Author Subject: oil pressure switch? unplugged? what plug goes to it?
jimmyhackers
as per title?
i noticed i had one today with the inlet manifold off, and it didnt have a plug going to it.
should i worry?
Posted 19th Jun 2025 at 20:59
167hp
I think they only run at half a bar of oil pressure, there should be a plug there.. If you've got a oil pressure gauge then it shouldn't matter but don't quote me on it. Welshpug will have more info about it.
C. Hughes
Posted 21st Jun 2025 at 16:22
Where abouts on the engine was it?
There should be one just above where the heat exchanger sits, I believe thats for the low pressure light and it should have a plug from the loom on it.
Off to the right of this (just left of where the small breather pipe goes into the block) theres a port which i've found on some previous engines has had a sensor in it's place to seal it but no connector should go to this one.
Posted 23rd Jun 2025 at 19:29
jimmyhackers
right next to the oil breather t peice underneath the inlet manifold. i think where/what you are describing with the small breahter pipe into the block.
grey 2 pin plug (i think, was very dirty) went and had a google, found the ubiquitous picture of the colour coded engine block sensors
https://www.205gtidrivers.com/forums/topic/99387-gti6-xu10j4rs-sensor-identification/
red - oil pressure warning switch.
Posted 24th Jun 2025 at 21:55
marksorrento205
Some use two sensors, one is just a blank.
Both the red and the pink (205 drivers link) are oil pressure and can be used.
Posted 25th Jun 2025 at 17:34
