Author Subject: rear beam vibrating when hard braking?
zxturbo400
Does anyone know what this can be? the cars lowered 80mm and is on the bumpstops ( shit i know) and the rear shocks are leaking (obviously)
when under hard braking the rear beam vilontly vibrates, what could cause this?
cheers!
Posted 10th Jan 2011 at 05:33
jeffers Forum Admin
Rear beam mounts foobarred!
Team Running Engine again!
Team Negative Camber!
Posted 10th Jan 2011 at 05:35
everything is fooked, come back when you've sorted that Thumbs up
Posted 10th Jan 2011 at 13:37
rallyeash
beam mounts, rear discs, shagged shocks.
also bring it up 40mm, might look alright then too
309 3dr K20 Type R
Posted 10th Jan 2011 at 13:40
FACEPALMSMILEY Crazy
Posted 10th Jan 2011 at 13:49
rallyeash
309 3dr K20 Type R
Posted 10th Jan 2011 at 13:52
tvrfan007
My thoughts exactly.
How can you expect it to do anything else when you've listed faults already?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 10th Jan 2011 at 15:14
sounds like yo need a complete back end mate. your disc are fooked causing the beam to vibrate because its to low which proberly hasn't been apart since it was lowered which was more than likely done the wrong way.Huh? get it sorted
Posted 10th Jan 2011 at 15:19
zxturbo400
its drum btw, cheers for imput, il tell him to get another beam for it, was fine at 120mm when i had it and after being sat for months its had no use so dont know why its just started
cheers
Posted 10th Jan 2011 at 20:44
might be oval drums then.
Posted 10th Jan 2011 at 21:18
zxturbo400 wrote:
was fine at 120mm
Shock
Posted 10th Jan 2011 at 21:25
davidmartin
zxturbo400 wrote:
was fine at 120mm
The tarmac was absorbing the vibration.LOL
pet hate, the cat
Posted 10th Jan 2011 at 22:34
zxturbo400
Aye, had no bump stops and everything was on the floor, i guess its only 80 at the momment, il get the drums off and have a look at the rear end! its a horrible vibrating that goes right through the car, its gained so many problems since i owned it Sad
Posted 11th Jan 2011 at 02:13
rallyeash
always makes me laugh, people think the lower there car is the cooler it is too...
309 3dr K20 Type R
Posted 11th Jan 2011 at 03:09
zxturbo400
was as low as a mx5 roof wise, handled shite and couldnt go anywhere when i had it, the bottom of it was mashed, il get pics of the underside when we change the steering rack and beam (if thats the problem!)
Posted 11th Jan 2011 at 05:33
