ive done a bit more investigating....and tinkering, with some reasonable findings.
ended up using a go pro to record the fuel pressure tester in engine bay while driving to test under load conditions...
my initial testings were mostly correct except
i was being a fanny and not opening the throttle enough on driveway as it would bounce of limiter too quickly, it sits at a wobbly 2.9-3bar at WOT while driving or bouncing off the limiter stationary.
it would sit at a wobbly 2.4-2.6 bar at idle
i made a vacuum pulse restrictor orifice by drilling a 0.8mmx5mm hole in a piece of brass and heat pressing it into a 4mm plastic barbed pipe fitting. fitted it to the fuel pressure regulators vac line.
similar things are used to stop boost/vac gauge needle fluctuations
wobbly fluctuations in fuel pressure are gone. but it still switches between low and high pressures as quickly as without
pretty sure this is a good thing?
thoughts?
