displaying posts 176 to 200 of 3424
Pages (137): first .. 7 [8] 9 .. last
Post #176
demondriverdan wrote:
I took a bit of copper pipe with a union then crushed the end down Big grin Probably should get some proper blanking plugs at some point though
That's what I was doing Thumbs up
Posted 13th Mar 2016 at 19:38
Post #177
Nearly there with the Fuel pipes ...
Got to now switch the Jenvey linkage to other side & cut 18inches off the outer & inner cable
Posted 15th Mar 2016 at 20:44
Post #178
Battery cables need tiding up & New fuel pipes clipping up...
A box will be covering all the Swirl & pump / filter for Safty Thumbs up
Posted 15th Mar 2016 at 20:50
Post #179
Alloy checker plate rubber mounted ...
Posted 15th Mar 2016 at 20:51
Post #180
Just needs a vac out now ...fuel pump rubber bobbin mounted
superchargedblack1997gti6
Post #181
Make sure you get you're fueling readjusted after you've changed all that mate? Can make a big difference if guess you'll be running rich now Smile
Posted 15th Mar 2016 at 20:53
Twangy
Post #182
nice to see this coming together damien , you will soon have this done the way your going , keep up the good work mate
wayne mcardle
Posted 15th Mar 2016 at 21:09
Post #183
Was told because I'm using the same setup ...EG same FPR ...even though I'm increasing the flow it should be fine ...I was pumping in more fuel than needed before ?
I know what your saying Ross Thumbs up
I think Mei had issues when his pump was playing up & he had it mapped ?
Posted 15th Mar 2016 at 22:22
Post #184
Thank you Wayne ...it's getting there now thank god !!
Your door panels look amazing Thumbs up
Posted 15th Mar 2016 at 22:27
Post #185
yeah, my pump died after mapping, so it really needed another session to tidy it up, oddly it never ran lean on the RR but the flow must have been down as it was markedly different on the new pumps.
if your old pump was good, and youre on the same FPR it should be fine, so yeah no issues there, easy to keep an eye on it with a wideband, it wouldnt need a full map with sandy anyway, trimming the fuel with no other changes to the spec wont take too long
Posted 15th Mar 2016 at 22:30
Post #186
Fingers Crossed Mei ...how's the new engine coming along ?
Post #187
waiting for pay day and house move!
Posted 15th Mar 2016 at 22:31
Post #188
Yes I'd say you'd need the map tidying you're fuel pressure will be the same but I'd say that the flow will have changed it'll move more fuel. It may be ok but I'd recommend it being looked at before you give it death Smile
Posted 15th Mar 2016 at 22:46
Post #189
If it was flowing enough to keep the regulator at the right pressure before then it'll be the same fuelling now if the pressure is the same.
Posted 15th Mar 2016 at 23:35
RallyeP6
Post #190
It actually looks like you have a space frame just to support the pump and swirl pot, in that picture. Nice work.
Posted 15th Mar 2016 at 23:59
Post #191
Yea it does LOL .....
I'm paranoid about Fire now but didn't plan it like that ...
Posted 16th Mar 2016 at 06:49
Post #192
House Move blimey ....any garage with the new one ?
I take it your going Local still ?
Posted 16th Mar 2016 at 07:40
Post #193
yeah, 3rd move in a very short while, I'm down Bridgend these days, left Cwmcarn end of November!
and yes, awesome workshop space..
Posted 16th Mar 2016 at 07:52
Post #194
Ohh didn't know that ....I'm in Bridgend now (Pyle) working at AMSS
Posted 16th Mar 2016 at 10:04
Post #195
ahh, me and DCC get our MOT's up the very top end of that industrial estate.
Posted 16th Mar 2016 at 10:34
Post #196
Yes I know it Mei /.:.
Just finished my Revised Stainless Steel Satchell shift gator boot ...this one clamps the gator
This one shouldn't tug on the rod at angles now
Used a flexible CV boot
Posted 16th Mar 2016 at 13:25
Post #197
Trial fitted the bonnet I bought yesterday & it's good quality.
No better or worse than any fibreglass bonnet I've seen
The twin skin makes it very ridged.
It's Red gel coated but that's easy sorted ..
The only slight issue I'm unhappy about is where the two bonnet stays fix and when you close it it flexes far to much for my liking So I'm going to bond a couple of strips inside the edges of each side to spread the pressure...Thumbs up
My Aero catches will be fitted the weekend ...
Spray it also & Fit Ashs Water jets
Posted 16th Mar 2016 at 20:28
Post #198
One should never tug on your rod at the wrong angle.
My bonnet is single skin and attached with four catches. It's active at speed shall we say!
Posted 16th Mar 2016 at 21:03
Post #199
Mine has 5 catches and it flaps like a bird above 60 Laugh
Nice updates as always Damien, mind me asking if theres a reason you didnt stick the fuel stuff under the boot floor? Not at all a criticism, just i've seen a few people mount it there.
I stuck mine under the floor as i usually chuck loads of tools and spare wheels in the back of mine for trackdays so i wanted it all out of the way, plus a little extra safety incase theres a leak or anything. Smile
Posted 16th Mar 2016 at 21:22
Post #200
My Battery is sunk deep into the floor leaving no room in between the beam brake lines etc Thumbs up
Would of much preferred it underneath ...
Posted 16th Mar 2016 at 21:50
