displaying posts 26 to 50 of 50
Pages (2): 1 [2]
Author Subject: Oil Catcher Tank
i think on the s16 you could run both outlets from the oil filler [the two breathers, not the main filler hose] to each side of the catch tank, and then vent in via the tank lid [mocal] or with a k&n style cone filter thingy on it
my whole car and setup is so far from standard i have had to take a few different routes with things
Posted 23rd Mar 2010 at 20:58
ballys16
Sounds better, thank you Thumbs up
XSi 8V -> S16
Posted 23rd Mar 2010 at 23:02
pesukaru
might be a stupid question as I don't understand technical English 100% but where does the hose, that doesn't connect to the oil catch tank, go
To start, press ANYKEY!
Posted 24th Mar 2010 at 22:41
ballys16
Maybe a pic will help more:
(Suzuki Swift 1.3)
XSi 8V -> S16
Posted 25th Mar 2010 at 00:14
Sorry to revive this again, but there is mixed opinions in this thread.
Can we have a vote of which way to install a catch tank please? Flowers
or
Posted 15th Nov 2010 at 23:37
jimbamboon
glad you did revive it actually, have one on order and wanted to know the consensus. Also i accidentally bought one with 9mm connectors and am trying to get hold of some 15mm ones but i need to know the thread diameter of where the fittings screw into the tank, total balls up i know!
clicky code for my benefit
Posted 16th Nov 2010 at 01:17
chrisd306
Well ive got mine down at the front panel and is lower than all of your pics, mine does look rough hence the lack of phot in the reply lol and shitey slow net!!
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 16th Nov 2010 at 01:25
midlife
Just be careful lads, if you intend to use your car for motorsport (sprints, hillclimbs, racing etc) the RAC blue book states that IF you have an oil catch tank fitted it must be a minimum size of 2 litres. If you have a smaller one fitted (dependent on the scrutineer) you could be forced to remove it or fail scrutineering.......
Here is my Mocal 2 litre catch tank
I will be blocking one of the inlets as it breaths through the cap & there is no feed to the inlet.
Cool
Team 330™Cool
Team "no front end or engine"
Posted 16th Nov 2010 at 01:46
Anyone?
Should a pipe go back to throttle body?
Posted 16th Nov 2010 at 21:20
jimbamboon
Post #35
I'm not sure I want to put the pipe back to the throttle body as to me this seems like unnecessary contamination, however I wasn't sure whether it was recommended in order to maintain negative crankcase pressure as mentioned above.
Posted 18th Nov 2010 at 01:40
:: blade ::
Post #36
What are the advantages of fitting one of these? Apart from it cutting the oil vapour to the inlet?
Black Ph1 XSi-6
161.8BHP (Getting Better!!!!)
Posted 18th Nov 2010 at 02:34
swiftyboi006
Post #37
Tank needs to be lower than the pipe going into it otherwise you will get a build up over time. The second pic is the better option with the breather. On mine iv just got the pipe extended to the floor with a breather on the end with no catch tank. Does the same thing
Black p3 Love
Posted 20th Nov 2010 at 00:30
swiftyboi006
Post #38
Racerxbon you have one of the nicest engine bays on a 6 iv ever seen. 1 think thought......get the resonator box off n bung it up. Rrrraaaaaaarrrrrrrr lol
Black p3 Love
Posted 20th Nov 2010 at 00:57
smegal
Post #39
It's a 206.
Ex SC-6
Now in a Megane R26
Posted 20th Nov 2010 at 01:09
swiftyboi006
Post #40
Gti engine bay tho ;-)
Black p3 Love
Posted 20th Nov 2010 at 01:37
ballys16
Post #41
Hello there,
Sorry to revitalize such an old thread but I don't understand something.
With either pic1 or pic2, there is still vapour coming out of the tank - and it is oily. If it goes back to induction, oil still gets to where it might not help. On the other hand, not recirculating it but rather filtering it in the engine bay means that the oily vapour messes up the bay (and of course it stinks Smile)
Or am I just overthinking this?
Thanks,
B.
XSi 8V -> S16
Posted 10th Jan 2011 at 13:11
ballys16
Post #42
ballys16 wrote:
Hello there,
Thanks,
B.
I think my problem lies deeper.
There is a gap in my knowledge as to how the "PCV" regulator valve is supposed to work.
When is it shut and when is it open?
Trouble is I found oil in the air filter chamber Sad
XSi 8V -> S16
Posted 12th Jan 2011 at 23:46
rallyeash
Post #43
ballys16 wrote:
Hello there,
Thanks,
B.
with a filter on the top of the catch tank it should just vent the vapour/air out the filter and catch the oil in the tank. every now and again the catch tank will need emptying.
alternativly i had the below catch tank made up to my spec.
two 16mm outlets on the top, one for the pipe from the rocker and one for the k+n breather filter. then ive a return which will drain any oil back into the sump via the outlet on the block. although im running throttle bodies so dont have any of the pipework on the standard tb
309 3dr K20 Type R
Posted 13th Jan 2011 at 00:01
ballys16
Post #44
Thanks!
Fumes from the filter are oily, right?
XSi 8V -> S16
Posted 13th Jan 2011 at 00:21
rallyeash
Post #45
well not really, although there will an element of oil in the air it isnt anything that will make a mess in the engine bay.
309 3dr K20 Type R
Posted 13th Jan 2011 at 00:29
ballys16
Post #46
Thank you!
So the only thing left is the smell Smile
XSi 8V -> S16
Posted 13th Jan 2011 at 00:31
rallyeash
Post #47
not something u'd notice
309 3dr K20 Type R
Posted 13th Jan 2011 at 00:43
ballys16
Post #48
Nah, not me - my wife Smile
I did test it for a day and there is some smell in the garage or when in a jam as well as some vapour slipping from under the hood.
But maybe thats because my PCV valve might have given in?
XSi 8V -> S16
Posted 13th Jan 2011 at 00:50
rallyeash
Post #49
tell her she needs to man up Yes
309 3dr K20 Type R
Posted 13th Jan 2011 at 00:51
ballys16
Post #50
Cars and women rarely add up Smile
XSi 8V -> S16
Posted 13th Jan 2011 at 02:02
Pages (2): 1 [2]
