displaying posts 501 to 525 of 3424
Pages (137): first .. 20 [21] 22 .. last
Post #501
Brilliant Mei Thumbs up
Double checking Mei ...I thought you had to come off the lower Engine Old Matrix tube not the upper that goes to thermostat housing type area ?
It's definitely the upper old matrix thermostat housing area your saying you come off of & blank the lower ?
I thought you told me before to blank the top & use the lower one that goes down the back of the Engine to the bottom hose & the fills from the bottom ?????
Posted 26th Apr 2016 at 16:16
cully
Post #502
drill two 3mm holes in the thermostat either side, to allow any air to bleed out, its a peugeot/citroen sport mod that Ive done to all cars I've worked on.
This Thumbs up makes the engine so much easier to bleed even the std set-up Smile
Posted 26th Apr 2016 at 17:10
Post #503
no, blank the top of the expansion tank as its unused and tee into the heater hose
the bbm 205 kit has a special hose for the gti6 installation
http://www.bakerbm.com/205.php?data=schkitgti6205
Posted 26th Apr 2016 at 18:03
Post #504
Mei my not using a 205 expansion tank ?
I'm using the one in the pic below Thumbs up
I've only got the (u) shaped short matrix bypass pipe from spoox ...as I've no matrix ....why do you T into that ?....it's just outlets if you have a matrix ?
I've been told by you & others to use the bottom old matrix pipe that goes behind the engine & blank off the top old Matrix pipe that goes in behind before the thermostat ...?
Posted 26th Apr 2016 at 18:19
Post #505
i told you to not be so daft and keep the heater LOL
Posted 26th Apr 2016 at 18:36
Post #506
I don't need it & don't use it GONE Razz
Just like the Ex LOL
Posted 26th Apr 2016 at 19:10
Post #507
You're in the northern hemisphere...
Posted 26th Apr 2016 at 19:12
demondriverdan
Post #508
Just vent the exhaust through the car, that'll keep you warm! Wink
EDIT: Can't spell
Rallye Race Car
Posted 26th Apr 2016 at 19:56
Post #509
Mei you got to laugh ...I've just had someone everybody knows who makes Asst items telling me A top hose on a 306gti6 is 100% 32mm ...I told him look I'm here looking at a Nissens leaking 6 rad & im looking at a Nissens 205gti rad & the 6 ones 40mm & the 205 ones 32mm....I need a 32mm to 32mm 205 top hose m8 for my 205 rad to 205 thermostat outlet pipe & I can lengthen it if need be LOL ..
He still said he makes them & im wrong Doh
Posted 26th Apr 2016 at 19:18
Post #510
Mei you forget it's always sunny where I live & the Car never goes further than Combe LOL
Posted 26th Apr 2016 at 19:19
Post #511
demondriverdan wrote:
Just vent the exhaust threw the car, that'll keep you warm! Wink
Dam good idea Dan LOL
All joking apart the 4x4 boys run a flexible pipe over the exhaust & direct the heat behind the dash ....don't fancy the smell much Crazy
Posted 26th Apr 2016 at 19:22
RetroPug
Post #512
You can buy 12V hairdryers... Laugh my ass off
Posted 26th Apr 2016 at 19:29
Post #513
I can run two one on each side ....bit of gel & kill two birds with one stone Laugh my ass off
Posted 26th Apr 2016 at 19:32
Post #514
Big thank you to Ryan / Pug_306 for sending me his final revised Heatshield plate amazing quality & stainless steel ....I'm going to be covering it with self adhesive Zircotec to keep heat away from my bulkhead as much as possible ...
PS film left on until just before I'm fitting it LOL
Posted 27th Apr 2016 at 16:50
Post #515
The 205 /32mm..Thermostat elbow for my 306 to 205 Baker/ BM conversion housing arrived ...Ill give it to my Glass bead blasting / Nickle plater man it looks OLD at mo but should come up like new Whistle
Posted 27th Apr 2016 at 16:54
Post #516
Big thank you to Areo Catch UK for supplying yet again some FOC Extreme steel pins for my tailgate ....I'm not a big fan of the red alloy ones as they can't take a knock I've personally found out the hard way ...others swear by them Thumbs up
Posted 27th Apr 2016 at 16:57
demondriverdan
Post #517
Interested to see how you mount the tailgate. I've got a fibreglass one sat around waiting to be fitted but no point at the moment as it would make the car too light for my class.
Rallye Race Car
Posted 27th Apr 2016 at 17:38
Post #518
It's twin skin as original & Fits on standard hinges & struts Dan & I'll use Aero Catches same way Stephen/ prism7guys done his to lock it shut Thumbs up
Posted 27th Apr 2016 at 20:27
Post #519
I'm going to have to get some steel pins for my bonnet, it's only a matter of time before the alloy ones give up, you should have seen how much my bonnet was flapping about at 120 the other day Doh Laugh
I also need to decide on the best way to fix my single skin fibreglass boot to the car at the top, i want to try and keep it hinged if possible as it makes it so much more convenient when doing trackdays etc just putting the wheels and spares in the boot area, don't fancy having it similar to my bonnet where i need to remove it then try and find somewhere safe to leave it whilst i load/empty the car. Hmm
Posted 27th Apr 2016 at 19:23
demondriverdan
Post #520
Mine's single skin as well. I was thinking about bonding on some hinges then just having it clip down at the bottom
Rallye Race Car
Posted 27th Apr 2016 at 20:39
Post #521
Blimey guys I couldn't have a bonnet flapping to much in front of me ...it's obvious the twin skin ones twice as heavy as a single skin one but the twin skin one weighs nothing Crazy ...
The tail gates are surprisingly sturdy ...with the 5mm rear window instead of 4mm hard shell grey polycarbonate bonded in it should be solid Thumbs up
Posted 27th Apr 2016 at 22:35
Post #522
There is a point where weight saving just becomes dangerous. Flappy bonnets and high speed do not mix well.
Posted 27th Apr 2016 at 22:33
Post #523
I agree myself but everyone to there own LOL
This should be here tomorrow to fit the 205 hose elbow to
Posted 28th Apr 2016 at 00:40
Post #524
Also got one of these coming as it's the only bush not changed
Posted 28th Apr 2016 at 00:42
demondriverdan
Post #525
I got the single skin as it came up for about £70 brand new, hard to turn that down really. Like you say, when it's bonded in with the rear screen it should be ok. My bonnet is only single skin and that doesn't flap much at all with the little support bar I put in the front through the bonnet badge
Rallye Race Car
Posted 28th Apr 2016 at 09:01
