Author Subject: Creaking/knocking when turning!
jakeypoo
When I turn in my rallye I sometimes get a creaking sound coming from the suspension and other times when it is bumpy it seems to make a knocking sound as the suspension compresses!
Anyone know what could be causing this?
Posted 11th Oct 2010 at 12:00
jord294
worn mounts ot bushes Dry
Posted 11th Oct 2010 at 16:11
jakeypoo
Is this a cheap/easy enough job to do?
Im just getting my head around the peugeot as used to looking a Z series vauxhall engines, and vauxhalls as a manufacturer
Posted 11th Oct 2010 at 19:01
cheap yes easy.......can be lol
Posted 11th Oct 2010 at 19:39
honestly3k
i had same problem in the front drivers side when i changed the top mounts, droplinks, springs and struts. Think it was slightly loose top mount screws (the 3 you can see from the engine bay) so tightened them and not had it since but only driven it once though it was a spirited run in the b-road twisties! Easy to change if you have half a clue about what you're doing... Smile
Posted 12th Oct 2010 at 23:17
jakeypoo
Will give that a go first then! Cheers for the info!
Posted 13th Oct 2010 at 00:21
kit
Also have this exact problem, yet to have it looked at, keep us posted about what was causing the knock.
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 13th Oct 2010 at 22:58
tacha-gti-69
i had this problem turned out to be a cv joint
Posted 21st Oct 2010 at 22:12
phil b
Usually a tired/seized topmount bearing, it's usually the spring turning in it's cup, hence the creaky twangy sound, had this on most my pugs living down a farm drive
'97 PH1 'Sigma Blue' 306 GTI 6 project 'Tooters'
194.2bhp 127.6 dB
'96 PH1 'Black Noir' 306 DTurbo (project in permenant storage)
'94 300tdi LR Discovery (project gone dead and buried)
'99 td5 LR Discovery 2 (trailer tug and family bus) project 'in the garage getting chassis welded' (again)
The 6 can go fast, the disco can go anywhere
Built: 9 January 1997 - that's a Thursday
Skip Brown cars: tarporley Cheshire Tel: 01829 720492
add me --> philbrindley85@hotmail.com
TEAM: Snapper Sad
Posted 22nd Oct 2010 at 14:44
paulvt
Mine does the same but also does it from the rear end sometimes? Rear beam seized?
allesclar wrote: wrote:
the only kind of similarities of the xsi and a 6' is if you jumble the letters round to spell six Razz
Posted 24th Oct 2010 at 01:58
