Arches being cut away tomorrow plus trial fitting 205 arches
Forgot to say NO ARB or Dampers fitted in this pic
| Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Post #1476
Well this is the rear drivers side looking from the back of the car with NO wheel spacers ...295mm drop on 25mm TBs Arches being cut away tomorrow plus trial fitting 205 arches Forgot to say NO ARB or Dampers fitted in this pic Day666 has attached the following image: |
superchargedblack1997gti6
Post #1477
Looks awesome 😎 ________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
Post #1478
quote: [quote="superchargedblack1997gti6"]Looks awesome 😎 Big thank you Ross |
Post #1479
Been Busy all day today rear arches Day666 has attached the following image: |
Post #1480
Jigsaw time Day666 has attached the following image: |
Post #1481
Rear arches ...Remember I’m running 25mm TBs with 30mm ARB / Black Art Design 3way Dampers 300mm long open plus TBs set at 295mm ride height..Day666 has attached the following image: |
Post #1482
Carbon outside / Kevlar inner skin Day666 has attached the following image: |
Post #1483
Fits a treat Just need to file around wheel arch to Miss bumper a little Day666 has attached the following image: |
Post #1484
Got to laugh 65mm Carbon / Kevlar 205 (Front) arches used on the back Day666 has attached the following image: |
Post #1485
Carbon outside Day666 has attached the following image: |
Post #1486
Kevlar inside skin Day666 has attached the following image: |
Post #1487
Even fits under my side skirts Day666 has attached the following image: |
Post #1488
Wasent a Big deal ....someone forgot to use a Subframe (with) a post ?...maybe a Automatic gearbox one ? ...so I had to cut the old one off my Subframe ...weld it onto the Satchel subframe for a Satchel shift support point Day666 has attached the following image: |
Post #1489
So a good days work today ...arches sorted plus primed edges of cut Bodywork / underseal done .....Satchel subframe plus rack plus top adjustable mounts modified / fitted rear 3ways with adjustable canisters fitted Finish off / Tidy up front subframe plus measure for driveshafts for Satchel to make .... Try Brake calipers / make adaptor (template) for 406hubs offset .... Fixed on rear Arches temp Plenty to do tomorrow |
pug_306
Seasoned Pro Location: Great Hockham Registered: 28 May 2013 Posts: 1,597 Status: Offline |
Post #1490
Looking forward to seeing this finished :-) ________________________________________ 1998 Supercharged White Rallye1992 205 GTi6 205 Turbo 340bhp |
Post #1491
quote: [quote="pug_306"]Looking forward to seeing this finished :-) Big Thank you Ryan Finished off Fitting 406 hubs plus the Satchel subframe / front complete arms etc ...Red tape to remind me which bolts plus areas need tightening plus looking at / maybe changeing Day666 has attached the following image: |
Post #1492
Cars sitting really nice now / bumpstops Amazing ...just need to adjust front coil overs plus get steering arm made longer / / plus Drive shafts measured made ...The threaded adjusters are only temporary in the picture to adjust then Satchel will make correct length Day666 has attached the following image: |
Post #1493
Really happy but still lots of money plus things to sort but getting closer Day666 has attached the following image: |
RallyeRed
Regular Location: Northwich Registered: 03 May 2016 Posts: 353 Status: Offline |
Post #1494
Good to see it coming along Damo.Interesting that your TRE's go above the upright, rather than below like the 306. I don't know if it's perspective but you seem to have lots of different angles going on between wishbones and TR arms. Unless you're aiming to go rose jointed in future? Cheers Iain |
Post #1495
quote: [quote="RallyeRed"]Good to see it coming along Damo. Interesting that your TRE's go above the upright, rather than below like the 306. I don't know if it's perspective but you seem to have lots of different angles going on between wishbones and TR arms. Unless you're aiming to go rose jointed in future? Cheers Iain Hi Ian .. so am I m8 ..lots of stuff is missing including all the complete rose jointed steering rack components ends plus shafts .....I’ve put red tape to remind me as I won’t be going back for 2-3 days ....which you can probably see lots of Red tape in the picture warning me ...it was all quickly assembled ....to try the Camber only ...see if I’m in the place I should be ?PS ...All the Rose joints extended in all the pictures are temporary as he’s never made a plus 50mm kit only plus 75mm / standard so I need to fully extend everything plus trial fit it all ...then give Colin the size / length I need on the Arms / steering rack....Hope that makes sense ? |
Post #1496
track rods are upside down indeed ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #1497
quote: [quote="welshpug!"]track rods are upside down indeed ![]() God knows what bells I’m going to need ?....I’m sure Colin will Know ...my Bells / rotors currently from my old setup 330mm from Ash / hit the bottom bump steer ...I spaced it out washer by washer on all 4 wheel studs ...just to see /10mm thick of washers on each stud to just miss the bottom arm .... if I space it out ...the Bells look like they may end up being 5mm offset not far off flat ...they are 20mm off set now |
Post #1498
sounds about right yeah, 406 used pretty much zero offset discs on most calipers, 305mm disc was 28mm thick and 28mm tall.this may introduce radial clearance issues with the wheels if you're running big discs., they'll get pretty close laterally to the spokes too. you will need a different bracket for the caliper anyway, as the radius of the lugs is different to the 306 by about 8mm or so, looking at it I noticed its a 406 caliper so you wont have room for a bracket! but you could bolt them straight on with a standard 305mm 406 v6 disc. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #1499
Your a dam Star Mei I really wanted 330mm bells / Rotors .....Ben from Godspeed said Disc size is key ? If I’ve got to change my calipers then I will / or everything else inc wheels ...mad I know but I’ve gone this far if you know what I mean ... I’m sure 300mm discs would be more than fine ...but got to go Bells / Rotors Mei ... |
