displaying posts 101 to 125 of 485
Pages (20): first .. 4 [5] 6 .. last
Author Subject: My Rallye - V6 install page 3
Post #101
Photos will happen in due course.
Now waiting on 2x mounts and clutch-to-flywheel bolts. Then I can get the flywheel looked at to see if anything can safely be removed.
Posted 7th Jan 2010 at 20:55
shimmy
Post #102
Whats plan of action for the weekend then mate?
Team V6
Posted 8th Jan 2010 at 18:29
Post #103
Will be:
Plugs, inlet and cam covers sorting out.
New cambelt and pump to go on.
Install the gearshift
Crank Seal
Might get the clutch fork sorted out.
Flywheel, clutch and box on, depending if the flywheel is back from the machine shop.
Might get some of the wiring sorted out.
Weigh some more things Smile
Yours?
Posted 8th Jan 2010 at 19:10
rallyestyle
Post #104
So do you just do a cut and shut on the driveshafts then Adam? Might help the guys looking for Dimma length driveshafts Unsure
Just Drive It
Status: Online
Post #105
essentially yes, they cope with the 200 ish lbs from the V6's, not heard of a failure yet.
how long do the Dimma shafts need to be?
Posted 8th Jan 2010 at 19:14
shimmy
Post #106
How are you doing the clutch on yours? Could you just use the hydraulic clutch?
Only realy the wiring and a few small bits left to do on mine. Waiting to see how you get on with the wiring as we arent sure on it.
Team V6
Posted 8th Jan 2010 at 23:11
Post #107
We are going to extend the current clutch fork up through the nylon bush and then use the GTi6 cable to work it. Fair bit to fabricate there Smile
Cool - sounds like you'll be running waaay before me then
Posted 8th Jan 2010 at 23:48
shimmy
Post #108
When you hoping to get yours up and running?
Team V6
Posted 9th Jan 2010 at 01:00
Post #109
As soon as I can! LOL
Posted 9th Jan 2010 at 02:57
Post #110
Small update.
The GTi6 engine was fairly fubar'd. Head gasket had a pretty large hole (biggest Mei has ever seen - sheltered life Whistle) in it between the cylinders. One piston has very bad wear on the edge and there is about a 0.5mm deep groove in the head. Not sure if it can be saved tbh. Shame as its fine otherwise and the valves are all good. Any idea if it can be filled and skimmed?
Crank and camshafts on ebay soon...
Posted 9th Jan 2010 at 23:16
Post #111
Posted 9th Jan 2010 at 23:06
Post #112
Do you or Mei ever answer your phones?LOL
Posted 10th Jan 2010 at 00:09
Post #113
Mine has been dead most of today with a flat battery. Sorry - should have given you my work number! Doh
Posted 10th Jan 2010 at 00:34
ryangti6
Post #114
Good effort on the headgasket, will be watching this project as always wanted to know whats involved with the conversion.
Is the piston above a gti6 one? It looks dished in the pic and the ones i have seen are flat top.
Ryan
Posted 10th Jan 2010 at 00:45
Post #115
Much progress with the V6 then today Adam?
Posted 10th Jan 2010 at 00:49
Post #116
Yes its a flat top GTi6 piston - dodgy mobile photo i'm afraid.
Well... split the autobox off with torque convertor and flywheel, cambelt + water pump changed to the new type (coming off again to sort the cam cover leaks), split the old engine, fixed the 406 dTurbo gear linkage and changed over it wheels...
Not able to make a great deal of progress on putting it in due to no clutch/flywheel or mounts. Meirion wanted to do the wiring when its in the car.
Posted 10th Jan 2010 at 00:57
shimmy
Post #117
Do you have any diagrams for the wiring?
Team V6
Posted 10th Jan 2010 at 01:05
miles
Post #118
Intresting about the clutch operation, I've only had a quick look but the main selector gets in the way and the angle of it is wrong really
www.pugracing.com
Posted 10th Jan 2010 at 01:17
Post #119
Yes we had a look at it today and although I can see where you are coming from it will be ok. A friend has already done it on his 205 Smile
I'll put up photos when its done
Posted 10th Jan 2010 at 01:25
Status: Online
Post #120
that gasket is like fatty's leg but!
Posted 10th Jan 2010 at 02:30
Post #121
Not as bad as your phone answering skillz LOL
Posted 10th Jan 2010 at 02:46
Post #122
Adam you should have just bought this and sold the Rallye! LOL
Clickaroo! Smile
Posted 11th Jan 2010 at 01:09
stu
Post #123
Clickaroo! Smile
WTF happend to the interior? Huh?
Posted 11th Jan 2010 at 01:15
Post #124
Oh good god. Thats shocking! Very nearly made me bring up my tarte tatin Shock
Posted 11th Jan 2010 at 02:55
Post #125
Tarte tatin?posh food w*nker! LOL
Posted 11th Jan 2010 at 03:02
