Author Subject: Brake Caliper Rebuild FAQ
petegti6
Right then, finally got around to it Big grin
Please note, i did this on a spare set of calipers, there was no "downtime" for my car this way and i could use the proper stuff at work Smile
Lets go:
1. Remove the brake calipers from the car, clamping the flexi pipes would be an idea!
2. Clean the calipers and carriers up ready for spraying
Best i could do with a wire brush (sandblaster on the blink Roll eyes)
3. Remove the piston, you could do this another way, but i advise using an air line through the line fitting to force the piston out, put a bit of rag in front of it and expect a loud "pop" when it SHOOTS out Shock
Pistons removed: Smile
4. Clean the piston /bores and mask up for spraying......
5. Clean the slider pins up, i put them in a box of pepsi (maybe coke? Razz) and wire brushed them
6. Time to spray, i used VHT red paint with VHT laquer (laquer is essential to get the nice shine Big grin)
Pics don't really do it justice No
7. Time to fit the new main piston seal and dust seal:
Examine the piston first, any signs of bad wear? f*ck it off in the bin Yes
Small scuffs are okay so long as the coating isn't peeling as this will rip the new seal Sad
Mine were OK so i re-used them Smile
Piston and dust seal:
Location of main seal - This just lifts out, use a terminal screwdiver CAREFULLY to remove.
8. Fit the new main seal, it just drops in.
9. Fit the dust seal, it also drops in.
10. Cover the piston and bore in brake fluid (aids fitment)
11. Fit the piston, you'll need to manipulate the dust seal around it, don't use excessive force at first, once its in you can push it down by hand.
Its a good idea to use an airline in the pipe fitting to push the piston out and then push it back by hand to ensure the dust seal is sitting right and the piston moves in the bore smoothly Yes
Your done Thumbs up
Fit your nice shiny calipers and carriers to the car Big grin
Thankyou Please
Sorry about pic quality people, not allowed cameras at work!
Stealthly VRAZR! LOL
Cress87 wrote:
This place is getting beyond a joke. There's been an enormous influx of bellends signing up recently
Team 205 1.9 GTi ™
Team: Hmm™
Posted 21st Apr 2007 at 01:10
khj100
FAQ'd Thumbs up
Posted 21st Apr 2007 at 01:14
I know this is a really old thread but having rebuilt a few sets of these now and remembered each time the main dust seal is a pain to fit, and trying to see how others get around it.
Couple of people over on 205gtidrivers forums asking how to do it as they kept splitting the seals trying to do it the normal way, and the fact is the seal is too hard to grip and pull up whilst trying to manoeuvre it over the piston.
I find to do it the following way will save you a lot of hassle, and it's to lay the piston on it's side so that it isn't naturally pressing onto the dust seal as you do it.
You'll find it a bit easier to coat the bore of the caliper and the piston in brake fluid to help it slide around.
Step 1 - fit the seal like the below
Step 2 - slot piston and seal into the dust seal groove
Step 3 - Turn caliper upwards and gently ease piston into the caliper. You will feel it grip the dust boot and it will naturally hold it in place.
Step 4 - grab the edge of the dust boot with a seal pick etc being careful not to rip it, and pop it into the groove
Step 5 - I found it easier to rotate the piston around in circles to get the seal in place on all sides
Job jobbed Smile
Some people get lucky and fit them perfectly without issue, but sometimes aftermarket seals vary slightly and are a proper pain to apply. I found the above turns a 30 minute hassle of fighting the seal and trying to pull it around the pistom whilst it's upright, into a 10 second job.
Posted 26th Oct 2021 at 06:07
This thread has been locked
