displaying posts 251 to 275 of 388
Pages (16): first .. 10 [11] 12 .. last
Author Subject: Midlife's Rallye
puglover Banned!
Post #251
think my cooler came with an extension bolt Yes
Posted 7th Nov 2010 at 18:43
Post #252
Buy some M20 threaded bar/set screw and drill it out?
Posted 7th Nov 2010 at 19:24
Post #253
I can drill out a set screw or some threaded bar if you need me to Wayne, just let me know what size you want it drilling to and how long you want it and i'll see what i can do Thumbs up
Posted 7th Nov 2010 at 19:41
midlife
Post #254
Thanks for the offer Stephen!
I might just take you up on it if the suggestion from Miles doesn't work.
miles wrote:
This old chesnut, Comes down to people not knowing what they are selling I'm afraid or saying you need another part, Just order 1103.54 (Mamelon or thread in English) from Pug, around a £1.00
I've had quite a nonproductive day at the garage today.
I first checked my ptfe gasket against the sc inlet & found that I needed to dress the bores in the gasket a little to get rid of some positive steps into the gas flow. I just used a drum sander in the drill.
I then dummy fitted the sc inlet on the engine with a spare fuel rail to see where I could position the dip stick tube.
I then set about stripping the fuel rail from my old na inlet manifold. I removed the two bolts thinking it would pull off the tops of the injectors easily. After 5 minutes on my hands & knees on the floor with no success I put the manifold onto the bench only to discover that each injector is held in the fuel rail with a little black clip.
Clips off & it came apart fairly easily.
I then spent a couple of hours preparing the fuel rail for paint, what a ballache ensuring no crap got inside it!!!!
Fuel rail painted.
Also painted the dip stick tube.
Decided to pull up stumps at this point as it was bloody freezing!
Cool
Team 330™Cool
Team "no front end or engine"
Posted 7th Nov 2010 at 23:09
Post #255
haha loving the leather sofa mate to sit down nd work on LOL
Posted 7th Nov 2010 at 23:47
midlife
Post #256
It's somewhere to rest my old bonesLaugh my ass off
Cool
Team 330™Cool
Posted 8th Nov 2010 at 01:10
midlife
Post #257
This turned up in the post today from Miles, cheers buddyThumbs up
Problem solved!
Cool
Team 330™Cool
Posted 10th Nov 2010 at 01:18
Post #258
cute little doggie
Posted 10th Nov 2010 at 01:27
midlife
Post #259
hovis16 wrote:
cute little doggie
It's Princess Aura Tilley PompomBlush
Cool
Team 330™Cool
Posted 10th Nov 2010 at 04:07
eddy_gti6
Post #260
Cool
that dip stick looks huge Laugh my ass off
Posted 10th Nov 2010 at 06:48
midlife
Post #261
My 1 litre swirl pot & Facet solid state fuel pump arrived today.
I'll be using the facet pump to lift the fuel from the tank to the swirl pot then I'm planning on fitting the Walboro high pressure pump somewhere under the bonnet so that the run of pipe under high pressure is as short as possible.
I know that most of the SC boys use the STD in the tank pump to send the fuel to the swirl pot but my theory is that the STD pump is designed to run at 3 bar & won't like the fact that it's seeing no pressure. This Facet pump on the other hand is designed to run at 7psi max so should cope nicely.
Cool
Team 330™Cool
Posted 11th Nov 2010 at 23:46
midlife
Post #262
Wow, 10000 viewsShock
Thanks lads! The motivation this gives is unbelievableThumbs up
Cool
Team 330™Cool
Posted 14th Nov 2010 at 03:58
Post #263
Oh more shiny bits! Hyper
Posted 14th Nov 2010 at 04:01
midlife
Post #264
After seeing a thread from one of our Scottish members showing the end result (crash pics) of using a pattern brake master cylinder on an expensive project car I decided mine was getting a genuine Peugeot master cylinder.
I got one from Luke Jenks for £64.48 + vat, very reasonable I think.
It arrived today, cheers Luke!!!!
It's coming together slowly but surely
Cool
Team 330™Cool
Posted 16th Nov 2010 at 23:39
eddy_gti6
Post #265
Shock you covered her tits... NOOOOOOOOOOOO!!!!
Posted 16th Nov 2010 at 23:42
midlife
Post #266
Laugh my ass off did you like what I did there keeping it safe for workLaugh my ass off
Cool
Team 330™Cool
Posted 16th Nov 2010 at 23:58
eddy_gti6
Post #267
not the best fake boobs i have ever seen but atleast you got the white bits right Laugh my ass off safety first tho
Posted 17th Nov 2010 at 00:00
Post #268
Laugh my ass off
eddy_gti6
Post #269
looking good tho. when you expecting to have it ready for the track Devil
Posted 17th Nov 2010 at 00:03
midlife
Post #270
If things go smoothly we should be good to go June/July ish next year
Cool
Team 330™Cool
Posted 17th Nov 2010 at 00:35
berger
Post #271
When I replaced the m/c in the Xsara earlier this year I bought a pattern one, only to recieve it, decide that the quality looked a little shoddy and go to ECP to order an OE one, which was 10x better!
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 17th Nov 2010 at 01:28
Post #272
I reckon that picture is Waynes sneaky way to get another 1000 views sharpish....Hmm
Posted 17th Nov 2010 at 01:35
chrisd306
Post #273
looking forward to seeing pics of your fibre glass bits so that i can deside if im getting some or not!
That small helper pump. bet its loud, the 1 in cherrys 106 does your nut in clicking away!!
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 17th Nov 2010 at 12:32
midlife
Post #274
I'm going to mount it on rubber bobbins so it shouldn't be too bad, let's face it the whole car is going to be bloody noisy so a bit of ticking isn't going to make much difference..
I'll post a write up on the fg bits when I get home on SundayThumbs up
Cool
Team 330™Cool
Posted 17th Nov 2010 at 12:50
chrisd306
Post #275
Cool as im thinking of buying a bonnet and door cards and bootlid, then some poly carb windows.
My mates 106 the noise is mad, but if you watch his videows on youtube you can hear the pump clicking over the exhaust lol an his is mounted straight to the floor tho, he used to where ear defenders on the road it was that bad lol.
& Audi Q5 S Line
Posted 17th Nov 2010 at 18:26
