Post #468
Its not a fitting like a 306 uses, just the type where you push the hose over and use a jubilee clip. The bottom mounting is pretty much the ideal location for how the normal bottom hose is routed, you could potentially get away with chopping the push fit fitting off a normal hose then shoving the rubber over, thats what i did for mine, you may need to fettle the front leg holes a little though to ensure the hose can't rub where it goes through.
The top hose comes off on an angled ally tube which aims towards downwards towards the bottom hose ends mounting, which would need chopping off and a fresh bit of tube welding on to aim it towards the thermostat housing. I kept mine with the angled bit as i just ran that into the laminova which sits along the top edge of the radiator, and knocked up a fresh run of coolant hose from the laminova to the thermostat housing area. For mine i sourced an ally hose adapter which mounts to the thermostat housing and gets rid of the normal plastic push fitting thing.
There may be a few pics somewhere in my project thread on how i did it, as im sure i'm describing it pretty badly
Yeah you'd need to change from a standard fan, or make some sort of mounting for one to be used. I can't remember if my pair of slimlines are 10" or 12" off hand, but they fit perfectly. Mine are just cheap ones which carbuildersolutions sell, they're plenty good enough to bring the coolant temps right down when they kick in if im stuck in traffic. Now i have shrouding around the radiator it's plenty good enough to keep the coolant to 90c or less when giving the car abuse on track. As for their reliability, mine have been on 3-4 years and are still going strong.
If you head to a car show where CBS are attending, you may get a better deal on price than online. They'll be at the Stoneleigh kit car show next weekend, really nice and helpful guys whenever i've had dealings with them.
