displaying posts 601 to 625 of 1309
Pages (53): first .. 24 [25] 26 .. last
Author Subject: Daveyboy's Rallye Race car
Post #601
phillipm wrote:
You look like you've just found an old stash you'd forgetten about in the shelves LOL
Not been getting much sleep lately LOL
Posted 29th Nov 2009 at 14:11
matt h 306
Post #602
Good work.
Another red rallye killed its bottom end a combe yesterday.
Posted 29th Nov 2009 at 15:44
Post #603
matt h 306 wrote:
Good work.
Hate that track, it's cost me thousands! Angry LOL
Posted 29th Nov 2009 at 15:48
rallyeash
Post #604
good work, whens the next track day?
p.s did you get my pm?
309 3dr K20 Type R
Posted 1st Dec 2009 at 00:13
Post #605
I did mate, sorry for not getting back to you yet, were you wanting just the welding done with you supplying the tubes already mitred, or did you want me to do the whole thing?
Posted 3rd Dec 2009 at 01:58
Post #606
Bit more progress last night, installed the crank and checked the runout, less than 0.25 of a thou at it's worst point, and dead on all the way round for the other main journals (pretty damn good in plain english!)LOL
Then some plastiguage was used to check the running clearance on all the main bearings with the caps installed and torqued down, we also checked the thrusts too. All well within tolerance so no worries there...
Posted 3rd Dec 2009 at 03:57
Post #607
nice, someone doing it properly Big grin
Posted 3rd Dec 2009 at 04:07
Post #608
Cheers, but it's really just for peace of mind. With the quality of modern engine parts it's probably all good enough to throw it all back together and work just fine, but it's costing me so much to do, that I can't afford for it to fail as a result of something silly like a tight bearing or a dodgy valve etc. So I'm bieng anal and checking as much as I can, saying that I still managed to f*ck up by installing the bearing caps the wrong way round at one point, that stopped the crank from running freely I can tell you! Still, this is the first engine build for me so I'm learning as I go. Smile
Posted 3rd Dec 2009 at 04:26
jcphat
Post #609
You really are doing perfectionist work and it is good to watch. Keep up the posts.
New Forum same high quality intellectual debate!
Team Zimmer™
Posted 3rd Dec 2009 at 04:35
dan gti-6
Post #610
LOL
I was going to post, when you brought me the block you had caps 2-5 on the wrong way round, thought you would have noticed being that number 1 only goes on one wayWhistle
Had you worried for a bit i betSmile
Posted 8th Dec 2009 at 00:07
rich_w
Post #611
LOL
Laugh
True, although the writing on #1 bearing cap is orientated differently to all the others, so you can't use that to set out others Razz
Dan - I'll be up either Friday or Monday, got another head for you.
Best try and remember a cheque for the last lot for your boss too Laugh
Contact Details:
07732 822546
Posted 8th Dec 2009 at 00:26
Post #612
To be honest, It only became apparent when torquing up the main bearing caps that something was'nt right. Once the bolts started to be done up the crank started to bind, and I assumed it was something like a problem with the shells or thrusts. After a little flapping from me, Chris suggested that we try the main caps the other way round and that soon sorted out the 'problem'.
I will hopefully get the bottom end wrapped up this weekend, work permitting.
Posted 9th Dec 2009 at 00:02
chrisd306
Post #613
last time i seen a dial gauge was college i think!!
coming on well!! im needing a new head for mine i think as thoguth was a tapy lifter but probly a bent valve FFS!! will run it till it dies i tink, then will get new head another gasket from rich an head bolts this time aswell!! Dont know why cars are so cheap an easy to run its great.....
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 9th Dec 2009 at 01:45
rallyestyle
Post #614
Jesus dude, it just never goes right for you does it Sad
Just Drive It
Posted 9th Dec 2009 at 03:43
Post #615
I think it's having a red Rallye that's bad luck in general, mine seems to be cursed too...Dry LOL
Posted 10th Dec 2009 at 04:36
chrisd306
Post #616
what like is your diff mate, will they do another 1 at same price as you got??
& Audi Q5 S Line
Posted 9th Dec 2009 at 14:53
rallyestyle
Post #617
I think it's having a red Rallye that's bad lubk in general, mine seems to be cursed too...Dry LOL
Well i must buck the trend as mine is supreme Smile You guys will get them sorted im sure of it, that engine is gonna be better than new when finished Thumbs up
Just Drive It
Posted 9th Dec 2009 at 18:09
lotek
Post #618
you should be fixing her not doing this LOL
Posted 10th Dec 2009 at 02:39
Post #619
You would have to chat to matey at Demon Tweeks, probably be more expensive now as their prices seem to go up by about 5% year on year. I found it to be really good, however on an entirely track focused car it's not the one to have. You would want the plate type that fully locks really for best results, however as mine will do a fair ammount of road work it's a trade off I'm prepared to suffer.
Posted 10th Dec 2009 at 04:41
Post #620
Tonight, I checked the big-end bearing clearances on all four rods, all were ok. However, two rods have side clearance issues, both are a fair bit under minimum (8 thou.) so I'll try swapping them with the two rods that have enough clearance, if that does'nt help, some material will have to be removed from the thrust faces of the rods (I really dont want to have to do that though as that will mean the rods will need to be balanced again if I start taking metal off them) oh what fun!
Posted 10th Dec 2009 at 23:23
rallyeash
Post #621
hope with a swap around they will be all good. fair play though mate certainly doing it properlySmile
309 3dr K20 Type R
Posted 10th Dec 2009 at 15:20
Post #622
Thanks, me too. Hopefully I'm just bieng paranoid, but the side clearance is half what it should be, so it really would'nt be a fantastic idea to bolt it up and hope for the best. I'll take them all off and put a mike on them and see if any are thinner than the rest. My guess is that they will all be pretty close and it will be the thrust faces on the crank that are tight, it will be less work and less costly though to take metal off the rods to get the space I need.
Posted 10th Dec 2009 at 23:22
Post #623
Well, I ordered up my camshafts yesterday:
Inlet NRD 127: 296 degree, 480 thou of lift @ 104 degrees, 183 thou at TDC
Exhaust NRD 954: 143 thou @ TDC
They were made by Piper as development cams for an engine builder who was developing engines for National Hotrod racing. That's why the numbers don't match cams normally made by Piper. These made 230 hp on a high comp engine running twin 45m carbs.
Once I get these and check fit them, I'll be sending the head away for overhaul, new guides, re-cut seats, new valves, solid lifters and shimming etc. Upon consulting Brett Simms (An ex. Longman engine builder) I'm going to be sticking with the standard valve sizes (Other people on here have also said its not worth the bother upping the size) as they managed to get nearly 280 bhp on the standard sizes. I am going to get new valves though for peace of mind.
I still have no idea what sort of HP to expect from the finished engine, both the guys I have been dealing with for cams and headwork seem confident of 240+,which is nice Smile
Posted 2nd Mar 2010 at 03:04
Post #624
Placed my order with Piper today for my solid lifters and uprated valve springs,
Posted 24th Feb 2010 at 21:20
chris with a pug
Post #625
Posted 24th Feb 2010 at 22:01
