displaying posts 301 to 325 of 3424
Pages (137): first .. 12 [13] 14 .. last
Post #301
RetroPug wrote:
Have you weighed it lately Damien? I'm quite interested to see what it would be.
No luke ...but Wil Declaudio (name dropping) LOL ... is corner weighting & setting up my front suspension & looking at my rear suspension hopefully in two weeks ...
Still have all my ABS on working at mo ...I'll strip that out while the engine is out next year hopefully Thumbs up
Posted 31st Mar 2016 at 22:33
Post #302
Both base engine block mount & Altenator mounting bracket have been Nickle played to match the top mount
Nickle plating Cast Alloy is a completely new process
Posted 1st Apr 2016 at 11:29
eddy_gti6
Post #303
So much lighter these mounts, I had them on my old Nile 6. Hard to get hold of, was after one for the van too
Posted 1st Apr 2016 at 12:14
Post #304
I had to buy mine off two different people & paid Good money to the pair of them as they both knew what they had Eddie ....
Posted 1st Apr 2016 at 13:22
6waysforward
Post #305
What mounts are they? Love
Posted 1st Apr 2016 at 18:18
Post #306
Top mounts both Off a Citreon XM 8v Turbo ...according to Miles the only car they came on ?....don't ask me LOL
Bottom Altenator mount off 205 Diesel Thumbs up
Posted 1st Apr 2016 at 18:27
Post #307
not just the turbo, any xu10, but phase 1 only, and you need the top arm frm a 1.9 405 mi16
Posted 1st Apr 2016 at 20:01
Post #308
Blimey thanks Mei Thumbs up
You know of any ?
Posted 2nd Apr 2016 at 08:41
Post #309
You know of any ?
How rare are they really then ?
I don't think BAZ T would mind me showing the picture below its his 205 with 16v engine & one of these mounts fitted minus the top mounts while it's being mended Thumbs up
Posted 2nd Apr 2016 at 08:45
Post #310
Got the Droplink boots fitted with Redline Red HP CV grease packed into them ...not to much LOL
Good old long nose pliers to expand the boot Thumbs up
Posted 2nd Apr 2016 at 20:25
Post #311
Bit of a update ...
Fitted the new 8v turbo XM engine mount & diesel alternator bottom mount by oil filter plus the Mitsubishi /Denso type 40amp Alternator
Only problem is it has a 15mm spindle so I had to order a 15mm X 53mm X 6v belt alloy pulley to fit .
Ordered a 110mm 8mm / twin rose jointed Teflon ajuster .
Second hand new small one below ....loads of room
Posted 5th Apr 2016 at 18:49
Post #312
Used the standard 6 belt & automatic ajuster ....can believe the Altenator weighs 2.2kgs the standard ones 8kgs
Very little room also ...
Old one below
Post #313
New 15mm alloy pulley with 10mm offset
Standard 6 alternator has 17mm shaft
Posted 5th Apr 2016 at 18:54
Post #314
I used this guy from EBay £24 for the 15mm pulley
Posted 5th Apr 2016 at 18:55
Post #315
Little update ...2nd hand Seat has been picked up & looks hardly used Thumbs up
Only problem is he keep the side mounts & it's a Corbeau XL Kevlar/ Carbon Mix not Cobra GT / Carbon as told and sadly wont match my Passenger side ..it's not a show car LOL
Posted 6th Apr 2016 at 13:41
Post #316
Not sure about the Corbeau Kevlar pattern back ?......would of preferred plain Black same as Cobra ....it may grow on me ?
Your not ment to paint them Whistle
Posted 6th Apr 2016 at 13:42
Post #317
Needed a new radiator cap as my Rubber inside lid has had it Thumbs down
Trying one of these Stants
Posted 6th Apr 2016 at 13:47
Post #318
Tried & fits spot on ....Teflon left/right hand -thread ....rose joints = centre to centre overall 110mm For 40amp Alternator
Posted 6th Apr 2016 at 19:45
Post #319
Trial fitted ...saves weight & saves loads of space Thumbs up
Posted 6th Apr 2016 at 19:56
IvayloPavlov
Post #320
Is this direct replacement for GTI6 alternator?
Posted 6th Apr 2016 at 22:07
Post #321
No work has to be done ...sadly ...it will fit ...Rally Ash has one fitted ...I use the standard 6v belt & auto ajuster also Thumbs up
Posted 6th Apr 2016 at 22:49
Puggitt
Post #322
Just wondering, why'd you get an adjustable link if you're using the standard tensioner? Wouldn't a simple solid link have been simpler and 'cost efficient'?
Posted 7th Apr 2016 at 04:59
Puggitt
Post #323
Post #324
£13 all in from McGill motorsport & I can now use several Assorted length belts I have with the auto ajuster ....you need it with a slightly different size belt -bigger or smaller because you don't have much to work with distant wise from the Altenator pulley to the auto tensioner pulley they can touch & rub ..this allows me to adjust that distance now with my Assorted belts I've aquired over 3years...trying to plan ahead Whistle
Posted 7th Apr 2016 at 06:44
Post #325
you still have the spring thing?
Posted 7th Apr 2016 at 07:36
