
Posted 20th Feb 2023 at 13:05
