Compomotive THs 15x7 group A fittment, they're et 32 but are complete with 16mm hubcentric spacers and a full set of wheel studs and group A conversion nuts. They're powder coated in Matt black and fitted with toyo t1rs in 195/50/15. Two tyres are on the wear markers the other two have around 4mm of tread.
3 of the wheels are 'mint' the other has some curbing and the powder coating has lifted a little. The bad one either needs touching up or if you were fussy you could have it re-coated, I've run it as is for a good while though as it never bothered me. £250 pictures to follow at the weekend.
306 2.0 xsi (xu10j4r) open ecu.£25 delivered
New Plastic t/stat take off. £8 delivered
Alloy rear beam mounts. £8 a pair delivered
2.5" coil springs, 300lb x 8". £35 delivered
2.5" coil springs, 500lb x 180mm. £35 delivered
1 x 205 manual steering racks and lower columns, no play in arms. As seen in pics it has overspray on the lower column so will need a bit of a clean. £20
If I haven't mentioned delivery with the price please ask for a quote. Offers considered on everything!
Cheers, Allan
allanallen
Project thread
175.8BHP SCA Norwich
