displaying posts 476 to 500 of 3424
Pages (137): first .. 19 [20] 21 .. last
Post #476
i remember getting those rads from gsf for £40!
Posted 25th Apr 2016 at 13:45
Post #477
looking good mate! Thumbs up
Posted 25th Apr 2016 at 14:38
Post #478
you could use a 205 tank, quite easy to plumb it into a 306.
dont cut into the top hose, ill get you a diagram later, standard 406 top hose.
Brilliant Mei ...I've got a 205 expansion tank but it's old & doesn't look great PIC BELOW Thumbs up
How the hell am I going to fill the radiator & bleed it also ?.....I'm all ears Thumbs up
Posted 25th Apr 2016 at 20:11
Post #479
Got some bits I was going to use or take back ?
Posted 25th Apr 2016 at 20:47
Post #480
Got this expansion tank & it has everything I need & it fits perfect as in picture ...plus it's well above the hose / radiator level
Posted 25th Apr 2016 at 20:48
Post #481
Used some alloy 6mm plate & drilled & fitted the rubber bungs in the right position for the 205 radiator .....
Used the Aircon rubbers as they are smaller & same internal size ....
Posted 26th Apr 2016 at 15:16
Post #482
Going to fix alloy plates to cross member ...the reason I used 6mm is it lifts the rubbers enough to miss the oil cooler brackets
Posted 25th Apr 2016 at 20:53
Post #483
Fits a treat
Post #484
Plenty of space
Posted 25th Apr 2016 at 20:54
Post #485
Getting some alloy angle welded onto the top of the radiator each side & then these two rubber Robbins will bolt through the slam panel ...hopefully nice & simple fitment Thumbs up
Posted 25th Apr 2016 at 21:01
Post #486
Nice update. Definitely consider making a shroud for the radiator, it's made the world of difference to mine! Thumbs up
Post #487
Nice & softish rubber bobbins
Posted 25th Apr 2016 at 21:02
Post #488
Don't forget Steve I've got no intercooler or pipework infront of my radiator m8 ...
Defo do it if I get any issues ...ill see how the temps are first Thumbs up
My 10inch single fan is a Tripac USA made one so say good quality but not SPAL prices ...one fan kept it cool before & it's easy to add another if needed
Posted 25th Apr 2016 at 21:20
demondriverdan
Post #489
Will the expansion tank have any issues with heat from the exhaust?
Rallye Race Car
Posted 25th Apr 2016 at 22:42
Post #490
I'm hoping not Dan ?.....many cars have ran them there m8 ....I can Put some Zirotec underneath if it becomes a issue m8 Thumbs up
Posted 26th Apr 2016 at 01:17
Post #491
you need an xu/xud tank not a tu one.
Posted 26th Apr 2016 at 07:30
Post #492
What's the difference Mei ?
Would the one I bought in the picture be no good ?
Where's the best place to connect the header tank bottom hose ?
I can fit it with the piece in the bottom hose or top hose ?....I didn't think the top hose would work because the thermostat may be closed ?....or am I wrong ?....fitting the large bottom tank filler Hose into the top hose would make things so easier Whistle
I can see the small top expansion radiator tube goes to the top of my expansion alloy tank ...
Posted 26th Apr 2016 at 08:35
Post #493
Trying to find one of these off 205 GTI 1.6/1.9 to fit my Baker BM thermostat adaptor .....get rid of that Bacolight 306 thing & wont need a reducer to 205 rad then ?
Anyone have a spare to sell ?
Posted 26th Apr 2016 at 08:27
Post #494
Got one good condition £15 delivered .....from address below only deals with 205s good bloke has 32 cars instock
Posted 26th Apr 2016 at 13:10
demondriverdan
Post #495
I doubt it'll be a problem, just wasn't sure!
Rallye Race Car
Posted 26th Apr 2016 at 11:27
Post #496
Got one from 205gti spares £15 delivered ....
Also I'm connecting into my rear lower Old not used heater matrix pipe & blanking top Thumbs up
Post #497
Made some T pieces up out of alloy angle & seam welded them & then tigged them onto the top of the Radiator ....
Will drill x2 holes in each later for rubber bobbins to fix too ...
Posted 26th Apr 2016 at 13:17
Post #498
Had to go dam careful & not let it get too hot Thumbs down
Posted 26th Apr 2016 at 13:18
Post #499
Got my clips for the 205 new hoses .....so far so good
And got some thin 1.5mm alloy sheet bent to make radiator Cold Air director like Prismguy/ Stephens done Thumbs up
Posted 26th Apr 2016 at 14:14
Post #500
yeah with the square 205 tank tee off the upper heater hose to the bottom of the tank, fitting it to the top hose wont fill up properly.
the small takeoff goes to the rad and with a 6 engine blank the larger top takeoff with a factory bung, from a 405 airbox iirc, or an XUD rear water takeoff.
drill two 3mm holes in the thermostat either side, to allow any air to bleed out, its a peugeot/citroen sport mod that Ive done to all cars I've worked on.
go easy with those mikalor type clamps, too easy to over tighten those.
I might have a spare alloy takeoff, much prefer the standard plastic takeoff though, so much easier to fit, use a 406 top hose MIles has said.
Posted 26th Apr 2016 at 15:19
