Author Subject: Air con removal!
birk
ive done a search, but couldnt realy find anything to help!
I want to take my aircon out system out to save a bit of weight, and it doesnt work either, plus its going to need to come out for my SC anyway!
the bits i think i need to take out, with out going nuts and spending more than well... erm not alot are...
The Compressor, Condenser, Filter/dryer/receiver and all the pipes i guess!
i have a ph1 gti6 on my drive i will be stripping, can i use the set up from that, just take it off and simply put it on my ph2/3 6, if so, what do i do!
Dan
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 11th Jan 2008 at 20:03
fletch
Track Head
Fairly straight forward but youll need to get hold of the Rallye aux belt setup.
Posted 11th Jan 2008 at 22:03
smighall
Smeg-all
Have fun with the pipes Dry
Meh
Posted 11th Jan 2008 at 22:06
birk
should have said! the gti6 i have that im stripping doesnt have aircon on it! would i be able to use the setup from that, or is it diff to a rallye one?
07889376885
Dan
Posted 11th Jan 2008 at 22:19
chris with a pug
I did mine with the engine out and was a doddle, just cut all the pipes the only proplem I had was that it rusted along the cross member
Posted 11th Jan 2008 at 22:23
306matt
Birk: Did you simply just remove the air con pump and fit a Rallye Aux belt?
Matt
Team Astor Front Mounted... Hybrid turbo on it's way.
Posted 25th Apr 2010 at 20:20
lotek
you have to remove the compressor, and auto tensioner, and fit a manual tensioner ,roller and belt from any xu engine without aircon doesent have to be a rallye .
i got my setup fron a 2.0 406 Yes
Posted 25th Apr 2010 at 20:27
306matt
This is on a Hdi, thanks anyhow..
I just need to source a belt from a Non- Air con Hdi,
Matt
Posted 25th Apr 2010 at 21:09
smegal
306matt wrote:
This on a Hdi, thanks anyhow..
I just need to source a belt from a Non0- Air con Hdi,
Matt
You also need the tensioner set up.
Ex SC-6
Now in a Megane R26
Posted 25th Apr 2010 at 20:54
