Does anyone have one of these and if so what do you think of them?
Team 'unintentional rat look'
| Author | Subject: Pugracing quickshift |
clen666
Was just browsing miles' ebay shop and came across his quickshift kit.Does anyone have one of these and if so what do you think of them? Cheers ________________________________________ Team 'unintentional rat look' |
chris with a pug
Seasoned Pro Location: Southampton Registered: 16 Feb 2003 Posts: 5,366 Status: Offline |
Didnt know he did a quickshift, do you have a link!!!! |
clen666
its not like the other quickshifts that attach at gearbox end, it replaces gear lever mount, I am curious......!clickaroo ________________________________________ Team 'unintentional rat look' |
chris with a pug
thats like the compbrake one, they are really good. bit fiddly to fit though |
clen666
ah I see. Just my gear stick has decided to snap off at the ball bit, so was wondering whether this would be worth fitting while sorting it.Just a question of money now! ________________________________________ Team 'unintentional rat look' |
tangy7
Regular Location: Rhondda Registered: 20 Jan 2008 Posts: 149 Status: Offline |
I got one from comprake not fitted yet, costs |
clen666
tangy7 wrote: I got one from comprake not fitted yet, costs
tangy7
umm probably the same as any other quickshift of this kind. Will be better than standard.I had one of this type on a 106, coupled with chopped gear stick and a GE one lol, it had a very short throw. for |
clen666
ah right, didnt realise you were selling, thought you ment compbrake were doing them for that price.also does anyone know how much the gear stick costs from peugeot? ________________________________________ Team 'unintentional rat look' |
chris with a pug
there loads being broken at the momet id just grab one of those |
clen666
chris with a pug wrote: there loads being broken at the momet id just grab one of those Good idea! Cheers for the heads up ________________________________________ Team 'unintentional rat look' |
ken
Senior User Location: wokingham Registered: 28 Mar 2007 Posts: 905 Status: Offline |
so that quickshift, is it anygood then?i will prob buy it, never heard of that make to be honest ________________________________________ Team Black Rallye![]() xbox live - Xx 7 kenny 7 xX |
puglover
Banned!Location: Far out there Registered: 08 Jun 2006 Posts: 6,095 Status: Offline |
the pugracing shop is run by miles off here, top guy top products. |
tangy7
LOL comprake are selling them at that price.I've rarely seen them second hand and |
kust noticed this myself, i may buy one!!________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
deanstacey
Regular Location: Reading Registered: 07 May 2008 Posts: 242 Status: Offline |
I have one of these from Miles.Firstly, I have had other bits from Miles and they work fine. A few things to be aware of. Mine didn't come with fitting istructions. I'm mechanically OK with fitting bits but it would have been helpfull! Miles mailed me a quick list of how to fit them. Unfortunately it was for a 5 speed box as he'd never personally fitted one to a 6. Which meant I had to find out via the forum what to do with the reverse gear selector which is bonded to the gear stick. This has to be removed with a sharp knife and then held in place with a hoseclip when you've put the stick in place. It also needs to be trimmed back as it expands when cut and the lift bit wont slide back over it - I used a dremmel. Once fitted the real problems started. The two collars supplied have bad tolerances which resulted in the stick moving about in the ball joint. They are held in place by two grub screws that are at 180degrees to each other. This, added to the gaps between the shaft and collar, meant that moving the gearstick basically pivoted the collar on the shaft and after a short period of time caused the colar to come loose. This was usually the bottom one which was too big for the housing and meant that you had to force the gearstick into gear. You then have a floppy stick to drive on as you can't get to it to tighten it back up due to having to access it from underneath after removing the heatshield by the glowing hot cat! After this happening for 4 or 5 times (Usually after about 15miles of driving) I'd had enough. Speaking to a friend about it, he mentioned that he had a lathe - so we made some more collars with tight tolerances and grub screws at 90deg. Now done 140miles and nothing has moved or fallen off. So, yes, the QS works great if you have a lathe to make some new collars. Dean |
Seasoned Pro Location: Reading/parts for sale Registered: 21 Nov 2008 Posts: 4,311 Status: Offline |
^^same thing he said good bit of kit tho but always have agro with it just wrap electric tape around the gear stick and ram it on done the job for me and i love it ![]() ________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
i asked miles and he said hes having some newer updated version made up at the moment.i dont know what the difference will be ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
deanstacey
I sent him pictures of the collars I made, so hopefully the new ones will have tighter tolerances and grub screws at 90deg.I agree with Hovis though, love the short shift |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
Iv had one of there sat on my shelf for ages. Tried to fit at the weekend but like ppl have said the top hat bush that secures the bearing fouls the inside of the alloy mount. Has anyone got any pics or info of how they modified it. Cheers |
steve h gti-6
Location: Carterton Registered: 04 Dec 2006 Posts: 1,583 Status: Offline |
________________________________________ "Gotta Love The 6"According to my wife i think the 6 is the fastest car in the world, perhaps she is right LoL ! |
pugheaven
Just spoke to miles and he wont be making any new top hat bush's for a few months. Looks like i will have to make the bits. Any info would be a great help. |
ken
i may need help fitting mine? i bought one off miles, and im confused by the instructions lol :S ________________________________________ Team Black Rallye![]() xbox live - Xx 7 kenny 7 xX |
