displaying posts 226 to 250 of 388
Pages (16): first .. 9 [10] 11 .. last
Author Subject: Midlife's Rallye
Post #226
no discount?
Posted 3rd Nov 2010 at 00:11
midlife
Post #227
no discount?
Discount for whatDunno
Cool
Team 330™Cool
Team "no front end or engine"
Posted 3rd Nov 2010 at 00:14
rallyeash
Post #228
engine looks really good, impressed with the attention to detail.Smile
309 3dr K20 Type R
Posted 3rd Nov 2010 at 00:50
Post #229
midlife wrote:
no discount?
Cool
from pug dealer?
Posted 3rd Nov 2010 at 00:55
midlife
Post #230
midlife wrote:
no discount?
Cool
from pug dealer?
Those robbing pikey bas**rds just laugh in your face if you ask for a discount, I've spent a couple of grand with them over the last few years. I got charged £5 + vat the other week for a single 10mm 8.8 bolt Grrrrr
Cool
Team 330™Cool
Posted 3rd Nov 2010 at 02:53
rallyeash
Post #231
jesus, just go to a nut and bolt supplier, most ind est's have them.
could buy a pack of 25 for that!
309 3dr K20 Type R
Posted 3rd Nov 2010 at 03:03
Post #232
kents! Sad I always get discount without having to ask!
Posted 3rd Nov 2010 at 03:04
midlife
Post #233
Yeh I know, that's what I was so mad about, I'd decided to change from a 136 to a 137 tooth timing belt kit, my problem was that the bolt that goes through the middle of the 136 tooth tensioner is a weird jobbie that won't fit through the 137 tooth tensioner, I didn't know the spec of the proper bolt so I had to get it from the stealer. He agreed with me when I told him he should wear a mask when robbing people!!!!!
Cool
Team 330™Cool
Posted 3rd Nov 2010 at 03:11
big g
Post #234
Does this mean my car is covered in yet more yellow overspray? Talk about fannying about!
BRIGSPORT
Fridge men do it in the cold
TEAM Back garden into workshop
TEAM 306 meridian track car
TEAM I'm bored of thinking of stuff to put TEAM before.
Posted 5th Nov 2010 at 04:00
Post #235
Coming along nicely mate, keep up the good work Thumbs up
Where did you get that sheet of carbon fibre from, is there more available?
Posted 5th Nov 2010 at 14:38
puglover Banned!
Post #236
have you got the valve stem seals part number wayne?
Posted 5th Nov 2010 at 17:15
lotek
Post #237
50 nugs for the steering wheel? Shock
bargainous! how much was the boss?
Posted 5th Nov 2010 at 17:41
midlife
Post #238
big g, yes lots more overspray
cjm_harris, the carbon sheet came from Motorsport tools of their website
puglover, I jot them from Lukejenks, he should be able to sort you out
Lotek, I want a snap off boss for the wheel, it will cost approx £130 but I could use a bog std boss of ebay if stuck, its the same size as sparco, momo etc
Cool
Team 330™Cool
Posted 5th Nov 2010 at 18:13
Post #239
Cheers for that Wayne.
Downside is I will probably end up buying shit loads more stuff from them too Doh
Posted 5th Nov 2010 at 18:19
midlife
Post #240
I know exactly what you mean, after a tip off from rikky I went on there to spend £50 on seat mount rails & ended up spending £200Doh
Cool
Team 330™Cool
Posted 6th Nov 2010 at 01:21
Post #241
LOL
Posted 6th Nov 2010 at 01:28
chris with a pug
Post #242
Cool
I know that feeling,
I hope to start fitting my seat mounts this weekend. should be fun.
Posted 6th Nov 2010 at 01:33
midlife
Post #243
Think I may need to actually get a seat before I can start on mineDoh
Cool
Team 330™Cool
Posted 6th Nov 2010 at 01:38
chris with a pug
Post #244
Cool
Dont be so silly, I am sure u could guess and the seats will fit fine
LOL
Posted 6th Nov 2010 at 02:12
Post #245
Plenty of room from the door bars should do.
Somewhere in the middle perhaps Whistle
Posted 6th Nov 2010 at 02:17
midlife
Post #246
Been buying a few things recently.
This turned up today from Merlin Motorsport
I've done a bit of research & for motorsport use IF you fit an oil catch tank it MUST be a minimum 2 litres in size.
This Mocal one is beautiffly put together, a bit pricey at £120 delivered mind but compared to everything else on the Market it's streets ahead!
Cool
Team 330™Cool
Posted 6th Nov 2010 at 16:13
midlife
Post #247
First job for today was to fit the power steering pump.
Best tip is fit the brackets to the sump first! There is just not enough room to get the spanner in to the two middle nuts with the pump in place.
Next up was to fit the can shaft oil seal on the inlet cam. I put a light smear of rtv sealant around the outside diameter of the seal & a little tiny bit oil on the seal lip. I found that the hub nut socket I've got is the perfect size to push the seal in with, a few taps with my nylon mallet & it was in.
I then held the inlet cam in place with the tab from the pulley & a 6pm drill shank.
Coz I'm really anal about damaging the valves I'd only fitted one cam shaft, my theory was that I could fit the second cam roughly in the correct position, which should prevent valve to valve contact. Don't get me wrong, it was a lot of fannying about but I'm happy it worked.
After fitting the second cam seal I fitted both pulleys & fitted the cam belt. I've got a 137 tooth cam belt & tensioner. What an easy job it is, no seriously, I've heard it can be a bit of a ballache getting the tension right with 136 tooth kits, with the 137 tooth tensioner you just turn it clockwise with an allen key until the pointer points to a groove in the mount, then tighten up the central bolt & it's done!
Part washer & a toothbrush cleaned up the cambelt cover nicely.
Here we go, one low compression engine ready to go!
Think I'll have a look at fitting the inlet manifold tomorrow.
Cool
Team 330™Cool
Posted 7th Nov 2010 at 01:58
davedgti6
Post #248
Nice work Wayne Thumbs up ,that bolt holding the power steering pump on is seriously long LOL , took me ages to fit mine as I left my cordless impact gun in work Doh and the nuts are hard to get to,
Interesting that your using the 137 tooth kit, I used one on mine for two years with no problems whatsoever, and as you say they are a piece of p*ss to tension, I was then swayed by everyone saying that the metal tensioner was better so I went back to the 136 tooth kit, will be interesting to see how you get on as i would prefer to fit the 137 tooth kit due to its simplicity Smile
Posted 7th Nov 2010 at 03:36
rich_w
Post #249
Looking good Wayne Cool
Contact Details:
07732 822546
Posted 7th Nov 2010 at 05:01
midlife
Post #250
Dave, my cordless impact wrench saved the dayLaugh my ass off
Rich, cheers, looks like I'm getting there at last, still nowhere near finished yet thoughDoh
A problem I did encounter today is that I've removed the STD oil to water cooler in favour of a proper oil to air cooler, the mocal sandwich plate came with an extention tube in the middle, female m20 thread at one end & male m20 thread at the other. As I have removed the original oil cooler the male thread on the block is not there anymore & I'm left with a female thread, so the sandwich plate won't fit.
I've been searching tinternet all night & I can't find a male to male extension tube for a sandwich plate anywhere so I've been looking for some m20 threaded tube either, I only need a piece about 40mm long.
I'm sure I'm not the first person to come across this, what have others done to get around this?
Cool
Edit, this is the extension tube from inside the STD cooler, male at each end, it's too long for the sandwich plate though..
This is similar to what came with the sandwich plate, male one end & female the other.....
Cool
Team 330™Cool
Posted 7th Nov 2010 at 05:54
