displaying posts 126 to 150 of 485
Pages (20): first .. 5 [6] 7 .. last
Author Subject: My Rallye - V6 install page 3
Post #126
roland rat wrote:
Tarte tatin?posh food w*nker! LOL
Hardly... Thought i'd try to cook one as we had a bit of puff pastry and a few apples going spare. Didn't go quite to plan, but was good all the same Big grin
Posted 11th Jan 2010 at 03:05
Post #127
had a look at the 406 wiring diagrams earlier, looks quite straightforward Smile
A diagram showing the 406 (and 306) multiplugs would help a lot time wise but doesn't matter greatly.
Having the 306 loom would have made it easier Ninja
Laugh my ass off Doh
Think I might know someone with a diagram of a 306 plugs anyway, if I can figure it out I'll have a crack at fitting the immobiliser too Big grin
Posted 11th Jan 2010 at 03:12
Post #128
Can't you steal the loom off the ZX for a short while...? Whistle
Posted 11th Jan 2010 at 04:18
Post #129
nope, its totally different in that respect Razz
though whilst you mention it, I might still have the plugs that I cut off the end of it somewhere!
Posted 11th Jan 2010 at 04:32
shimmy
Post #130
Could you wire mine for me? Lol.
Team V6
Posted 12th Jan 2010 at 00:32
Post #131
guess what I found earlier....
Cool
don't you love hoarding stuff in the vain hope that it'll be useful to you or someone else sometime in the future? Laugh my ass off
possibly!
have you got the transponder unit or an unlocked ecu (professionally) and original gti6 loom?
any idea what tug-1-off charge for it?
Wiring Ninja has cracked 61 from 65 wires so far Ninja
Posted 14th Jan 2010 at 23:33
Post #132
Sat on a sofa in the middle of my industrial unit LOL
Should have taken a photo!
Nice on the plug Smile
Posted 15th Jan 2010 at 00:11
mechanical_repairs
Post #133
Wiring isnt my forte so hats off to you welsh man!!
Carl
Posted 15th Jan 2010 at 01:04
Post #134
done a handful now, they're all the same in principle on these French cars, helps with the later cars that most of the wires are numbered and use the same numbering principle across the 06 ranges Smile
I've also helped do two 1.6 16v Vitara FI engines into 1000 and 1300cc carbed Suzuki SJ's, Jap wiring is nuts Crazy
Posted 15th Jan 2010 at 01:20
shimmy
Post #135
Welshpug - If you could wire mine id give you 50 notes. Or you got any diagrams?
Team V6
Posted 15th Jan 2010 at 04:25
Post #136
Got work Mei,really hope to see this up and running by the 23rd Hyper
Posted 15th Jan 2010 at 04:36
Post #137
Pay him
Posted 15th Jan 2010 at 05:23
Post #138
Going to be lucky... Smile
Posted 15th Jan 2010 at 14:59
Post #139
I think we've now got everything to do the conversion. Flywheel is back and lightened by exactly a kilo - still a fairly hefty 7.1, but every little helps, especially as its all on the outer part of it.
Hope to get on with it properly tomorrow Smile
Will have a camera then too!
Posted 15th Jan 2010 at 22:18
Post #140
Been trial fitting the engine and box. It is going to sit about 2 to 3 inches further back than Carl's. Although this will mean more cutting of the subframe it will help the weight distribution.
Anyway fair way to go yet...
Posted 17th Jan 2010 at 03:09
Post #141
Pics? Unsure
Posted 17th Jan 2010 at 03:23
Post #142
In the middle of the trial fitting marathon (it went in and out about 15 times...)
SES ally top mount kit
Bonnet shuts! Yay!
The difference between a shit pattern part cat and what mine should have looked like. (chin up CUJ)
Wiring wizard - shimmy you need...
Finally swinging freely on its top mounts with no driveshaft, exhaust or diff clouting.
Posted 17th Jan 2010 at 22:02
Post #143
Quite a few things still to be done - subframe needs welding, clutch arm, driveshafts and finally putting the thing in Smile
Posted 17th Jan 2010 at 22:04
shimmy
Post #144
Haha, yeah i need something to help the wiring. Is that done now? Coming on nicely by the looks.
Team V6
Posted 17th Jan 2010 at 22:08
mechanical_repairs
Post #145
Its getting there mate looks very nice sat in place.
Whats the cost of the mount adapter you had made? Mine has had a 406 mount welded into the inner wing.
Carl
Posted 17th Jan 2010 at 22:09
lotek
Post #146
Smoke
Post #147
Carl
Its from a guy on ebay. Would make your engine sit a lot further back in the bay - the subframe on mine will have had a lot more modification than yours. Will post pics in the future when it is welded.
Ebay Link Smile
Posted 17th Jan 2010 at 23:45
Post #148
Fair play that mount looks awesome!
The shiny-ness makes me want to do the conversion just for that LOL Nice to see you have retained the crossmember also chaps Thumbs up
Posted 17th Jan 2010 at 23:50
jonnie205
Post #149
what gearbox mount is that?
Posted 18th Jan 2010 at 00:32
Post #150
standard 306 mount, shiny bit ias just a replacement bracket for the 406 gearbox as it didnt come with it, its stamped 96 - 2 years older than the donor. Had to come from France as well!LOL
It has now been modified to bring the gearbox end up about 10mm over standard. Also dropping the front of the subframe by about 6mm. The big problem is getting decent driveshaft clearance on the subframe - the diff and exhaust is easy enough as you can remove/replace metal, but the driveshafts foul on the wishbone mounts which can't be cut. The top mount will also be spaced up by about 5mm. Still fits under the bonnet Smile
Posted 18th Jan 2010 at 02:27
