Author Subject: crank and bottom end
both of which are worn and will need work. good if you are planning on larger pistons and new larger bearings bottom end free to collect crank 20pounds
Posted 16th Sep 2011 at 21:54
mikebee
have you got the plate that goes on the sump at the crank pulley end with the slot in for the timing pin? some idiot has tried starting the engine on mine with the timing pin in the crank pulley and broken the slot......
Posted 17th Sep 2011 at 09:55
the end that slides in yeap with the two seals yeap
Posted 17th Sep 2011 at 11:26
mikebee
YHPM :-)
Posted 18th Sep 2011 at 22:30
pm'd back
Posted 19th Sep 2011 at 13:32
