I know there's loads of these threads on here but mine is all through the rev range .I've tried unugging maf or map sensor I dOmt know what it's called and engine cuts out instantly what other things could I try ??? Thx in advance
| Author | Subject: Another hesitation issue |
daddy5times
Junior User Location: halifax Registered: 29 Jul 2011 Posts: 69 Status: Offline |
I know there's loads of these threads on here but mine is all through the rev range .I've tried unugging maf or map sensor I dOmt know what it's called and engine cuts out instantly what other things could I try ??? Thx in advance |
daddy5times
I've also tried unplugging lamba and taking it for a quick razz problem remains .all plugs look a nice soot free light brownish colour what else can I try??? Thx |
swiftyboi006
Bit more info as to whats going wrong with it?________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
daddy5times
Just holding back when I put foot down even of I do it slowly .it's like someone's holding car by bumper to slow it down when I take my foot off a bit it's ok .I can feel it trying to go but it doesn't I've tried it when I've unplugged tps/lamba/ when I unplugged maf/map it cut out instantly .idles perfectly when I set off at lights it holds back soon as I put foot My foot down but the picks up a bit then hesitates all throgj driving range .I'm a bit stumped |
Tried the ICV?________________________________________ ![]() |
daddy5times
No I've not tries icv I thought that just sorted idle????I've done ecu reset |
daddy5times
There seems to b a very small split in the pipe that joins the big pipe witch comes from the throttle body ???? .wondering if this could b making it worse |
gti6power
Junior User Location: Barnstaple Registered: 05 Mar 2011 Posts: 77 Status: Offline |
i had the same problem with mine and it turned out to be a 10 amp fuse had blown for the lambda sensor or oxygen sensor(which ever you want to call it) in the fusebox near the ABS pump |
daddy5times
Cheers I'll have a look in morning |
daddy5times
No all fuses seem ok! |
swiftyboi006
I very much doubt the icv but it could be the tps not knowing how much stick ur giving it (throttle position sensor)Does it idle lumpy at all or is idle perfect? ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
pebbles167
Seasoned Pro Location: Melksham. Wiltshire. Registered: 08 Dec 2009 Posts: 2,516 Status: Offline |
Unplugging the map sensor and plugging it back in won't do a thing if its damaged. You would need to buy a replacement part. My car had a hesitation issue that was intermittent but frequent all the way through the rev range, almost as if you were to gun the accelerator and kick the clutch every second or so. Turned out tot be the map sensor, new one is around £20 - £40 depending on brands and location of purchase. And the icv can cause problems with hesitation too. Try taking both sensors off. Soaking them in carb cleaner (or something similar) and cleaning them with rag. Don't worry about covering up the electrical connections as they will be fine, sometimes this works but generally a new part is always preferred.________________________________________ 2005 Peugeot 206 GTI 1802008 BMW K1200R |
daddy5times
Yes swifty idle is perfect .as I set off it hesitates for a sec then gets going like it doesn't wanna go any faster .there's no peticular speed it does it at can be anywhere but always does it as I set off at lights etc thx |
daddy5times
I'll take sensors off now and give em a bit of a clean with wd40 I ll post back results later and thx all |
daddy5times
Tried cleaning map sensor but still the same .chap who fit my thermostat has just said he only filled it up with water !!!no antifreeze silly question but could that have anything to do with it holding back?????? |
daddy5times
It's like it's missing when I accelarate but then sometimes picks up when I ease off sometimes makes a popping sound from exhaust !!! |
swiftyboi006
Try with a new tps like I said, also coilpacks are now known to be intermittent not sure if they would cause this but you never know. Def try the tps tho as it sounds like this to me________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
daddy5times
Could I not 1st try cleaning the 1 that's on ? When I took throttle off there was no gasket . Should there be 1 ?? |
There should be a throttle body gasket yeah.That pipe with a split, replace it. could be completely unrelated, but should be replaced anyway. ________________________________________ ![]() |
daddy5times
Just noticed wires that go to lambA are joined and taped up could it be there not done right? |
swiftyboi006
Also double chrck fuse box________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
daddy5times
guys where abouts is tps??? |
ryangti6
Seasoned Pro Location: Pontypool Registered: 01 Sep 2006 Posts: 1,839 Status: Offline |
On the throttle body, it's the big white/cream sensor.Have you taken the plugs out? If not that would be where I'd start, check general condition and also note what colour they are and if any stand out as looking different etc as this can usually show you where the problem lies. If it's as bad as you say though I'll go with fuel pump dying rather than a sensor problem. ________________________________________ Ryan |
daddy5times
Yes pal all plugs look same kinda light brownish colour |
daddy5times
Just been to look at plugs again and 3look good 1is covered in a crusty matter that I can pick off with my thumb and is a different colour to the rest .uuummmmm plugs coil ? |
