Author Subject: Beam bits
Got some Xsara VTS beam bits here from one which was disassembled to make use of the trailing arms, calipers and ARB for a 309 beam I'm fitting to my 205. Had covered 77k.
Beam tube. Good condition inside. Bearings remain inside although would need replacing. One of the cups the torsion bar screws though is missing. £30
Beam mounts. 2 studded top mounts which affix through boot floor. Ideal to make into solid items. £10 pair
Shock absorber brackets. £10 pair
Rear shock absorbers (2332's) in good condition £10 pair
All prices are plus postage. Collection welcome.
21mm bars may be available shortly. I beat one out with a drift which marked the end so thats been retapped. I want to get it back and check it over before offering the pair for sale.
As mentioned the arms, calipers and ARB aren't available
  • Posted 11th Mar 2013 at 20:47
    jord294
    Interested in tube and shocker brackets.
    Could you take pic of ends of tube and were brakelines fix into the shocker brackets please?
    Ta muchly
    Posted 11th Mar 2013 at 21:10
    No problem. Will sort some out for you tomorrow.
  • Posted 11th Mar 2013 at 21:13
    jord294
    any more on this
    Posted 17th Mar 2013 at 17:34
    Let me know which tb is ruined if it is because I have a good and a ruined one :-) together we can sort someone out maybe.
    Hovis
    Posted 17th Mar 2013 at 20:00
    Beam tube sold to jord294 (being collected tomorrow as discussed)
    Hovis - I haven't got around to collecting the TB's yet, but apparently it's been saved. Will let you know if that isn't the case.
  • Posted 21st Mar 2013 at 17:04
