| Author | Subject: Rear Wiper - Wiping on its own |
livy
Location: Kirkcaldy Registered: 01 Apr 2007 Posts: 161 Status: Offline |
it is |
allesclar
Seasoned Pro Location: Sheffield Registered: 17 May 2009 Posts: 4,254 Status: Offline |
just a fresh bump as i have the same problem.opened the boot section with the wiper motor in it. Removed the blue relay and opened it up to see that it had corroded. Gave it a full on clean with wd-40 and then a slight sanding etc. Cleaned it up and re-installed it. still no joy. i am presuming it has completley burnt out and will try the local scrap yards, i mean ________________________________________ Team allesclar ® |
jpmatrix
Senior User Location: Hampshire Registered: 12 Jul 2007 Posts: 689 Status: Offline |
I had the same problem. Water had leaked through the tailgatelock due to me pressure washing the car. I managed to fix the relay by prizing the cover off and cleaning the contacts out. I then wrapped it in some tin foil. I cant believe these things are ________________________________________ |
fletch
Track Head Location: The nearest Shell garage Registered: 12 Jun 2004 Posts: 12,273 Status: Offline |
allesclar wrote: just a fresh bump as i have the same problem.
opened the boot section with the wiper motor in it. Removed the blue relay and opened it up to see that it had corroded. Gave it a full on clean with wd-40 and then a slight sanding etc. Cleaned it up and re-installed it. still no joy. i am presuming it has completley burnt out and will try the local scrap yards, i mean |
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
I've got the motor and relay assembly on a P3 breaker if yous guys are stuck.There are lots on ebay usually. ![]() As above I cable tied a u-bent plastic bag over mine. ________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
