Author Subject: Fuel feed pipe
sd@npl.co.uk
Hi
I need to find a replacement fuel feed pipe (Part No. is 1573 JN). Any advice on where I might get hold of one (or what to do if I can't).
Cheers.
SD
Posted 2nd Oct 2024 at 17:44
alcon
These are hard plastic lines, shaped to fit the underside of the car. I'm not sure if they're still available from the main dealer but unlikely. I think your best bet would be to contact someone on one of the FB groups who break 306's and see if you can get one from them.
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 3rd Oct 2024 at 11:35
sd@npl.co.uk
Thanks, that's helpful.
Local garage couldn't find anything and commented that anything from a breakers would be old and therefore likely to be brittle and so potentially problematic to fit.
Are there any other solutions? Flexible hose?
Cheers.
SD
Posted 4th Oct 2024 at 17:15
never seen the oem plastic lines have any issues, its always the short rubber sections.
flexible hose wont fit in the original clips, best bet is to get an used one and fit it yourself.
have you actually tried a decent peugeot parts guy for the part? its only £90 odd.
https://peugeotcitroendsparts.com/search.php?search_query=1573JN try these guys, they must have sold one not too long ago as it comes up on their website.
Posted 5th Oct 2024 at 09:59
i've just taken a load from a gti6 I broke,..
is it this pipe in the picture?
if so i'll see if i have one!
Posted 5th Oct 2024 at 20:25
alcon
I think he's after one of the long ones that runs from the fuel filter to the engine bay (1573.JN)
1999 Rallye (black)
Posted 6th Oct 2024 at 18:01
alcon
Local garage commented that anything from a breakers would be old and therefore likely to be brittle and so potentially problematic to fit.
Cheers.
They don't really become brittle to be honest. I took mine off a couple of years ago and once cleaned they looked brand new and certainly got re-used. Perhaps the lack of direct sunlight/heat means they stay in good condition.
I would certainly try to source a second hand one from someone breaking a 306.
1999 Rallye (black)
Posted 6th Oct 2024 at 18:12
I saved everything so I probably do still have it,..
Posted 6th Oct 2024 at 21:56
sd@npl.co.uk
Thanks for the help.
gnrlee, if you do have the pipe let me know.
Otherwise will try online (wleshpug - thanks for the link).
SD
Posted 12th Oct 2024 at 15:22
