displaying posts 476 to 500 of 643
Pages (26): first .. 19 [20] 21 .. last
Author Subject: Project PUG
chris with a pug
Post #476
Its worth the effort when its done, its just getting it there.
I mean to be fair to custom cages, the original cage they sent had the wrong stays in and as soon as I told them the next day I had the right ones sent out.
Hopefully they will sort the other poblems out just as quick
Posted 26th Sep 2010 at 23:50
miles
Post #477
Have fun with those bar's, LOL
www.pugracing.com
Posted 4th Oct 2010 at 05:44
craigm
Post #478
Taken me a few hours to work my way through this thread, Amazing skills youve got mate! Mucho inspiration for my up coming project..
Whats all the extra switches on your Dash for?
Cant wait to see this done!
6 Project Coming Soon Smile
Posted 5th Oct 2010 at 00:53
chris with a pug
Post #479
The switches will be for the fog lights; front screen ; water/methanol kit; the gauges and I cant remeber what the other was for off hand
Posted 5th Oct 2010 at 02:01
chris with a pug
Post #480
So had another session on the car tonight trying to get the cage to fit.
We shortened the rear stays lower so they fit and started to fit the a pilar bsars, but they are just too over bent so Jim is going to attack them with some oxi acetiline.
I am also 1k lighter as I ordered my seats, harnesses and subframes.
SO am rather happy tonight.
Posted 7th Oct 2010 at 02:45
Post #481
Better off putting a porta-power on 'em if you've got one, you don't want to soften 'em too much with the heat.
Posted 7th Oct 2010 at 03:30
chris with a pug
Post #482
we dont have one of those. With Jims frame he might be able to swing off it.
Posted 7th Oct 2010 at 03:33
Post #483
LOL
I'd lend you one but southhampton's a bit of a trip, farming method then - block of wood and a scissor jack...
Posted 7th Oct 2010 at 03:40
chris with a pug
Post #484
Well yesterday we got a good way along with the cage. The A pillars, main hoop and screen bar are all together and fully welded so I now have a half cage together, but its not welded to the floor yet as we still need to move it to put all the rest in.
Now custom cages sent me some new rear stays that they made off of a shell they have there, but they where about a foot too long, so I have said to them just send me 2x 1.3M of tube and we will profile it to fit.
Safety first
Now we dont have a fancy tool to spread the cage so we made one (thanks to Phillip M for the tip).
Here it is in action, we tacked it to the cage so it didnt ping out and smack Jim in the face.
So hopefully this will now come togethe quickly but we shall see.
Posted 17th Oct 2010 at 17:56
Post #485
Thumbs up
Are you chopping holes in the floor to weld the top then, or have you dropped the a-pillars and screen bar back before putting the main hoop in?
Posted 17th Oct 2010 at 18:31
chris with a pug
Post #486
We already welded the plates in so we tacked it all in place, then fitted the screen bar welded along the bottom then we broke the tacks and lent it forward. I deffo think thats the best way to do it even if Custom dont do it that way
Posted 17th Oct 2010 at 22:59
Post #487
We usually tack the plates in, shape the feet and get the a-pillars/main hoop/door bars and the screen bar all tacked in in the right place, then weld 2/3 of the screen bar, grind all the tacks back off the rest and lay the a-pillars down to weld the top, easiest way when the windscreen is still in.
Then take the feet out and drop the main cage onto the floor once you've welded the door bars and main hoop to the a-pillar bars so you can do the top. Saves having to chop holes in the floor.
Posted 17th Oct 2010 at 23:13
chris with a pug
Post #488
We just ratchet strapped the legs of the hoop together and it comes off the hoop feet
Posted 18th Oct 2010 at 00:05
Post #489
Yes
Posted 18th Oct 2010 at 00:06
chris with a pug
Post #490
Well Just got a call from Custom, I have 2x 1.3M of tube on its way and hopefully the missing gussets so this will be everything to finish.
Posted 18th Oct 2010 at 21:59
Post #491
Yipee! More welding...
Posted 19th Oct 2010 at 04:05
chris with a pug
Post #492
God u have turned into a miserable man!! LOL
Posted 19th Oct 2010 at 04:07
ashtal
Post #493
Will keep an eye on this thread. Just fitting a rollcentre cage to my 6.
Posted 29th Oct 2010 at 21:54
chris with a pug
Post #494
So last weekend I decided to to a bit of tidying up on puggy.
First job was to put a bit of primeron top of the cage where it is touching the room as it will be hard to get paint in there when its all finished.
First off I gave the cage a good going over with my wire brush on my grinder then a quick rub down with some 80grit and a quick spray up.
I did some seam sealing where I welded up where the seat supports where removed (forgot pics of this), but it took so long to sort that but with a few coats of primer looks good.
Getting the cage back up on its supports at the rear is a bit of a pain as its so tight in places, but after jacking it up with our cage spreader it went back up.
Hopefully more cage fitting this weekend but we shall see.
My Chistmas holiday starts on Dec 5th so my plan is to have the cage in by then so I can paint the inside and refit everything so the inside is completed by Jan but you know how these things work!!
Posted 30th Oct 2010 at 00:48
ashtal
Post #495
Is the cage up on its feet in the second pic?
Posted 30th Oct 2010 at 01:24
chris with a pug
Post #496
yeah
Posted 30th Oct 2010 at 01:27
ashtal
Post #497
Do you have tagging plates as its not very tight to the body?
Posted 30th Oct 2010 at 01:41
chris with a pug
Post #498
yeah there are gussets. and it is very tight to the body in places.
Posted 30th Oct 2010 at 01:53
Post #499
Kev's main hoop was that low too, ended up welding another plate on the rear feet to get it sat up a bit closer to the roof.
Whereas Rikky's went in nicely with a helping hand from a rawhide mallet, touching all around....
Not sure why there's a kink in the a-pillars above the doors though! Blink
Posted 30th Oct 2010 at 06:27
ashtal
Post #500
Were has everyone got the screen bar fitted. Mine is completly diffrent to the cage pictured!
Posted 30th Oct 2010 at 17:02
