displaying posts 76 to 100 of 485
Pages (20): first .. 3 [4] 5 .. last
Author Subject: My Rallye - V6 install page 3
lukejenks101
Post #76
Yes i may be useless but what did you want to ask about? LOL
PS3 I.D - jenkers101
Live i.d - Lukejenks1201
Posted 4th Jan 2010 at 04:12
clen666
Post #77
lukejenks101 wrote:
Napoleon dynamite Welshpug (right)
LOL
Good to finally put a face to some of the regulars
Team 'unintentional rat look'
Posted 4th Jan 2010 at 04:13
stu
Post #78
Good work lads, seems to be coming along nicely. Cool
Wish I had a workshop like that to play in. Sad
Posted 4th Jan 2010 at 04:26
Post #79
Well most of my face is cambelt cover Laugh
Adam cheers for the Subway lunch Thumbs up, not quite the savaloy and chips we left to get but non the less hit the spot.
Posted 4th Jan 2010 at 04:27
Post #80
Oi oi saveloy! LOL
Posted 4th Jan 2010 at 04:55
Post #81
You can't buy the old style cambelt setup from Peugeot now, just the new one that has to use a different water pump. Interestingly Peugeot are very nearly the cheapest for the clutch, but I'm getting a Gates Laguna/Clio belt kit off ebay for
Posted 4th Jan 2010 at 14:54
rallyestyle
Post #82
Looking good Adam Thumbs up Will be interesting to see how this shapes up to the orginal, it will sound cracking for sure Devil
Just Drive It
Posted 4th Jan 2010 at 15:14
Post #83
what price did Peugeot give you for the clutch? its
Posted 4th Jan 2010 at 15:19
Post #84
Its the same clutch but has an option to return your old one back to them. It was
Posted 4th Jan 2010 at 16:35
marksorrento205
Post #85
Tesstuff got a gen pug later type cambelt kit of ebay cheap. Worth a look. Is that clutch inc discount? When I got a qoute for one last week it was more than that for a recon one
Posted 4th Jan 2010 at 16:49
Post #86
Current Parts list:
6x Plugs
Inlet manifold gasket
Crank oil seal (might as well)
Flywheel (bolts + plate are the same as auto)
Gearbox
Gearbox mount + spike
D9 Cambelt kit (belt + pulleys and tensioner)
D9 water pump
Coilpack bolts (muppets had rounded them off)
Driveshafts
Rear engine mount and driveshaft bearing
Diff oil seals.
Gearstick + cables
Paul's ally top mount adapter plate
Christ on a stick thats a lot of stuff LOL
Posted 4th Jan 2010 at 16:52
Post #87
Mine is a dayco / INA cambelt kit from GSF. Worked out at
Posted 4th Jan 2010 at 16:54
Post #88
wooohhooo shiny shit to play with! LOL
shame the 306 is at the back of the unit, would have bought the pressure washer over to clean the engine and bay Doh
Posted 4th Jan 2010 at 17:02
Post #89
Its not really a problem as I can squeegee it to the door anyway. In fact might get some of the other crap off the floor at the same time.
Go get your car fixed you!
Posted 4th Jan 2010 at 17:04
rallyestyle
Post #90
I may have missed it but what box are you using with it adam?
Just Drive It
Posted 4th Jan 2010 at 17:10
cosmic spanner
Moral objector
Post #91
+6
was just wondering the same thing..
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 4th Jan 2010 at 17:12
Post #92
Its a coupe ML 5 speeder, not the auto Smile
Posted 4th Jan 2010 at 17:18
rallyestyle
Post #93
Good good, cant imagine an auto Rallye LOL
Just Drive It
Posted 4th Jan 2010 at 17:25
Post #94
I'm not sure it would fit actually. Wouldn't have the clutch issue to sort Hmm
Posted 4th Jan 2010 at 17:46
miles
Post #95
I do a hard rubber mount/bush for these, Has to be custom fitted thou due to the castings and cheap too
www.pugracing.com
Posted 4th Jan 2010 at 19:16
Post #96
Ok Miles, I may well be in touch.
Having the flywheel looked at when it arrives to see if it needs skimming or can have any meat taken off easily without weakening it. Should have somewhere local to get the shafts done as well, will find that out later (there are a couple of options).
Also trying to find out how much to advance the cams without causing any damage. Bit more torque wouldn't do any harm.
Parts should be mostly all arriving tomorrow Smile
Posted 5th Jan 2010 at 23:48
Post #97
No bloody post due to the snow, or deliveries into GSF. However Peugeot had everything bar one part and thats now having to come from France.
Apparently not many people need V6 Gearbox mount parts LOL
Posted 6th Jan 2010 at 23:47
Post #98
We need pics! Hyper
Posted 7th Jan 2010 at 00:25
Post #99
roland rat wrote:
We need pics! Hyper
+4.256789
Posted 7th Jan 2010 at 00:43
Post #100
I will update this post as I weigh things...
ML5 Gearbox - 50.5kg with selector fork
GTi6 Gearbox - 40.2kg with selector fork
GTi6 Inlet Manifold Complete - 9kg
GTi6 Exhaust Manifold - 5.7kg
V6 Inlet Manifold Complete - 6kg
GTi6 engine with plugs, cambelt aux tensioners, PAS + alternator, flywheel and clutch (no wiring, most water hoses) - 145kg
V6 - too heavy for the scales (over 150).
V6 Standard Flywheel - 8.1kg (mine is expected to be about 7kg - safety first!)
V6 Standard Clutch - 7.2kg
Not easy to weigh the driveshafts but as standard I would say there is about 3kgs more on the V6 ones. Most of that is the outer cv joints. Mine are likely to be lighter as they will be a hybrid.
Posted 10th Jan 2010 at 00:36
