displaying posts 126 to 150 of 643
Pages (26): first .. 5 [6] 7 .. last
Author Subject: Project PUG
chris with a pug
Post #126
So as the swirl pots are going to be here soon, I had a think about how to pipe it all as pug use push fits and they do leak sometimes so here is my solution to it, I am going to repipe the whole car.
here is my diagram with dimensions of pipe
The way I got round going from 8 mm to the 10mm on the walbo (not 100 percent sure the walbro have 10mm ends, but ordered one today so will check when it arrives, or if someone can tell me) is to buy an after market fuel filter, you can have them with different sized ends from tweeks to take it up to ten mil, my only probelm with that is that the filter now behind the pump, is that ok to suck not push it through the filter?
to go from the 6mm on the pump to 8mm on the swirl pot I am going to get some brass reducers made up like so
I am sorry I only have paint and I cant draw.
If i cant have the filter behind the pump, ill get a 10mm both end filter and another reducer going from 10mm to 8mm to sort it.
I am looking at ordering 5m of 10mm braided pipe, 5m of 8mm pipe and 2m of 6mm pipe. thats more than enough but no point running out, if anyone else likes the look of this let me know and I can order more stuff, still waiting for a price on the pipe
Posted 30th Sep 2008 at 23:04
chris with a pug
Post #127
Right braided fuel lines for the car out of the question, just got a quote for about 450 quid, so going to go for over braided in cotton, also the adaptors I can buy off the shelf so will be a bit cheaper
Posted 3rd Oct 2008 at 01:34
midlife
Post #128
That sounds very expensiveDunno
Try these
http://cgi.ebay.co.uk/Braided-Fuel-Hose-RACE-RALLY-Aeroquip-goodridge-earls_W0QQitemZ290263996255QQihZ019QQcategoryZ72205QQtcZphotoQQcmdZViewItem
Cool
Team 330™Cool
Team "no front end or engine"
Posted 4th Oct 2008 at 20:58
Post #129
thanks
The stuff I tried to get for chris is the top spec stuff from pirtec and not resally needed for this application.
Posted 4th Oct 2008 at 22:29
chris with a pug
Post #130
Got my fuel pump on friday, I only bloody ordered it tuesday afternoon so am well chuffed with the service from Import blowouts.
Came in at $115 for the pump, with is about
Posted 5th Oct 2008 at 18:37
chris with a pug
Post #131
So as it was a nice day, decided to spend a bit of time out in the garage doing some work.
So first off, as I picked up my swirl pot yesterday, drilled the holes to mount this, didnt mount is as still need to get the pipe etc.
Am going to run the Walbro pump off a relay, have started another thread in electrical, can someone help me out with some advice, would appreciate it.
So once finished drilling the holes turned my atentions to the oil pump.
All my new parts
then fitted the new bits in
When putting the pump together you cant rest it on a bench as the big cog pushes the little cog too far up and they are then not flush to the face, my way of getting round it is using the work bench like so
the spring is really compressed when you put the cover on and start to bolt it up, so be careful or it will spring off.
I started doing the bolts up and compressing the spring evenly
Tightened it all up and was done
So decided to strip the head ready for skimming and rebuilding
First off remove PUlleys
removed the cams
and started removing the valves
all the valves in seperate bags (didnt have time to to exshaust ones, will do them tomorrow
Am going to smooth and match all the ports myself
Posted 12th Oct 2008 at 22:56
chris with a pug
Post #132
So last couple of days did a few more bits.
Removed the rest of the valves, cleaned them all and checked they there straight and measured all the stems to check for wear, all good so Am a happy bunny.
Gave the head a good wash and now need to send it to get skimmed and tested.
Then turned my attentions to the swirl pot, fitted the pump and pulmed the feed to it in
Then drilled the holes, (did it by laying the pot in the boot, so much easier) and offered it up under the car.
Getting all the nuts and bolts on ur own s a right pain, seriously recommend getting a friend to help.
Started wiring in the relay in the bonnet to run the pump, but cant find the feed, will have another look at the weekend.
Posted 15th Oct 2008 at 22:29
Post #133
could just use the original feed to the fuel pump to trigger the relay for the second pump.
easiest place would probably be the inertia switch.
Posted 15th Oct 2008 at 22:37
chris with a pug
Post #134
I cant find the feed, I put the relay in the black box in the engine bay.
The haynes manual says its fuse 15 in that box, but there no continuity from there to the pump.
Any ideas
Posted 15th Oct 2008 at 22:40
SteviePut
Post #135
Any ideas
Ignition switch on?
Posted 15th Oct 2008 at 22:50
smighall
Smeg-all
Post #136
I'm pretty sure the power from the fuse box goes into the dual relay behind the battery box, and then out from there to the actual pump. Pin 7 springs to mind for some reason but not 100%.
Meh
Posted 15th Oct 2008 at 22:52
chris with a pug
Post #137
No there no battery init, I did a continuity test, will that still come back open with no ignitiion
Posted 15th Oct 2008 at 22:53
SteviePut
Post #138
I'm guessing as i've not looked at it, but the ignition turns on the pump does it not?
But saying that if there's no power to switch the relay then you'd still have no continuity. I think that's what Sean is getting at
Posted 15th Oct 2008 at 22:56
smighall
Smeg-all
Post #139
That's what i'm saying there won't be any continuity if i'm right, as the relay won't have switched as you currently have no power. if you check continuity between the pins on the double relay and pump you'll find it.
Meh
chris with a pug
Post #140
Its not like that on the diagram, but will check saturday
chris with a pug
Post #141
Ok, I think I get this now.
Checked throught the FAQ and that relay is not on the car at the moment as its part of the engine loom which is sat in my garage.
Might have to wait til further into the build to wire this in
Posted 15th Oct 2008 at 23:38
Post #142
Is that right Chris? LOL
Posted 16th Oct 2008 at 03:44
chris with a pug
Post #143
Yeah, well supervise you doing it
Posted 16th Oct 2008 at 20:47
Post #144
The die grinder hasn't arrived yet so you may end up doing it all by hand! (not for the first time!LOL )
Posted 17th Oct 2008 at 03:04
chris with a pug
Post #145
you will you mean
Posted 17th Oct 2008 at 03:18
puglover Banned!
Post #146
id be careful porting your own head chris, very easy to f*ck it up if you dont know what your doing. I wouldn't bother tbh. Polishing it might help but the turbulance created in the air as it enters the rough ports in the head will create a better burn anyway. You'd be better off just having 3 angle valve seats cut. Helps let more air in on opening and helps to cool the valve when shut.
Posted 17th Oct 2008 at 03:25
chris with a pug
Post #147
We arnt going to go mad, but there is lots of casting marks in there, will be better all smooth
Posted 17th Oct 2008 at 03:34
Post #148
Not too smooth, keep it at 40 grit or lower.
Posted 17th Oct 2008 at 03:35
chris with a pug
Post #149
Is that the texture of what it should look like when its finished or what to use to smooth it?
Posted 17th Oct 2008 at 03:55
chris with a pug
Post #150
So another weekend and a bit more work done.
First off fitted the relay and all wired in.
In the end took the feed off of the blue wire off of fuse 09. Checked it on another car and it looks like its the right one.
Secondly got some central heating flushing solution and the head is now being soaked in it to deschale it all etc, been in a day now, will get it out tomorrow probably.
Also refitted the Throttle cable and clutch cable. So much easier with the engine out, but throttle a pain getting it through the double skinned bulk head, but all done.
Also took the throttle body apart and thinned out the spindle, probably not needed but easy to do and cant do any harm. will post some pics later.
Posted 19th Oct 2008 at 14:59
