displaying posts 376 to 400 of 643
Pages (26): first .. 15 [16] 17 .. last
Author Subject: Project PUG
Post #376
Not really!
LOL
Posted 11th Mar 2010 at 01:50
jimmy_boy
Post #377
daveyboy wrote:
chris with a pug wrote:
Thats where I thought it went, cant remember where Jims is
Mines not fully welded in yet as I want a curved one, instead of the straight piece of tube CC sent out.
They sent you a perfectly straight dash bar?! Erm?
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Post #378
Yes, they even insulted me further by sending me a dash bar that was thinner diameter tubing than the rest of the cage with incorrectly profiled ends so it did'nt even fit! c*nts.
Posted 12th Mar 2010 at 04:43
chris with a pug
Post #379
So got up bright and early this morining and Dave came over and he had a good go at some more of the body work, it really is starting to get there now.
Forgot to take any photos.
I got on with getting the oil cooler and intercooler mounted.
Fist off I refitted the slam panel and rad.
I had to unscrew the loom under the cross member (didnt wanna drill through it LOL)
I then used the spacers supplied with the cooler and the two plates they supply, but the slots are not big enough for the bolts for the intercooler to go though, so had to file them out.
then fitted the cooler
then fitted the bumper to check clearance
the good thing with using the mounting plates supplied, is that there is so much room to move the cooler.
It can be moved 2 inches either side, or six inches backwards,
then the biggest pain in the arse job of the day, fitting the oil cooler.
What a ball ache, so much fiddling but its all fitted now
I used one of the bolts that holds the bumper on to hold the bracket for the left side of the cooler, I thought that was pretty genius
With the cut offs from those 2 fixings I made the supports for the top, they will be welded on, just need to speak to jim as to the best way to do it.
that looks pretty mean like that, but will be getting a badged carbon bonnet from NUR.
and with the rad fitted
I did a little prep work today on a bumper I brought (my idea or mint and other peoples is very different) but its getting there now
and I finsihed off by seam sealing the rear panel
Its starting to take shape now.
Posted 14th Mar 2010 at 06:54
Post #380
"Who's a busy boy then...?"
Posted 13th Mar 2010 at 23:23
chris with a pug
Post #381
LOL
I need you to take a look on the best way to weld the brackets to the slam panel. either notch it or not.
Posted 13th Mar 2010 at 23:32
mabgti
NV motors
Post #382
thought it was weird too that the FMIC had brackets that didnt even fit the bolts suppliedLOL
arent you gonna fit some fans??
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 14th Mar 2010 at 00:11
chris with a pug
Post #383
Do I need them? LOL
Na they go between the intercooler and the rad dont they?
Posted 14th Mar 2010 at 00:13
mabgti
NV motors
Post #384
thought you would've got fans mounted before fmic mounting? or ary you going for sucker fans?
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 17th Mar 2010 at 00:14
chris with a pug
Post #385
there is so much room between the rad and the cooler I cant see them being a problem
Posted 17th Mar 2010 at 01:11
chris with a pug
Post #386
I have been a bit lazy latley, not getting much done, but still have lots of parcels turning up so its still coming along.
When the new swirl pot gets here will really push on with getting the fuel system buttoned down and finished.
Talking of the fuel system had the fuel rail welded this week by Daveyboy to take the aeroquip fittings, but I forgot to take a pic. Just needs painting now.
I havent been totally lazy and did strip down my VTS stearing rack (thanks Jonnie).
Here it is in its component parts
then put the rod back in and greased it up
As I was bolting the bit that the Universal joint connects to, disaster struck and I stripped one of the threads.
But a large kebab as payment Daveyboy helicoiled it for me and sorted it.
I had forgotten to put the gator on before I put the rod in, but luckily it goes over the stud just and so its all good.
But getting the stupid metal clips that hold the gator on are a pain, but manged it after a bit of swearing
then fitted the guide thing with its shims and rubber O ring
And now in true Bluepeter style I made a bag for the ram.
I double folded a garden bin bag, and with some duck tape made a bag
here it is fitted to the ram
and here is the rack finished, bar the track rod ends and track rods
Posted 11th Apr 2010 at 23:37
mike rallye
Post #387
well i have just read this project thread from start to finish. and all i can say it is going to be a beast when it is finished. excellent work to you both and the knowledge you got to do a project like this Thumbs up .is this going to be ready for fcs?
Posted 12th Apr 2010 at 00:52
chris with a pug
Post #388
Maybe next year LOL
Posted 12th Apr 2010 at 00:56
clen666
Post #389
Nice progress chris, do you have any part no.s for the parts you replaced on the vts rack?
Team 'unintentional rat look'
Posted 12th Apr 2010 at 03:10
chris with a pug
Post #390
I havent replaced anything yet.
And the track rods and ends are the same as standard
Posted 12th Apr 2010 at 03:12
clen666
Post #391
ah right, thought you had replaced the gaiter and o-rings etc. nevermind!
Posted 12th Apr 2010 at 03:13
chris with a pug
Post #392
they all looked fine so no need to really.
The o ring only seals grease so should be fine
Posted 12th Apr 2010 at 03:16
chris with a pug
Post #393
So the sun was out and had loads of stuff to fit so cracked on with it.
this turned up this week, gave it a polish just because I am a little sad.
This is what I started with this morning
The swirl pot didnt come with the holes drilled to mount it, which is a good idea I think
So se about marking them up and getting them drilled
I then thought about how I will connect it all up to the standard pump, so decided to use the other hole that the phase 1 uses. I cut 2 peices of pipe and turned the pump round so the out let face the right way.
they are cable tied together noww, but I forgot to take a pic of that.
I then set about runnig all the braided hose.
This took ages, but I am pretty happy with it.
I then made up possibly the shortest fuel pipe ever.
I have never made aero quip hoses, but to be honest its not that bad.
The one problem I did find was cutting the hose, I tried some tin shears and they f*cked up the braid, I then tried a junior hack saw no go, then a big hack saw and nothing, bit p*ssed off I attacked it with an angle grinder and hey presto perfectly smooth cuts.
I took the fixing apart.
then loosened the braid and fitted the olive
with the trusty rubber lube to push it home
Posted 18th Apr 2010 at 01:54
mabgti
NV motors
Post #394
good stuff chris... i think you should do a kit like that, as i'd be no good sourcing parts and fitting unions.. but how much we looking at?
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 18th Apr 2010 at 02:12
chris with a pug
Post #395
well the swirl pot was 86.10 quid delivered
The pipe is 120 quid, but I need another 2m (could get away with 1m) for the engine of the smaller pipe.
the fuel filters are 13.99 and 12.99.
the weld on ends for the fuel rail are 7 quid each
its about 300 quid so far, and I need to buy the rest of the ends now I know how it will all go and what I need.
Posted 18th Apr 2010 at 02:20
chris with a pug
Post #396
Forgot the ones of the fuel rail
Posted 18th Apr 2010 at 18:06
Post #397
Looking good mate, any luck from your uncle with a welder yet?
Posted 21st Apr 2010 at 20:53
chris with a pug
Post #398
No, I not spoken to anyone. Did you find out anything?
Posted 21st Apr 2010 at 22:54
Post #399
Not yet, been a little hectic with Brian stuck in Cyprus all week, I'll look into it on Monday Smile
Posted 23rd Apr 2010 at 18:11
chris with a pug
Post #400
LOL he is so milking it LOL
Posted 23rd Apr 2010 at 18:49
