Author Subject: Uprated rear ARB, how do people find them?
306matt
Hi all,
Tempted on getting one for the Hdi, what are peoples general thoughts on them? I get the vibe on here they are worthwhile mod, any negatives? How does it affect day to day driving?
Thanks in advance,
Matt
Team Astor Front Mounted... Hybrid turbo on it's way.
Posted 17th Jun 2010 at 03:13
lotek
day to day driving isnt compromised at all.
its a very worthwhile mod if your into spirited or track driving.
Posted 17th Jun 2010 at 03:33
As Rick said, most of the time you won't even know it's there, until you start really leaning on it in the corners. I got the mahoosive 30mm one in mine and it makes it corner flat as a pancake. You need to do something to stiffen up the front though too if you plan to fit a really big ARB in the back.
Posted 17th Jun 2010 at 05:18
306matt
As in upgrading to hard shocks, I am running Eibach pro spring and new OE shocks.
I think I am just going to source one of Ash's ARB's, it sounds just what I need. Thanks for the information.
Matt
Posted 18th Jun 2010 at 03:15
awesome man!!!!!
Posted 18th Jun 2010 at 03:20
dommo
Flatter than this? Wink
clickedeydoodar
'99 306 Meridian TD with Bosch fuel pump - Cheap veg oil motoring
'99 Xantia Activa turbo - not cheap veg oil motoring Sad Goes around corners well though
Posted 18th Jun 2010 at 03:49
clickedeydoodar
Of course Whistle
Posted 18th Jun 2010 at 04:14
306matt
Haha, thats vidoes amazing!
Matt
Posted 18th Jun 2010 at 04:20
gti-dan
Still need to fit mine. Might help with this...
Posted 18th Jun 2010 at 04:30
You still get that unless you sort the front end at the same time, all that weight transfer towards the front makes it impossible to stop roll just by fitting a humungous ARB, are you on coilovers? If so get some 500-600 lbs springs up front, pancaketastic.
Posted 18th Jun 2010 at 04:35
gti-dan
got spax rsx coilovers. where would i get the springs from to them? would any fit? i spoke to spax and they only have the one spring for that car???
Posted 18th Jun 2010 at 04:39
As Daveyboy says, that's roll at the front that's the problem, not the rear.
If they're coilovers 2.25" springs should fit.
Posted 18th Jun 2010 at 04:41
lotek
by the looks of it you went wayy to fast with too much lock at that corner ! LOL
may explain the lift lol.
lotek
you can get the springs from rallydesign or pistonheads seconhand. im on 325lb springs and all is ok .
Posted 18th Jun 2010 at 04:44
gti-dan
yeah probably too fast! You can't see but the corner is tightening up into a right hairpin coming back on itself, hence the lock.
There is a smaller spring which sits on top of the main sprint will this need replacing too?
How much would a thicker front arb and strut brace help with handling? dont really get talked about much on here.
Posted 18th Jun 2010 at 04:48
Lotek does'nt believe in strut braces, his car handles worse with one fitted!
As fur uprated front ARBs Phillip M is the suspension gnu, if he does'nt make something I bet he knows where you can get one. (Polybushing the ARB bushes is a goiod start though)
Posted 18th Jun 2010 at 04:52
lotek
that little spring is a helper spring. dont worry about that.
brace wise, i found mine handled worse with a top one.
Posted 18th Jun 2010 at 04:54
lotek
LOL beat to it
Posted 18th Jun 2010 at 05:05
polybushing the ARB? LOL standard factory polybushes,,,,
Posted 18th Jun 2010 at 05:11
Conversely I find mine much better with a lower brace LOL
It is quite dependent on tyres and preference when it comes to toe settings though.
I'd go with stiffer springs over a stiffer arb, but you may have no choice - you can't go too hard on the springs without cocking up the front damping rates, even with the adjustment available.
I should have an adjustable front ARB setup ready soon, but that's for another thread...
Posted 18th Jun 2010 at 05:15
They are rubber are'nt they? Nylon then, I know what I meant Razz
Posted 18th Jun 2010 at 05:16
306matt
Does anyone know what spring rate Eichbach pro S are??
Thanks,
Matt
Posted 21st Jun 2010 at 23:08
