displaying posts 26 to 50 of 58
Pages (3): 1 [2] 3
Author Subject: xsara vts gear ratio's needed
pugheaven
Spoox
I'm trying to use a formula from Google and a gear ratio calculator but maths and Excel is not my strong point
Posted 6th Sep 2016 at 18:28
oh, they don't make anything themselves?
Posted 6th Sep 2016 at 18:44
the gear speeds they've given you are early xsara 4.42 fd with gti6 3-4-5.
Posted 6th Sep 2016 at 18:48
pugheaven
From what I can work out using spoox top speed using a 7500 limit on 195 50 the ratios are 2.9 1.83 1.40 1.15 0.95 so using a 3.6 final drive on 195 50 tyres and limit of 7500 will give top speed of 1st 48 2nd 76 3rd 100 4th 122 5th 147????
So using 225 40 18 using there gear set and a 3.6 FD and limit of 8250 I would get
1st 60 mph
2nd 96
3rd 125
4th 153
5th 185
Surely that's not right???
not what you want with your torque!
Posted 6th Sep 2016 at 18:50
pugheaven
It's the helical gear set they had manufactured for there time attack car which appears to be coping with the 500 odd hp he is running.
I'm just trying to work out if I use that gear set with a 1.9 3.6fd what top speed of would get and what the rpm drop would be into each gear
Posted 6th Sep 2016 at 18:56
205 has a 3.69 not 3.6, so with gti6 3-4-5 on that with your big tyres gives.
57 90 118 145 176
Posted 6th Sep 2016 at 18:53
if you shift at 8250 you drop to 5227 6288 6729 6815
Posted 6th Sep 2016 at 18:54
pugheaven
That sounds alright to me.
Do you think that's a good set up for my bhp/torque.
Posted 6th Sep 2016 at 19:01
pugheaven
Post #35
Is that because of the gear set or ratio's?
Thanks for your help bud
Posted 6th Sep 2016 at 19:02
Post #36
sounded like a gti6 3-4th which is what they have used in rally cars for a while, I know one guy that blew his to bits with a bodied gti6 in a 205 rally car.
but if its a different tooth count and tooth profile then hopefully they have addressed the weakness.
Posted 6th Sep 2016 at 19:04
pugheaven
Post #37
Na it's not a standard gear set!
We are coming to a deal etc as I'm not going through the whole KAD straight cut s**t again
He has even offered to lend me his box to prove he has no issues....
Pretty decent bloke by the sounds of it
Posted 6th Sep 2016 at 19:08
fatlapit
Post #38
Ill let u know how the spoox box gets on soon
Posted 6th Sep 2016 at 19:49
Post #39
just make sure you research what they're trying to sell you, a lot of the stuff they have is dealer sourced with an obscene markup, though looks like they have commissioned someone to make some gears up for them.
did anyone ever use those dog gears that were made?
Posted 6th Sep 2016 at 19:52
fatlapit
Post #40
Ive gone for a 3.9 fd at 7200 on 17s gives 142 terminal
Posted 6th Sep 2016 at 19:55
fatlapit
Post #41
In their defense spoox are the onlyones ive spoke to that have given me measurements to carrt out once its all fotted. They also provide the only solution that is proven to work on higher powered cars
Posted 6th Sep 2016 at 19:56
pugheaven
Post #42
Yup I used the KAD dog engagement straight cut 3rd and 4th... then 2nd went lol
Lapit is that a custom final drive?
How much is the gear set costing you?
Posted 6th Sep 2016 at 20:00
fatlapit
Post #43
2494.99 fully built ready to bolt on
Ive supplied a 5 speed box and my diff
Posted 6th Sep 2016 at 20:05
fatlapit
Post #44
Exact same spec as darrens that is in his 205
pugheaven
Post #45
So is that a custom final drive
Posted 6th Sep 2016 at 20:09
fatlapit
Post #46
Yeah
Posted 6th Sep 2016 at 20:16
pugheaven
Post #47
Why when it's the final drive used in the gearbox that's fitted to the 1.8 16v 306's from what I have seen
Posted 6th Sep 2016 at 20:17
fatlapit
Post #48
I dunno bud. I didnt ask many questions. Just gave them my car spec n what i want. In 3 weeks ill find out
Posted 6th Sep 2016 at 20:23
pugheaven
Post #49
So your wiling to spend an extra 1000 on a custom final drive that isn't custom.... are you mad
Posted 6th Sep 2016 at 20:25
fatlapit
Post #50
Its new. Its all new. Well apart from the casings n diff. Hopefully its the answer i need.
Posted 6th Sep 2016 at 20:29
Pages (3): 1 [2] 3
