displaying posts 226 to 250 of 3424
Pages (137): first .. 9 [10] 11 .. last
Post #226
aaron6 wrote:
I've just got a 16 row mocal. Looks okay tbf. Hopefully it'll be alright.
Mine was ok for 18months Thumbs up
Did loads of tiding up on the car yesterday !
I'll take some pics later ....
Below is my new Throttle cable linkage ...no plastic snappy snappy white plastic clip anymore Whistle
Posted 21st Mar 2016 at 07:27
RetroPug
Post #227
Day666 wrote:
RetroPug wrote:
Personally I'd have debadged but FG bonnet is awesome! Want one for mine.
I would if I was your age 24 LOL
One of the reasons I'm not is because all you youngsters do Whistle
Says the bloke who has deliberately gotten rid of just about every creature comfort in already rattly old french car. LOL
Looking forward to seeing this in action.
Posted 21st Mar 2016 at 09:12
cj-gti6
Post #228
LOL LOL LOL
99/S Carbon Gti-5
Posted 21st Mar 2016 at 09:49
Post #229
Nooo your not getting what I'm saying LOL
The bonnet smoothing is for the youngsters ....the comforts arnt needed & weigh to much Crazy
Posted 21st Mar 2016 at 11:02
Post #230
Nooo Luke ...your not getting what I'm saying LOL
Your a young one .....I've got shoes older than you LOL
Don't wear them anymore though LOL
I really can't wait either Luke ....
I'm trying to get it ready for two weeks time ...hoping ?
Posted 21st Mar 2016 at 11:07
Post #231
Well at last ...some good news ...finished fitting the pump relay tonight & started the old girl up & hey presto ...everything works great & no Petrol leaks or Vapour / fumes Thumbs up
At last I'm getting somewhere....the new swirl pot / pump is surprisingly quite & once it's all covered in its Safty cover box I'm having made I don't think you'll hear it more than the Standard pump ....
Bit of wire tiding tomorrow night & then fitting the new Satchel shift boot & clamp I've made ....
Hopefully the gearbox & Helix clutch / helix pressure plate & Lightened flywheel & Crank seal + Rich W roller bearing bottom arms & modified Clutch cable May be fitted Friday ???
Plus All competition Vibra Technics top mount & gearbox mount ...
Also a amazing find.... thanks to Miles a cast Alloy complete top mount inc the main engine mount this bit coming Thursday/-----saving 10kgs on the cast iron standard ,.... these are Rocking Horse S-it to get ...
Picture of just the top part below...
I'm then running a half size Alternator on a ajustable arm ...less weight again & I don't have much electric stuff on the car now Thumbs up
Picture below is of the half of top mount bit off a 8v old turbo Citreon engine ?
Engine fixing bit arriving Thurs as I've said already
I'm sure Welshpug will know which one ..Thumbs up
Posted 21st Mar 2016 at 21:57
Cjwatson27
Post #232
At 33 it's been i while since I've been referred to has a youngster Thumbs up
Posted 21st Mar 2016 at 22:05
RetroPug
Post #233
Plenty of people on here have cars older than me. LOL
Posted 21st Mar 2016 at 22:09
Post #234
Godspeed did a unreal job of my (v6 406 ) Brembos for my 306 /330mm Ashs rotors & bells ...total refurb & found a sticking piston that was pitted ..can't recommend Ben & Ian enough & amazing turn around ..
Posted 22nd Mar 2016 at 14:42
Post #235
Pitted Piston that was sticking slightly & being lazy ...exchanged For a new one .
Was told the Pistons are hard anodised (alloy) & never normally need any replacing ?
Ones not to bad though Thumbs up
Posted 22nd Mar 2016 at 19:46
Post #236
yeah, good lads up there, not too far from where you were earlier in the week LOL
best turnaround we had was 3 hours Wink
Posted 22nd Mar 2016 at 15:02
Post #237
Mei such good lads & know there stuff ...Ians Clio with Satchell everything is rather nice .....round the corner which was handy LOL
3 days was impressive Thumbs up
Posted 22nd Mar 2016 at 15:11
Post #238
Made a new two ring Stainless brackets / plus Satchell boot...:I fitted the bottom ring which I welded threaded bolts to & then bonded that ring to the floor with my windscreen bond ....then I could work 100% inside ..
The top Stainless ring is holding the base of the boot by clamping it down & I used a Full CV boot because with the old short boot pressure was put on the rod & it didn't feel free & easy as it is now Soo flexible Thumbs up
Posted 23rd Mar 2016 at 07:15
Post #239
Cut some 1.2mm Stainless plate to size & used slither disc to carefully cut out two slots .
Then I bonded the plate to the outside of the Carbon fibre with my two pack Epoxy bond & used two alloy box section one each side to clamp it for two hours ...
Took it out of clamps & then lite sanded the Stainless ....it feels better than new & now feels spring loaded & seals better Whistle
Posted 23rd Mar 2016 at 07:17
Post #240
Guess what I'm going to be doing this weekend?
Only the Drivers seat at mo Whistle
And yes ...CDS proper steel off Motorsport.tools.com
Hopefully going to give myself 2inchs more headroom ?....hopefully LOL
Posted 23rd Mar 2016 at 17:38
Post #241
about £3 of steel there, but makes a world of difference Big grin
Posted 23rd Mar 2016 at 12:55
Post #242
With captive nuts ?....£6.50 LOL
Posted 23rd Mar 2016 at 13:02
Post #243
Well yesterday was a long busy fit & do as much as you can day Thumbs up
Old box off & 3J plate diff out & replace my old Crownwheel to match my new Pinion in my Refurbed by (Miles) box ...now has 6speeds with 4.75 final drive = should give with 16s 50series -128 topping out in 6th ?
Had to file down a lump again as the 3j was just hitting the main casing ....
Posted 26th Mar 2016 at 06:52
Post #244
Then put my shiny new RichW flywheel on after changing the crank end seal ...
New Gen bolts fitted & torqued & cleaned with chemical spirit cleaner
Posted 26th Mar 2016 at 06:54
Post #245
Helix 4 paddle Sprung clutch & Helix pressure plate fitted
Posted 26th Mar 2016 at 06:58
Post #246
New (non) automatic / manual clutch cable made by Speedy cables in Wales fitted ...has metal ends to limit breakages ?
New VibroTechnics competition gearbox mount fitted ..amazing quality
RichW roller bearing bottom arms fitted & greased well
In the process a couple of small issues found = PAS RichW modded pipe needed tightening was weeping ..
Main problem which has to be sorted is a Spoox hose adaption Picture below has been leaking when moved slightly...it's probably the O ring but I want to ditch it
Posted 26th Mar 2016 at 07:13
Post #247
As you guys know it fits into here Picture below ...its to many possible Probs know mines leaking
Posted 26th Mar 2016 at 07:14
Post #248
I'm seeing if this will work ?
Not a massive problem really considering what could of gone wrong LOL
A small hiccup let's say ...
Posted 26th Mar 2016 at 07:17
Post #249
Been a busy boy Damien!
Now that I'm pugless I'll have to catch up and you can take me out in the 306 to keep the love going Wink
Posted 26th Mar 2016 at 07:19
Post #250
Then drained my engine oil & fitted a new oil filter & Millers Nano drive full Synthetic Race oil ...closest they make is 10w 50 which came out top in recent Tests LOL
I've been using this for the last 12months seems good but bit expensive not in the Royal Purple price range than God Crazy
Posted 26th Mar 2016 at 07:25
