displaying posts 26 to 50 of 50
Pages (2): 1 [2]
Author Subject: Alloy top mounts on KW's
puglover Banned!
he sold the other ones, they are so random at compbrake, ask him for the blue ones like i have or get phill to make you some. If they are 2.5 i apologise i didnt mean to give you the wrong advice.
Posted 10th Oct 2008 at 02:03
mabgti
NV motors
randomYes
no worries mate... should've measured them up. Cant wait to get em on!
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 10th Oct 2008 at 02:26
rallyestyle
mabgti wrote:
randomYes
Just remember to update when your done as the correct info will no doubt be of great use Yes
Just Drive It
Posted 10th Oct 2008 at 14:38
If you get stuck, give me a shout and I'll price you a pair up.
Posted 10th Oct 2008 at 19:43
mabgti
NV motors
Why have your top hats got a slit in it?
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 14th Oct 2008 at 01:44
Those are for non-strut coilovers - they slide onto the shaft and then seat on a thrust washer at the top, the recess allows the use of every last bit of travel without coil bind - all 16 inches LOL
They're in 7075 to get the maximum amount of offset though, so not all that cheap.
Posted 14th Oct 2008 at 02:01
mabgti
NV motors
ALL sorted now... does make a harsh rideYes
But for now i think i've got about 2 degree neg camber and a bit more castor... Will have to get it all tracked up sometime this week.
Pics to follow..
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 21st Oct 2008 at 19:32
mabgti
NV motors
The spacer which KW germany never came back to me about!
top hat hat to be bored out 20mm and spaced 8mm with a 25mm bored...
sleeve nut turned for maximum depth...
Tight fit on the KW spring!
Complete struts..
Pivot should give enough spacing without knock..
Maximum thread hold with thread lock..
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 25th Oct 2008 at 21:21
puglover Banned!
does it come off?
Posted 25th Oct 2008 at 20:59
mabgti
NV motors
Post #35
the spacer didnt budge much in a viceNo
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 25th Oct 2008 at 21:22
puglover Banned!
Post #36
nice one Smile
Posted 25th Oct 2008 at 21:26
Post #37
SERIOUS THREAD RESURRECTION WARNING, STAND BACK
This is exactly what I'm looking to do. I've got the KW v2's on the car, and I've got the top mounts.
After all the fuss and bother, what was actually needed from whom to make this work? Tophat thingies from Compbrake, aren't on their website but phone them up? Then what's all this machining stuff about bullcrap?
Ta doods.
Posted 16th Feb 2011 at 04:25
pugheaven
Post #38
Bump, I need to know this too, I'm going to be using avo coilovers and compbrake top mounts, will I need the cone type top hats too?
Posted 16th Feb 2011 at 20:31
dhampton
Post #39
For KW V2s...
Remove the spacer from the damper thread. It does come off but is threadlocked and tight.
Order some 60mm top spring mounts/pans direct from KW as KW use metric (KW part number is 65030056 I believe but check).
Fit with top-hat nuts & washer included with top-mount.
Clio 182 FF 306 Rallye (track) 306 Gti-6 Megane R26 Clio 172 Cup (track) 106 Rallye S2 (track) 306 Rallye Saxo VTR 106 Zest2
Posted 23rd Feb 2011 at 21:55
puglover Banned!
Post #40
did you put new bearings in those mounts?
how exactly did you remove the spacer??
Posted 20th Feb 2011 at 19:48
velar
Post #41
Have you use thrust bearings betwean the top perch and the spherical bearing( or do you rely on the spherical bearing for stearing rotation?)
Posted 20th Feb 2011 at 20:42
puglover Banned!
Post #42
rely on the spherical bearing Smile you can get some thrust type bearings to go at the bottom of your springs at demon tweaks. Id bet it would be ubber smooth with both but overkill maybe
Posted 20th Feb 2011 at 20:47
dhampton
Post #43
Molegrips to remove the spacer iirc
Posted 20th Feb 2011 at 20:55
puglover Banned!
Post #44
did you replace the bearings in the spoox mounts?>?
Posted 20th Feb 2011 at 20:59
dhampton
Post #45
No, bought them new and they've been fine.
Posted 20th Feb 2011 at 21:50
Post #46
Woohoo! Nice one people, I'll get those tops ordered up.
So no need to get the tools out on anything, should be possible with stock parts?
Posted 20th Feb 2011 at 21:57
Post #47
Right, so the bits arrived from KW just now. What appeared to initially be the wrong part is actually, I believe, a redesign:
The reasons I think they're correct is threefold. Firstly, they have the correct part number (65030056) printed on them. Secondly, I sent a picture from the previous page of the blue ones to the KW guy, who confirmed the part number. Thirdly, although they don't actually look right, they still do the job and don't interfere with the top mount at all:
So okay, they seem to be right. However only thing that seems weird is that the hole in the top doesn't seem to be the same size as the bearing at all, but close enough that it seems maybe they should be. Is this right? If it is (and it's just that's how they sit onto the bearing) then there only seems to be about a 2mm ring of the part in contact with the top mount bearing. Does that seem right? Will the coilovers somehow hold these central on the bearing? I'm sure it'll make sense once I get the coilovers off the car, just struggling to imagine how it all goes together...
Posted 1st Mar 2011 at 16:43
Post #48
Well this is embarrassing.
Posted 2nd Mar 2011 at 16:19
dhampton
Post #49
You should have these with the mounts?
It goes underneath the bearing. The top spring pan should sit against these
Posted 2nd Mar 2011 at 20:40
Post #50
Yup, got one of those on each side, which are sat as illustrated inside the bottom of the bearing.
However the top pan is then underneath that, and that's the bit that doesn't seem to make sense.
Maybe it will once I've got the coilover on. Trackday on Sat, then I'll whip them off.
Cheers mate.
Posted 2nd Mar 2011 at 20:48
Pages (2): 1 [2]
