displaying posts 801 to 825 of 1309
Pages (53): first .. 32 [33] 34 .. last
Author Subject: Daveyboy's Rallye Race car
Post #801
phil dented my upper bar next to the wiper inwards by about 3mm by the looks of it, just enough for it clear the wiper corner, but it is silly tight. i was going to run a different wiper motor, possibly on the inside but it worked out fine
Posted 23rd Jul 2010 at 19:53
Post #802
There's 1 degree of bend on the tube IIRC, if you have access to a tube bender. Smile
You could grind the inner wing a touch where the stiffening ridge is if you don't want to do that, but you'll have to weld the tube to the inner wing to get the strength back in the panel.
Posted 23rd Jul 2010 at 20:09
Post #803
I'm sure I'll get it in there, It's not exactly the most important part of the cage anyway.
Posted 24th Jul 2010 at 02:04
chris with a pug
Post #804
Practice makes perfect and all that
Posted 24th Jul 2010 at 02:15
Post #805
Yeah, Kev's has a little bit of a racing dent LOL
Posted 24th Jul 2010 at 04:23
Post #806
Started to make a little 'progress' on this again, if you can call stripping the block right back down to nothing so I can paint it can clean it prior to finall assembly. I also purchased a few bits of kit to make sure of all the sizes as I don't want any nasty suprises!
Pistons/rods all out and numbered
Block given first coat of Hammerite smooth Dark Blue (Company colours are Navy blue and white, so if it's going on track it might as well give me a little advertising while it sits in the tyre wall/on the back of the tow truck/burns uncontrollably while upside down...)
And some bore dial guages, the micrometer set comes tomorrow, I have a mania for good tools, I just cant't help myself...
Should be ready to start bolting it all up by the weekend. Oh and I've cut up a standard inlet manifold ready to make a longer inlet than the Jenvey item, no pics of that yet but I'll take a few while I'm making it. (Hopefully this will be a modified inlet that actually improves things for once!)
Posted 7th Sep 2010 at 02:47
chris with a pug
Post #807
How come you didnt mask up the water inlet surface? I would scrape the paint off.!
Posted 3rd Sep 2010 at 02:59
Post #808
get a stanley on it afterwards Yes
Posted 3rd Sep 2010 at 03:37
Post #809
Thats the plan, a stanley blade and a bit of thinners on a rag will whip that soft new paint straight off.
Posted 3rd Sep 2010 at 13:50
lotek
Post #810
Its getting there!!
Posted 3rd Sep 2010 at 15:17
Post #811
lotek wrote:
Its getting there!!
Yeah, at a similar speed to continental drift, and I'm not talking about Johnny Frogs-legs going sideways in a Shitroen BX LOL
Posted 3rd Sep 2010 at 15:43
Post #812
Slapped a bit more paint around this weekend. Should be getting started on sump baffling soon, if I can be arsed...
Looks 10% faster already Big grin
Posted 7th Sep 2010 at 02:55
cwspellowe
Post #813
Why did you just paint it blue and then paint it a different blue again?
Besides that, can I come touch some shiny things?
Also, speaking of baffling, know any way of getting a baffled fuel tank to cure this fuel starvation issue of mine/all other P1 owners?
Bye bye Sundance Kid Sad
Posted 7th Sep 2010 at 03:13
Post #814
The first coat had some black mixed in with it from another job and was darker than I wanted. It needed a second coat anyway as it was patchy so I broke out a new tin. It's come up a treat now and should be easy to spot leaks etc. against the lighter color. And as for your fuel starvation, forget special tanks, get a swirl pot buddy Wink
Posted 7th Sep 2010 at 03:17
Post #815
I ordered up my Maniflow system on Friday, it's coming in kit form to save me a few pennies, I'll be welding it up myself. I got the spec for the lengths of the primary and secondary pipes from Sandy Brown so it should be just the ticket.
Posted 7th Sep 2010 at 03:26
tea boy
Post #816
daveyboy wrote:
lotek wrote:
Its getting there!!
I'm with you mate, you can't rush a good job.Big grin
Make tea, not war.
If it ain't broke......fix it until it is.
Posted 7th Sep 2010 at 04:03
Post #817
tea boy wrote:
daveyboy wrote:
lotek wrote:
Its getting there!!
I can't even rush a bad job Wink
Posted 7th Sep 2010 at 04:18
Post #818
I get to pick up my DIY Maniflow system on Saturday, £175 instead of about £500 means quite a saving if you do the welding yourself, all I need to do is find someone that's handy with a TIG torch now...
Posted 7th Oct 2010 at 16:11
miles
Post #819
I Could have got it even cheaper for you, I know a man who can
www.pugracing.com
Posted 8th Oct 2010 at 00:41
Post #820
Use the 1 bar 1.4 pump to pick up fuel to feed the 3 bar pump, the little 1.4 pump sits flat in a little plastic swirl pot of it's own right on the bottom of the tank, just need to seal the pot the '6 pump sits in so it's got some storage.
Posted 8th Oct 2010 at 01:22
chris with a pug
Post #821
I just noticed the Stanley paint brush Jim, no snap on jobbie!!
Posted 8th Oct 2010 at 00:55
Post #822
Thanks Miles Wink Big grin
Posted 8th Oct 2010 at 01:20
Post #823
I am trying to cut down on the impulse buying, it costs me a fortune this addiction to shiny things!
Posted 8th Oct 2010 at 01:21
Post #824
I took a ride out to Salisbury to collect my Maniflow this weekend and am very pleased with how it looks. I think it might be a litle bit of a pig to fabricate on the car as there are a lot of sleeve joints that can move about but I'm sure I'll manage.
Posted 11th Oct 2010 at 23:16
Post #825
I think they have a Jig to do their manifolds.
could bolt the flange on the head and support the rest in place and tack it up, then weld it fully off the car?
hoping that the welding process doesn't (as it always does LOL ) pull it out of shape...
Posted 11th Oct 2010 at 23:22
