displaying posts 51 to 63 of 63
Pages (3): 1 2 [3]
Author Subject: misfire
3gan
Post #51
pardon me for being thick
what's the TPS throttle position sensor?
if so where is that? is it the sensor not in the pic mounted into the throttle body?
Posted 12th Jul 2014 at 19:24
Post #52
Tps is under Neath the throttle body, air temp sensor is a small grey sensor on the back of the throttle body
Posted 12th Jul 2014 at 22:42
3gan
Post #53
so what is at the side of the throttle body?
facing the front of the car
throttle heater? or is mine just mounted different?
Posted 12th Jul 2014 at 22:53
RetroPug
Post #54
Yes throttle body heater is the yellow thing on the front. That won't affect running really, only useful on very cold winter mornings.
TPS is Throttle Position Sensor, on the bottom of the throttle body. Should be able to feel it if you stick your hand under.
Posted 12th Jul 2014 at 23:17
Post #55
Yellow thing ? Has something to do with fuel vapour I think but it does not a lot in my eyes
3gan
Post #56
I have read up tons of threads
tested what I think are all ok sensors
anyone recommend a lambda please as I think it could either be that
or map
sensor :-)
Posted 13th Jul 2014 at 00:52
3gan
Post #57
Ok people update
Friend coming round later with diagnostic equipment
Took for a spin was almost like it was overfueling and missing then picking up as you accelerate, had a short run then trip on motorway gritted teeth lol
So seems ok when on full chat, makes me think lambda as its getting very hot then and not functioning well when just part throttle when its cooler
Place your bets
Posted 13th Jul 2014 at 16:00
3gan
Post #58
question for you guys
if my lambda was faulty would it trigger the engine management light?
could it be a bad earth somewhere?
cheers
lee
Posted 14th Jul 2014 at 12:35
3gan
Post #59
update people
tried the link below and have 5v at the plug
but when wiring it up and testing the map sensor using the 3 wires it's staying at around 5v
there is no voltage change
so I guess this is the problem
my sensor does not react anything like the video have ordered a second hand one
see what happens if it works I'll post up
cheers
lee
http://www.pugaddicts.co.uk/2014/02/map-sensor-testing-with-a-multimeter.html?m=1
Posted 14th Jul 2014 at 18:57
Post #60
I'm now going to test mine & The Lambda sensor ...just in case ...do have some tick over probs sometimes ....good info Thumbs up
Posted 16th Jul 2014 at 23:11
3gan
Post #61
let me know how you get on
sounds like yours in throttle position sensor
Posted 17th Jul 2014 at 00:13
3gan
Post #62
ok new Bosch sensor fitted
when cold or just started when warm drives fine
then after a couple mins Boggs down again
anyone have any ideas
water temp sensor? air temp sensor?
Posted 17th Jul 2014 at 18:23
3gan
Post #63
No more misfire
Lambda sensor was faulty!
So if you get similar symptoms unplug it and if its no good the car will drive fine
Posted 20th Jul 2014 at 17:38
Pages (3): 1 2 [3]
