displaying posts 26 to 37 of 37
Pages (2): 1 [2]
Author Subject: ML gearboxes
puglover Banned!
nah people have been blowing crown wheels out of diff casings in be3 boxes Yes one guy had a piece blow through the bulkhead and out his roof. Huh?
turbo monster though
Posted 4th Dec 2008 at 04:25
miles
As said the later box's got poorer casting's or lot's of crap in them,
There are a few design's in case, the Mi16 & TD have extra rib's, the later BE3's got different Diff cover's and went back to having a shim for the diff like the very early 198¾ BE1 boxes
www.pugracing.com
Posted 4th Dec 2008 at 05:14
monty-69
Looks like the gearbox out of the 170bhp 2.2hdi has got the heat treated parts. This suggests the previous ml6 had reliabilty problems when torque reached 270lbft. The torque of the hdi comes on a lot sharper though, and the manufacturers usually over engineer them. I think but not sure that some fords use this 2.2hdi and they have 295lbft with getrag box which could suggest psa limited the torque to save the box?
Posted 15th Dec 2008 at 18:06
ecureuil_zx16v
I think I'll try the ME5 gearbox, like robertinho... seems to be a extreme gearbox
with the RPM cut and tires I use, will do +- 230km/h in 4th gear at 402m, and 302km/h cutting 5th
The gearbox I use today is a BE4 with 3.94 diff, cutting 5th at 8k rpm gives me 327km/h (200mph)!! good for traveling
Citroen ZX 16v
XU10J4RS turbo
Posted 18th Jun 2009 at 22:42
ecureuil_zx16v
PLEASE HELP!!
Found the 2 kinds of gearbox for XU10J2TE for buying:
ME5 (older) - mechanical clutch, rod type gear selector
ML5T (newer) - hydraulic clutch, gear selector by cable
My doubt is, what
Citroen ZX 16v
XU10J4RS turbo
Posted 19th Jun 2009 at 23:57
puglover Banned!
i think its the hydraulic clutch you want. not sure though
Posted 19th Jun 2009 at 23:59
ML5 you want, it can be converted to cable clutch.
also the cable shift can be mounted into the 306 fairly easily.
Posted 20th Jun 2009 at 00:31
ecureuil_zx16v
I prefer cable cluth
my doubt is, what is stronger, suport a hi-boost engine with huge tires. My case is the worst case, drag racing.. This ML5T cheaper than ME5, and already with shift cables and all hidraulic clutch
Citroen ZX 16v
XU10J4RS turbo
Posted 20th Jun 2009 at 00:52
ecureuil_zx16v
bought the ML5T gearbox "kit" (from a Xantia Activa turbo 97) and now I'm going to put it...
now I don't know what clutch I'll use, I think I'll have to use the 235mm clutch and flywheel that came with ML5T, because of the pull-type clutch. I don't see a way to use a push-type clutch with that clutch fork.
welshpug!, how can I convert to a cable clutch?
Citroen ZX 16v
XU10J4RS turbo
Posted 1st Jul 2009 at 11:28
ecureuil_zx16v
Post #35
Citroen ZX 16v
XU10J4RS turbo
Posted 12th Jul 2009 at 08:35
kev-g
Post #36
miles wrote:
That was my first thought, But I have been told this by a very very good source which I have no reason not to believe
Probably the same soure who told me....I've got one sitting in the garage.... Wink
Posted 29th Jul 2009 at 03:05
Post #37
no not al BE boxes are interchangeable, there's lots that fit the DV6 diesels, and the TU5 and the EP3 and EP6 engines.
the V6 has its own bellhousing.
not sure if the angle of the DW bellhousing is the same as the XU10 one though the pattern is the same.
Posted 22nd Jun 2011 at 14:53
Pages (2): 1 [2]
