displaying posts 1451 to 1475 of 3424
Pages (137): first .. 58 [59] 60 .. last
Post #1451
quote:
[quote="welshpug!"]yep, those came about because he kept breaking be boxes and cv's
I've spoken to Tony they sound also look amazing ...he's testing one to Thumbs up
Posted 21st Sep 2017 at 12:48
Post #1452
quote:
[quote="RallyeRed"]Damien, going back to the ARB stuff, what front spring rates are you running?
Iain
Eibach ERS ... main red spring with Green Progressive spring below ...you need a very long threaded Damper body to fit them ...which Black Art Design made
Posted 20th Sep 2017 at 23:48
Post #1453
These
Post #1454
quote:
[quote="Day666"]Sunday update ...LOL
Both sides of the angled alloy to aid Airflow have been finished ....they float & allow the radiator to move freely ...a couple of dabs of clear silicon will stop vibration ....it fits tight with a 15mm gap all round inside of bumper Thumbs up
Bumpers gone on now .....nothing to exciting seeing a picture of a bumper ...
On my project page 23-26 you will see my old 205 rad set up with standard inlet /modified by Satchell to 8 injectors Thumbs up
Posted 25th Sep 2017 at 14:29
Post #1455
Well it’s been 4years since (Andy/ Jord294) .....fully refurbished my rear beam ....it’s had some abuse ... 27 hard Trackdays...3 Prescotts hill climbs plus 2 years of everyday road use ...
I took my first 306 beam apart yesterday using Mei / Welshpugs FAQ plus speaking to Lee/ Jeffers both on here ....sadly money plus time to get my car driving again is against me ...so I couldn’t make it to Andy / Jord294s place ..the garage we keep our cars in / share is up for sale ....
Pictures below are of the Arms before removing plus after taking them out Thumbs up
I’ve removed / changed the ARB to a 30mm Torsion Performance one 12months Ago but I’ve got to remove both Arms to fit 25mm torsion Bars I got from Ross/ Supercharger As 25mm won’t slide through the trailing arms like my current 21mm ones .
I’ve been told it’s going to be fun fitting 25mm TBs ....
PS the dummy shock told me my current 21mm TB setup is set to 313mm give or take a mm each way ....ANY BODY know or GUESS what 25mm TBs would need to be set at to get similar ride height to my 21mmTB setup now ?
Posted 27th Sep 2017 at 08:49
Post #1456
More before stripping shots LOL
Posted 27th Sep 2017 at 06:42
Post #1457
All I can say is WOW !!!...it looks like NEW .....no i have not greased it or cleaned it up for the picture....really says everything about Andy/ Jord294s quality of work ...with him using Gen parts
Posted 27th Sep 2017 at 06:46
Post #1458
Just can’t believe how easy the whole beam came apart .....Some more Beam Porn LOL
PS ...remember this is how it came out after 4years of abuse Thumbs up
Andy/ jord294 take a bow my friend,...Thumbs up
Posted 27th Sep 2017 at 06:50
Post #1459
PS ..anybody know or Guess better than me what 25mmTBs will need my dummy shock set to get similar ride height to my current 21mm TBs which came in at 313mm give or take 1mm per side ?
That measurement is centre to centre ..I take it 30mm approx drop from standard ride height ?
Posted 27th Sep 2017 at 06:56
jord294
Post #1460
I set jorgs a few years ago at 308mm with 23mm bars, so I reckon somewhere around that
Posted 27th Sep 2017 at 07:33
Post #1461
quote:
[quote="jord294"]I set jorgs a few years ago at 308mm with 23mm bars, so I reckon somewhere around that
Brilliant Andy ...I’ll start at that m8....thank you again for quality of work Thumbs up
Posted 27th Sep 2017 at 08:47
Post #1462
would imagine youll need to go a bit lower given how much stiffer 25mm will be over 23.
Posted 27th Sep 2017 at 12:40
superchargedblack1997gti6
Post #1463
Mines set at 273 mm mate
Posted 27th Sep 2017 at 12:43
Post #1464
quick guesstimate - 23mm 210lb/in wheel rate. 25.4mm 411 lb/in.
hope your dampers have enough adjustment!
Posted 27th Sep 2017 at 12:46
Post #1465
quote:
[quote="welshpug!"]quick guesstimate - 23mm 210lb/in wheel rate. 25.4mm 411 lb/in.
Brilliant Mei ....What would you say the ride height roughly would be for 30mm drop then Mei ?
PS I’ve got 3way Black Art Design rears with 40mm tubes not 38mm as used in Group A Bilstein...he was told what I’m using plus the F2000 spoiler extra downforce / John said these will control 25.4 TBs no problems ....
I can’t even push the dam things down like I could with my Group A Bisteins
Posted 27th Sep 2017 at 13:47
Post #1466
no idea sorry, never tried anything bigger than 23mm, I can't push in my 306 group A tar dampers, damping rate on those is 600/300 and were made for 23mm bars.
Posted 27th Sep 2017 at 14:30
Post #1467
quote:
[quote="welshpug!"]no idea sorry, never tried anything bigger than 23mm, I can't push in my 306 group A tar dampers, damping rate on those is 600/300 and were made for 23mm bars.
My Bilstein Group A ones were 205 valved ones from Kam Racing / not as well Valved as 306 ones that no one sells now ...but Bilstein said they would revalve mine to 306 Group A spec for £60 the pair ....
Posted 27th Sep 2017 at 14:47
Post #1468
quote:
[quote="superchargedblack1997gti6"]Mines set at 273 mm mate
But didn’t you say that’s 45mm drop as you have a straight through exhaust plus Dimma type arches on the rear ?
Posted 27th Sep 2017 at 14:50
Post #1469
Yep I’d be looking at setting yourself at 295ish mate
Posted 27th Sep 2017 at 18:23
Post #1470
Nothing Exciting really ....small update ....
Used two new beam seals plus two new arm shaft cups in the picture below ..the others were 100% good but while apart you may as well for the cost Razz
Fitted both 25mm torsion Bars using the Dummy damper / god knows how I would of fitted them without it ?
Because the TBs won’t push through the Arms like 21s I had to semi pull out the Arms plus turn the 25s time plus time again until both splines line up on both sides of the beam tube ....was Fun NOT !!!
I’ve Set both sides to 295mm centre to centre / should be able to finish it off Sat morning as just new SKF hubs / plus discs plus fit rear Disc / Calipers plus loctite wheel studs / fit New 3ways that are 300mm centre to centre fully open / spot on
I’ve dummy tried the 3ways today ....they fit nice / snug .Thumbs up
Posted 28th Sep 2017 at 20:37
Post #1471
New beam seals in picture plus Redline super super Grease used ...cleaned out as much old grease as I could plus repacked into beam using old end of a broom to get to inner bearings ...PS made sure this grease is 100% compatable with left over of older Grease ..
This is it ...been told it’s the business or they may of just seen me coming LOL
https://www.redlineoil.com/product.aspx?pid=82
PS ...Red Grease in the picture was smoothed out plus push into inner bearings
Posted 28th Sep 2017 at 20:44
Post #1472
Any decent calcium-complex grease will do there, I like K323 for stuff like that where you want long life/low washout, it's only about £8 a cartridge.
Posted 29th Sep 2017 at 00:06
Post #1473
quote:
[quote="phillipm"]Any decent calcium-complex grease will do there, I like K323 for stuff like that where you want long life/low washout, it's only about £8 a cartridge.
Sadly Phil ... I’m ashamed to say I’m stupid enough to fall for all the Bull PR Whistle
Posted 29th Sep 2017 at 13:39
Post #1474
CV2 is great....but it where it shines is high temperature abuse, I don't think you'll be running the beam bearings at 150*c Big grin
Posted 29th Sep 2017 at 14:33
Post #1475
quote:
[quote="phillipm"]CV2 is great....but it where it shines is high temperature abuse, I don't think you'll be running the beam bearings at 150*c Big grin
This ones for you Phil Thumbs up
Posted 29th Sep 2017 at 18:18
