displaying posts 76 to 100 of 156
Pages (7): first .. 3 [4] 5 .. last
Author Subject: achieving 200 bhp
markylee
Post #76
blandy wrote:
Cheaper at that cost if doing youself but not less work. Can you map the standard ecu to suit though or would you need standalone ecu
Yeah maybe not less work but in my opinion more straigght forward. Have no idea about ecu, hopefully someone will tell us
Posted 27th Mar 2013 at 21:25
markylee
Post #77
Also will it be worth doing a rebore and head skimmed
Posted 27th Mar 2013 at 21:35
rallyeash
Post #78
As on my reply before yours yes you can remap your sci, chip wizards do this
309 3dr K20 Type R
markylee
Post #79
Cheers mate what do you think about a rebore and head skim
Posted 27th Mar 2013 at 21:37
rallyeash
Post #80
88mm crank with S16 pistons will give you 50cc more anyway in a completely standard block. I would bother with head work just a set of cams.
309 3dr K20 Type R
Posted 27th Mar 2013 at 21:45
markylee
Post #81
88mm crank, is that a completely new crank anwhere can i buy from, and the pistons
Posted 27th Mar 2013 at 21:52
markylee
Post #82
Ok I'm making a parts list, any help on where I can get the parts please
88mm crank
s16 pistons
cams(what cams and where can I get them)
Posted 27th Mar 2013 at 22:19
rallyeash
Post #83
88mm crank is found in the 1.9td engines.
I'm running 109 catcams in my gti6 engine, these are a standard fit for the head
309 3dr K20 Type R
Posted 27th Mar 2013 at 22:26
markylee
Post #84
Cheers mate, would never had dreamed of getting a crank from a 1.9td
Posted 27th Mar 2013 at 22:29
blandy
Post #85
What kind of costs involved in doing a 2.1 engine build with labour etc
rallyeash
Post #86
Mine...
87mm forge pistons and custome steel rods £1200
88mm crank inc polish £150
Block bored to 87mm £100
Cams £500
Vernier pulleys £200
Jenveys, inlet, trumpets, linkage £1,000
DTA ecu £500
Loom (I had the whole car custom wired from scratch £1,000
Arp bolts, bearings, 16 new valves, springs, head work, everything to build a new engine,assembled etc by Sandy brown. £ Can't remember!
That gave me 230hp, 2088cc in a 740kg 205 :-)
309 3dr K20 Type R
Posted 27th Mar 2013 at 22:55
rallyeash
Post #87
But I recon you could do
88mm crank £100
S16 rods and pistons £50
Bored block £100
Pocket machined pistons £100
Rebuild stuff £200
309 3dr K20 Type R
Posted 27th Mar 2013 at 22:59
blandy
Post #88
Thanks gives a kinda rough idea lol already on jenveys so just engine work next
blandy
Post #89
Out of interest why do people not go the extra to forged pistons whilst its apart or are they just not necessary?
Posted 27th Mar 2013 at 23:01
Post #90
I wouldnt use s16 pistons, very heavy and most will be worn out these days, also attached to short rods.
Personally i would get some pistons made to work with bushed gti6 rods, longer rod so less side thrust loads and mean a lighter piston.
jeffers Forum Admin
Post #91
markylee wrote:
jeffers wrote:
stan_306gti6 wrote:
You could always go for some bike throttle bodies, 'Peugeot96' on here is doing this at the moment. It will be a lot cheaper than going down the Jenvey route, especially if you fabricate some parts yourself.
I'm mid doing this exact thing along with my new engine build.... Which reminds me I must update my project thread...... Big grin
Have you got a link to your thread, I'd be interested in copying er I mean seeing what you've done
I'm waiting on some adapter plates being machined up to fit the bodies on so as there's no silicone hoses required. Once I get them back hopefully next week sometime il post some pictures up so u can see how I'm doing it. It's an experiment at the end of the day, the engine is being build regardless of the bodies, if I can make the bodies work il be really happy!
Team Running Engine again!
Team Negative Camber!
Posted 27th Mar 2013 at 23:52
Project D
Post #92
Project D wrote:
I have spend lot's sleepless nights and reading horror stories about cams and skimmed heads. I ordered Newman PH2 camshaft and i want to know will they fit unskimmed head?? Car is GTi-6.
Can somebody answer my question. Pistons are standard and head is unskimmed.
Posted 28th Mar 2013 at 11:22
Post #93
yes Yes
Posted 28th Mar 2013 at 11:44
beez_neez_gt
Post #94
Start a thread on the subject then.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 28th Mar 2013 at 12:37
Post #95
Have you tried asking Newmans?
Posted 28th Mar 2013 at 14:39
Post #96
PH2's have half a mil less lift at tdc than pt80/81, so as long as you can guarantee its not been skimmed you'll be ok.
Posted 28th Mar 2013 at 14:48
Post #97
AND only if timed correctly.
Posted 28th Mar 2013 at 14:50
Post #98
yes, of course Smile
Posted 28th Mar 2013 at 14:53
Project D
Post #99
OK... that nice to know. Smile
I have e-mailed to newman, let's see what he respond.
Posted 28th Mar 2013 at 17:37
Post #100
Have you had your peter T's from paul yet? I love mine :-) timing them was fun tho
Posted 28th Mar 2013 at 19:22
