Bought them off
http://www.amspeedracing.co.uk/product-detail?cid=&pid=2174
Best quality rod ends I've seen .....same as Satchel use on my shift
| Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Post #276
Well I've received my ajustable Droplinks ...I've had to buy 250-290 because my ARB front damper mount points are 40mm lower than stnd as my dampers have long Eibach ERS springs with helper springs ...250mm should be spot on & let me ajust them 100% for correct position...Bought them off http://www.amspeedracing.co.uk/product-detail?cid=&pid=2174 Best quality rod ends I've seen .....same as Satchel use on my shift Day666 has attached the following image: |
Post #277
Close up of ends Would of bought some PhillipM ones but I needed them quick sadly ...they come with 12.9 bolts & conical spacer ...may of paid £20 over the top ...I'm happy 👍 Day666 has attached the following image: |
Post #278
Just got to order some rubber boots to go over them now from McGill motorsports...... MOT rules |
Post #279
you need a better MOT tester ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #280
welshpug! wrote: you need a better MOT tester ![]() Your so correct on that Mei Hes driving me nuts ....doesn't want to do my car now because of my door bars |
Post #281
definitely take it elsewhere, he doesn't understand modified cars clearly!I would recommend one of our local ones but they're a fair trek from Bristol just for an MOT! ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
demondriverdan
Post #282
Pah, MOT I do have scrutineers though who can be equally annoying. One nearly refused me a pass because I didn't have yellow tape on my negative battery lead. Not sure I've ever heard of that regulation!________________________________________ Rallye Race Car |
Post #283
I've heard of it, its one of the most basic first rules of car prep for competition ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
demondriverdan
Post #284
Strange then that I'd done 7 or 8 races before someone complained I once had the T handle of my battery kill cord come off after I did the test and managed to get the scrutineer not to know!________________________________________ Rallye Race Car |
Post #285
Small update for today ..Got cast alloy Base off Baz T who Mei knows he used to be on here & is a good friend of Miles ....it's to fit my cast alloy top mount Miles had spare Needed a little few bits removing & smoothing & has gone off to be Nickle played the same as the top mount bit has I'm sure Mei will know these are 1.8kgs inc top 1.9kg & you have to use a extra Cast Iron Alternator plate off a 205 Diesal ...& a rose jointed bar to tension the alternator belt .. These 3 items weigh just under 2.00kgs together ..... The cast Iron top mount & base which has Alternator bracket in one piece weighs in at 8.5kgs ...THATS 6.5kgs lighter WOW Plus it's neater & looks amazing ...bonus That's a lot of weight off just with my Bonnet & engine Mount Day666 has attached the following image: |
Post #286
Alternator Bracket below ...needs fitting Day666 has attached the following image: |
Post #287
Standard one below ...people seem to cut bits off to fit Jenveys & ChargersDay666 has attached the following image: |
Post #288
It weighs 8.5kg completely new one just under 2kgs complete Day666 has attached the following image: |
Post #289
Top mount ... posted earlier ...cast alloy to match bottom but has been Nickle plated already That's 21kgs weight saved on a twin skinned bonnet & engine complete mount ....plus my new Smaller Alternator is less than half the weight also Day666 has attached the following image: |
Post #290
How the Cast alloy mount looked before Mr Slither disc & pad file took hold Off I believe a (XM 8v turbo car) ....not Many of those about Day666 has attached the following image: |
Chr1sch
Seasoned Pro Location: Worcester Registered: 02 Aug 2014 Posts: 1,025 Status: Offline |
Post #291
Arrggghh i hate you, i want to do all of this but i just can't spend the money - stoopid houses...Keep up the good work mate, looks awesome. My Fb page constantly has your car on it advertising the French car show or something like that too - i can't escape lol |
Chr1sch
Post #292
Day666 wrote: Just got to order some rubber boots to go over them now from McGill motorsports...... MOT rules I dont have boots on mine!? |
Post #293
Chr1sch wrote: Day666 wrote: Just got to order some rubber boots to go over them now from McGill motorsports...... MOT rules I dont have boots on mine!? As Welshpug rightly said ....find another Tester mines turned into a twat ..that really doesn't want any climbing in over door bars .... I've got 4 coming tomorrow as they are cheap enough & it's one less thing for me to worry about on my Mot I'm always on the track at Combe ...bought like 14 sessions one year I was giving most of the high powered cars a run for there money ....I think they like the Under dog with the standard engine PS I could only do all of this because of my New Girlfriend of 3years who's bought into my house & bought 1/2 in ...paid all my debt off & no credit cards She's put £4K into it also |
demondriverdan
Post #294
I need to get one of those engine mounts! ![]() ________________________________________ Rallye Race Car |
Post #295
demondriverdan wrote: I need to get one of those engine mounts! ![]() I know ...when I saw Miles 2years ago & asked him about them he said if anybody offers him one he will let me know & True to his word ...he rang me 4weeks ago & said he has a spare top & a m8 of his Baz T has the bottom Two years sourcing one & I even joined the XM owners club & asked them ..no joy & that's the truth Wait until tomorrow night & they are Nickle played |
demondriverdan
Post #296
Give up and sell it to me ![]() ________________________________________ Rallye Race Car |
Post #297
demondriverdan wrote: Give up and sell it to me ![]() Give me 12months of the car I'm aware... lots of people lose weight as I have now bonnet / lightened flywheel / etc but engine mount is good one & even I didn't realise that amount of saving ... |
RetroPug
Post #298
Have you weighed it lately Damien? I'm quite interested to see what it would be.________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
Twangy
Senior User Location: heswall Registered: 27 Jun 2014 Posts: 623 Status: Offline |
Post #299
suprising how much weiht saving can be done on these cars damien , picking up some nice bits lately mate , keep up with updates mate , just had a read threw and coming along nicely ________________________________________ wayne mcardle |
Post #300
Twangy wrote: suprising how much weiht saving can be done on these cars damien , picking up some nice bits lately mate , keep up with updates mate , just had a read threw and coming along nicely Thank you Wayne .....you have helped me with your supplied parts & knowledge also m8 |
