Author Subject: Flashing STOP light!
fletch
Track Head
Came on toward the end of my journey Roll eyes
Shit French electrics.
All temps normal, ideas?
Posted 11th Dec 2008 at 14:00
justinaccurate
Flickering or flashing regularly?
When my stop light came on intermittently recently it just needed the brown sensor on the thermostat re-plugging
Posted 11th Dec 2008 at 14:39
fletch
Track Head
Flashing. Brown sensor is disconnected iirc.
Posted 11th Dec 2008 at 14:53
aaron6
Mine came on for no reason and just went away about 5months ago.1 month later the head gasket went, possibly because of thermostat sticking.Sad Change the sensor and maybe for the sake of
Posted 11th Dec 2008 at 14:55
tobeski
Mine done it recently, was the fan controller unit (Bitron) that caused it as it had got wet after going through a puddle.
Also done it before when the Brown sensor packed up.
Could also be the thermostat, worth investigating.
Now rollin' in a 182FF
Posted 11th Dec 2008 at 15:39
fletch
Track Head
Doubt its the thermostat as temps are normal, I'm guessing fan controller sending dodgy signal to ECU.
Cheers Thumbs up
Posted 11th Dec 2008 at 15:44
aaron6
Cheers Thumbs up
Still may be worth checking it.So iv been told you just take it off and dip it in boiling water,if it opens fully its fine,if not,its f*cked.worth checking id imagin.Wont cost anything other than some coolent to top up and bleed back in.Smile
Posted 11th Dec 2008 at 16:59
dave
Check the oil level Dunno
Posted 11th Dec 2008 at 17:04
rich_w
This on your new engine Matt?
Checked the oil pressure switch connector etc?
Contact Details:
07732 822546
Posted 11th Dec 2008 at 17:12
fletch
Track Head
Nope other car. Haven't checked OP switch no. I've never seen the STOP light flash before, usually it stays fully illumninated.
Posted 11th Dec 2008 at 17:20
fletch
Track Head
Good shout, all good according to the dash sensor but will check manually.
Posted 11th Dec 2008 at 17:21
carisma306
did anyone find out what this was as mine is doing this now and the fans start as well when you start the car up? any help Smile
Posted 30th Dec 2009 at 21:57
lwgti-6
I've just been out in the car now and had the same problem....(flashing on and off quite fast)
I'm assuming its the brown sensor on the thermostat housing not being plugged in correctly as the fans kept cutting in and out on their own..
Anyone else confirm this?
EX Bianca 6 owner,
Now drives: Octavia vRS
Posted 1st May 2010 at 05:15
fletch
Track Head
Im convinced its fan related, broke the car in the end, so didn't fully investigate.
Posted 1st May 2010 at 05:40
lwgti-6
Ok mate,
Just hope my filter hasn't sucked water up and f*cked something up Dry
EX Bianca 6 owner,
Posted 1st May 2010 at 05:45
