displaying posts 26 to 50 of 54
Pages (3): 1 [2] 3
Author Subject: Possible Brembo squeel cure
lotek
lmao
only 1 squeeled.
i will be joining club squeek again soon once i get this bloody beam and bumper sorted.
lemmy know how you get on adam. Thumbs up
Posted 12th Dec 2009 at 20:51
Was that the one with the copper grease on it - I did find that amusing, only one having loads of grease on it LOL
The slider kit is
Posted 12th Dec 2009 at 23:01
do the pads hang over the outside of the discs on these brembos when used with a 283mm C5 disc?
edit, was looking at wrong discs, I guess its the 28mm disc that's used so only 3.5mm less pad sweep radius.
Posted 12th Dec 2009 at 23:48
Well f*ck me. I seem to have a couple of stuck pigs on the front of the car. Quite an incredible amount of noise LOL
Plus side - although you can feel the extra track and weight it is shit loads quicker without the brake binding and they work very well indeed.
So far everything is greased with mintex brake grease using standard chamfered pads and standard discs. Next up i'm going to try some multiple grooved discs (Tarox G88) when I get the money sorted out.
Posted 15th Dec 2009 at 01:56
scib4
I used Mintex Ceratec on my Carbotech Xp8's which worked a treat.....plus its only
Mike
08 BMW 320d M-Sport touring (Superchipped Spec)
11 VW Transporter Kombi T5.1GP LWB (Bi-Turbo spec)
Yeti DJ (Jump spec)
Specialized SX Trail (DH spec)
Specialized Pitch (XC spec)
Posted 15th Dec 2009 at 02:20
rallyestyle
Will be interesting to see how you get on, perhaps investing in some ear plugs would be better LOL
Just Drive It
Posted 15th Dec 2009 at 02:34
mechanical_repairs
I don't know how you live with the squeel, a customer of mine had a set and the noise is unreal.
Makes you a better driver as you don't want to press the brakes!
Carl
Posted 15th Dec 2009 at 03:14
that's two people I know with Brembos, both squeal loud enough that I can hear it in my car when they're a fair way in front! Laugh my ass off
Posted 15th Dec 2009 at 04:22
Carl
Yes it is quite incredible. I found you can brake to about 30% with no noise, just after that it gets louder and louder awfully quickly.
I think i've already got that Mintex stuff on everything - can you remember what it was Meirion?
Posted 15th Dec 2009 at 12:49
rallyestyle
Post #35
Carl
Sounds like my AP's Laugh Just doesnt like very light braking, slam the anchors on and you wont get a peep out of them No
Just Drive It
Posted 15th Dec 2009 at 14:07
Post #36
hmm, I can't remember if it was the Ceratech stuff or just normal Mintex non-copper based brake grease, remainder of the packet is still in the unit I think, or might be in my toolbox!
Posted 15th Dec 2009 at 15:09
cosmic spanner
Moral objector
Post #37
Blink crikey this thread is a blast from the past!
ISTR mine only squealed on light pedal applications.. if you braked firmly then they were fine. Unfortunately the effect that has on your driving is you want to leave braking til late and brake hard.. which isn't a very good idea!
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 15th Dec 2009 at 15:43
rallyestyle
Post #38
Exactly like mine Yes Oddly it's fine for the first few minutes while all parts are very cold Crazy Any idea on why this may be?
Just Drive It
Posted 15th Dec 2009 at 15:56
ash
Six Addict
Post #39
I could get some alloy bells made to take 288mm Rotors, but the bells will be about
Posted 15th Dec 2009 at 15:57
Post #40
bells would be a good idea, as you could address some clearance issues by moving the caliper and bell inwards a bit away from the wheel (i.e taller offset)
Posted 15th Dec 2009 at 16:38
rallyestyle
Post #41
Wouldnt the caliper position be fixed as it is lug mounted? I guess you could space it out a bit and use some longer bolts Unsure
It all adds to the cost though i guess, if your looking to spend 400 on some bells and discs plus around 150 on the calipers and then 50ish on various other bits then you might be better off looking at the Renault calipers and the kit Ash does for them Yes
Just Drive It
Posted 15th Dec 2009 at 17:10
Post #42
yup, exactly what I meant.
depends how cheaply you can get the calipers, Renault ones aren't that common yet, I can;t see why the rest of the kit would cost any more.
Posted 15th Dec 2009 at 17:14
Post #43
I remember them sqealing on a certain stretch of Sussex road in 2007. That looked like pretty hard breaking too. Whistle
Posted 15th Dec 2009 at 17:17
cosmic spanner
Moral objector
Post #44
That noise wasn't the brakes, it was the tyres. And the airbags. Razz
Posted 15th Dec 2009 at 19:05
Post #45
But that doesn't fit under 15" wheels though iirc. Wonder if the massive number of grooves on the Tarox discs make all the difference.
Posted 16th Dec 2009 at 17:11
rallyestyle
Post #46
I doubt it no as 310mm is probably a tad big, i have been proved wrong before though Yes
The grooves will make a difference yes but not a huge one i wouldnt have thought No
Just Drive It
Posted 16th Dec 2009 at 17:55
Post #47
well pads and discs are the only variable between adam's car and DanS16's car!
Posted 16th Dec 2009 at 17:57
rallyestyle
Post #48
Does he get no squeal whatsoever then? What pads does he run?
Just Drive It
Posted 16th Dec 2009 at 17:59
Post #49
apparently not, you'd have to ask Dan I dont know what pads but I think its the Tarox G88 grooved discs, Adam said you ger a whirring noise when you brake instead of a squeal LOL
Posted 16th Dec 2009 at 18:02
Post #50
He uses DS2500 pads and the Tarox G88 discs. No squeal at all when I tried them.
Will hopefully get to hammer mine later on this evening and see if they still squeal when hot.Ninja
Posted 16th Dec 2009 at 18:07
Pages (3): 1 [2] 3
