. Worst case would be the leg of the coilover is crushed/ bent. Anyone any idea? Oh and it bloody clatters over the bumps even though the pinch bolt is tight .________________________________________
team: Stealth
| Author | Subject: Suspension leg not sitting straight in the hub. |
eddiebeano
Senior User Location: Edinburgh Registered: 31 Dec 2008 Posts: 715 Status: Offline |
Hi all I'm having a bit of a problem now I've fitted my coilovers, I can't get the leg to stay straight meaning the hub sits wonky against the coilover leg. This is giving me neg camber and messing with the steering. Is there a chance the hub is fooked? The leg isn't a tight fit against the hub anymore, hence is lies at an angle, as in this pic . Worst case would be the leg of the coilover is crushed/ bent. Anyone any idea? Oh and it bloody clatters over the bumps even though the pinch bolt is tight .________________________________________ team: Stealth |
Rich E
The damper and the hub are probably both damaged. You will need to dismantle and inspect to confirm though.________________________________________ Rich |
fatlapit
ovalised the hub maybe?________________________________________ |
eddiebeano
If you mean the ball joint hole then I dot see how this would cause the leg to sit wonky. Can the hub holes deform?________________________________________ team: Stealth |
fatlapit
no the hole which the bottom of the shock sits in could be oval________________________________________ |
Rich E
No he means the damper clamp, which is basically just a big version of the balljoint clamp, and could theoretically be ovaled in the same way (though it would require more force to do it).edit: As above ![]() ________________________________________ Rich |
Seasoned Pro Location: Reading/parts for sale Registered: 21 Nov 2008 Posts: 4,311 Status: Offline |
i had this with my spax coilovers.....put some b8s on a tada sorted.i think its due to the coilovers being slightly smaller width wise ________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
not likely for the strut clamp to be damaged, though the bottom of the struts can be bent surprisingly easily.might have a pic of my brothers strut, it was very fooked, but a replacement damper slid straight in fine. that bolt looks a tad rusty though, I'd replace that and see if the bottom of the strut is not damaged. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
eddiebeano
The plan is to take the strut out on Friday and inspect it, then try another hub. I have new bolts on order from Peugeot, see if that helps. I only have this issue on the left though :s________________________________________ team: Stealth |
welshpug! wrote: not likely for the strut clamp to be damaged, though the bottom of the struts can be bent surprisingly easily. might have a pic of my brothers strut, it was very fooked, but a replacement damper slid straight in fine. that bolt looks a tad rusty though, I'd replace that and see if the bottom of the strut is not damaged. I've got 2 of these bolts, I couldn't get them out of my hubs to replace. ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
eddiebeano
ok so i have better pics![]() ![]() ![]() ![]() ![]() ![]() ![]() what do you think? ________________________________________ team: Stealth |
looks a bit nadgered,________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
fatlapit
^^^^^^^^^^^^^+1 ________________________________________ |
what brand are they? most you can get new bodies, if they're decent ones and used its probably worth getting both serviced.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
eddiebeano
D2, aka Ksport, aka xyz ( supposedly). d2 and ksport no longer have uk dealerships. I rang xyz and they were able to offer me a replacement lower leg for 100 from taiwan, however they weren't sure it would fit and offered no returns.________________________________________ team: Stealth |
JWP EFi
s**t that looks knackered, i will dig out my spare hub later tonight, wont take long to change it overbtw, did you have any issues when you had the original shock on? |
