displaying posts 26 to 50 of 63
Pages (3): 1 [2] 3
Author Subject: misfire
RetroPug
I'd say probably TPS but that's still just a guess.
Posted 8th Jul 2014 at 19:30
Coolant temp sensor is part number 1920K9 from pug
Posted 8th Jul 2014 at 19:42
Check the air temp sensor as well
Posted 8th Jul 2014 at 19:43
woody.
Have you checked the lambda sensor? That would send your fuel usage sky high if it's buggered.
Also, have you tested the coilpacks?
Posted 8th Jul 2014 at 19:46
3gan
really appreciate all your help lads
stressed as hell
would the coil packs break down under full load?
any members in or near Bristol
I like fast cars, but fixing them is not something I am good at unfortunately
I will get a multimeter this week and start checking everything
but my preference is to change parts :-(
can't really drive it to a garage it's not driveable
and got worse
I could spend hundreds buying parts which is what I normally do and end up spending out when I didn't need to
contemplating lumping it to peugeot
I have had the same in the evo with coil packs but under heavy load
if I drive it hard or rev it it it clears until normal steady driving
Posted 8th Jul 2014 at 19:52
edhunter
There is low probability that you have failing coil. This engine have separate coil for each cylinder. You can try unplug/plug coils one by one and see which one will not make any difference (will not cause additional misfirings) - this is the failed one.
Posted 8th Jul 2014 at 20:01
Not coil packs
Try unplugging the power steering sensor - front of the engine on the power steering line
3gan
will I get a poke unplugging the coil packs?
as to the power steering sensor can I please ask why that could be a factor
Posted 8th Jul 2014 at 20:03
edhunter
No Smile. The high voltage is at the "bottom end" of the coil pack. You will unplug the upper white sockets - there the voltage is low.
Posted 8th Jul 2014 at 20:17
3gan
Post #35
you think it can be cool packs?
I have a local guy coming round tomorrow with his gti6
will swap some sensors around if its dry :-)
maybe cool packs
then water temp sensor
then air temp sensor
then map sensor
anything else?
Posted 8th Jul 2014 at 21:27
3gan
Post #36
just found this thread very similar symptoms and he fixed it
http://www.306gti6.com/forum/showthread.php?id=147156
Posted 8th Jul 2014 at 21:29
3gan
Post #37
map sensor
Posted 8th Jul 2014 at 21:30
Post #38
Jon? If you ever need anything drop me a PM as i've got most stuff in the garage and i'm just up the road... Thumbs up
Posted 8th Jul 2014 at 22:06
3gan
Post #39
was that for me buddy?
it's lee mate
if it was that's awesome I could pop up in the evo but the pug is just not driveable
unless I cover your fuel etc and parts supplied etc
Posted 8th Jul 2014 at 22:12
Post #40
It feeds a single to the ecu to up the revs when under load ie turning left or right - when it plays up it can cause odd running Yes
Have you checked everything is actually plugged in ?
Posted 8th Jul 2014 at 22:38
3gan
Post #41
ok worth a try nothing to lose
many thanks
Posted 8th Jul 2014 at 23:00
3gan
Post #42
I have had fuel
filter changes
from original metal unit to a smaller plastic unit
yes I have checked the flow direction
could this be an issue?
I'll post up any findings tomorrow
Posted 8th Jul 2014 at 23:59
3gan
Post #43
No chance to try and fix last night miss got rushed in hospital
Will update soon peeps
Posted 10th Jul 2014 at 10:54
RetroPug
Post #44
Oh dear, I hope she's okay.
Posted 10th Jul 2014 at 12:13
3gan
Post #45
miss's had CT scan
lumber puncture etc drained 20mls fluid
pressure was 38 in spine average is 13 to 26
gauge only went up to 40!
home waiting new tests eyesight much better thank heavens!
into the pug
just drive it seems ok but Boggs down not as bad
so sensor as link don't seem right
keeping the plug clip on the top I get no reading with 3 and earth
only 1 and earth and get 5v
not tried it connected and revving yet
see link below please
map sensor could still be fooked tho
all other tests seem fine
any ideas how to check the map sensor please?
Posted 12th Jul 2014 at 16:04
3gan
Posted 12th Jul 2014 at 16:12
3gan
Post #47
also have a spare plug by map sensor coming from same loom purple insert?
nothing to do with it I am sure
Posted 12th Jul 2014 at 16:29
RetroPug
Post #48
There are a few spare plugs around that area, but check that the Inlet Air Temperature sensor is plugged in:
http://www.306gti6.com/forum/showthread.php?id=20477
Definitely try someone else's TPS and CTS if you can. After you replace the CTS you can bleed just the thermostat housing by opening the bleed screw and blowing in the tube on the expansion tank. Coolant will come out the stat screw and you can shut it. Could probably get away with not doing that but might as well.
Posted 12th Jul 2014 at 19:12
3gan
Post #49
yes mate plugged in for sure
if only it was that easy
Posted 12th Jul 2014 at 19:13
RetroPug
Post #50
If the sensors in that picture are all plugged in then it is a spare. There are a a fair few kicking around just to confuse you. Laugh my ass off
My money's on the TPS.
Posted 12th Jul 2014 at 19:20
Pages (3): 1 [2] 3
