It was flexing far to much so I sorted that little issue ...
The Black is my work
I'll have it back from the sprayers before next Friday
| Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Post #201
The bonnet wasent bonded at the Stut point along the whole length both sides It was flexing far to much so I sorted that little issue ... The Black is my work I'll have it back from the sprayers before next Friday Day666 has attached the following image: |
Post #202
Don't think Red looks to great on Silver I didn't want to cut the bonnet & I wanted my Badge still so I just bolted it to my mesh grill Can see enough to know it's there I've also drilled loads of holes in the Hex pattern...how sad am I I've covered both camps ...smooth bonnet but have badge .... It looks stupid at mo !.....wait till the bonnets Silver Day666 has attached the following image: |
cj-gti6
Senior User Location: Barnsley Registered: 09 May 2011 Posts: 799 Status: Offline |
Post #203
Nice!________________________________________ 99/S Carbon Gti-5 |
Post #204
You have issues mate! Coming along nicely dude,gonna be a proper weapon once it's completed |
Robdog Rallye
Junior User Location: Devizes Registered: 03 Dec 2014 Posts: 55 Status: Offline |
Post #205
Looking good mate ________________________________________ Low boost RallyeRB182 Cup |
Chr1sch
Seasoned Pro Location: Worcester Registered: 02 Aug 2014 Posts: 1,025 Status: Offline |
Post #206
I have to say it looks awesome dude! Lick of paint and it's going to be quite something! |
RetroPug
Post #207
Personally I'd have debadged but FG bonnet is awesome! Want one for mine.________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
Post #208
Robdog Rallye wrote: Looking good mate Yes but no how much it cost How's your Car Now Robbie ??? |
Post #209
Chr1sch wrote: I have to say it looks awesome dude! Lick of paint and it's going to be quite something! Thank you Chris I'm working on it nearly every night & Sat / Sun days 👍 |
Post #210
RetroPug wrote: Personally I'd have debadged but FG bonnet is awesome! Want one for mine. I would if I was your age 24 One of the reasons I'm not is because all you youngsters do |
Post #211
Hoping Ash thank you m8& I definitely do have plenty of issues m8 .... Thank you Chris W Today ...Reversed the Jenvey throttle linkage with half the length shorter new cable Day666 has attached the following image: |
Post #212
This Ones for Welshpug / Mei You might recognise my new throttle cable ? Brilliant quality & Ptfe lined & I used Shimano cable white nano technology grease so say it's £45 for a stupid little pot Handy when your m8 owns a bike shop ... Have made & fitted a metal linkage on cable to Pedal now instead of those stupid plastic things ... So easy to push & soooo smooth now ...also cut a few coils off linkage return Spring ....WHAT a difference Day666 has attached the following image: |
Post #213
Sadly my Carbon Fibre Airfilter surround is cracked ....im not impressed with Carbon Fibre at this present time ...it was bloody expensive to ...I'll mend it with some thin alloy & bond it to the back Day666 has attached the following image: |
Post #214
£45?! ![]() it is slippery s**t isn't it! no linkage on mine, I use a custom bracket, a v-brake noodle and a direct pull throttle lever. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #215
My 16 row Mocal oil cooler has started to drip & leak when thermostat opens & it gets warm ....so I bought a better quality Setrab ...Merlin said they have had Mocal quality issues but never A Setrab ?At the same time I fitted my open circuit NON thermostat Sandwich plate I had for a while Day666 has attached the following image: |
Post #216
welshpug! wrote: £45?! ![]() it is slippery s**t isn't it! no linkage on mine, I use a custom bracket, a v-brake noodle and a direct pull throttle lever. That Madison for you Mei !!!! Crazy slippery stuff ....goes like water ...weird Got a picture Mei ? |
Post #217
Oil cooler fitted on two special flexible arms instead of rubber bobbins to stop vibrating & vibrations cracking it & sandwich plate fitted now ...hoping for cooler oil now ...just have to warm the car up more before using It's the little things that add up to a lot Day666 has attached the following image: |
Post #218
![]() ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #219
Mei looks nice & simple m8 ....good on you ...Like the old AD990 BMX rear brake set up |
Post #220
Took another look at my cracked Air filter inlet box ....I'm thinking how can it be cracked ?Really p**sed off that all it does is hold the pressure of a bloody air filter ....how Rubbish is that ? Bottom R/H corner it's cracked I'm wondering if it's faulty ? Day666 has attached the following image: |
Post #223
Day666 wrote: My 16 row Mocal oil cooler has started to drip & leak when thermostat opens & it gets warm ....so I bought a better quality Setrab ...Merlin said they have had Mocal quality issues but never A Setrab ? At the same time I fitted my open circuit NON thermostat Sandwich plate I had for a while This...... I fitted a brand new 16 row mocal to 3rd timelucky's supercharged phase 1 and a month later it was weeping from the middle of the core somewhere! We assumed it was from a stone at first but after washing it out with brake cleaner then running till warm it was clear it was leaking from the middle of the centre of the core somewhere in its deaths.... I've got a setrab on mine been there 3 years open to the elements without any form of grille in front and it's been perfect. ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
Post #224
armzsc6 wrote: Day666 wrote: My 16 row Mocal oil cooler has started to drip & leak when thermostat opens & it gets warm ....so I bought a better quality Setrab ...Merlin said they have had Mocal quality issues but never A Setrab ? At the same time I fitted my open circuit NON thermostat Sandwich plate I had for a while This...... I fitted a brand new 16 row mocal to 3rd timelucky's supercharged phase 1 and a month later it was weeping from the middle of the core somewhere! We assumed it was from a stone at first but after washing it out with brake cleaner then running till warm it was clear it was leaking from the middle of the centre of the core somewhere in its deaths.... I've got a setrab on mine been there 3 years open to the elements without any form of grille in front and it's been perfect. I can believe that Pete....Merlin Motorsport said the Quality Control of Mocal stuff is shocking ! They showed me a New 16row Mocal they had delivered & it looked like Steve Wonder had made it |
aaron6
Post #225
I've just got a 16 row mocal. Looks okay tbf. Hopefully it'll be alright. ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
