Author Subject: 87mm head gasket
167hp
Hi can I use this on standard 86mm engine bore? Cometic state 0.030 to 0.060 max.. question if I'm wrong.. That would be bout 0.040? What issues would there be? Compression loss? Enough to notice? Damage to engine eventually? Thanks.
C. Hughes
Posted 9th Jul 2024 at 00:41
.040 what exactly?!
Whats the compression height/ clearance to deck from the top of your piston?
I have a standard oem gasket on 87mm bore.
Posted 9th Jul 2024 at 10:53
167hp
Hi the head itself has been skimmed and The measurement is 136.50 I spoke to Matt from pug1 and he said that with a measurement of 136.50 I would need Headgasket 1.55mm for compression and 1.65mm for standard height. I've had to have it skimmed again because I dropped the head causing slight damage to the face. It's now got measurement of 136.48.. So I'm assuming that would be 1.57mm for compression and 1.67mm for standard. I purchase a head gasket with measurement of 1.6mm and the bore was 87mm not 86.5mm. I know that the 0.5 is for the gasket to sit back slightly around the bore so it's not flush with cylinder wall cometic recommend 0.030 min 0.060 max for the Headgasket bore to sit back off the cylinder wall. The extra 1mm with the head gasket being 87mm is within cometic recommended measurement meaning that 1mm is 0.040. Unless I'm speaking nonsense? I'm not an engine builder I'm just rebuilding my head. Welshpug..?? Thanks for your reply much appreciated.
C. Hughes
Posted 9th Jul 2024 at 18:16
167hp
I basically purchased the wrong size gasket.. Just need to know if it was OK to use as its been a couple of months and carnt change it. Thanks.
C. Hughes
Posted 9th Jul 2024 at 22:51
Probably be fine, from memory the oem gasket is 86.5mm, I'm using one on an 87mm bore+
Worst case you could sell your 87mm gasket
Posted 10th Jul 2024 at 09:39
167hp
SOLD!! for half the price I paid for it. Welshpug..? Thanks again for your reply. 👍
C. Hughes
Posted 4th Aug 2024 at 03:33
