displaying posts 501 to 525 of 608
Pages (25): first .. 20 [21] 22 .. last
Author Subject: Project Rallye!
atterz
Post #501
Parts for sale?
owain wrote:
Posted 21st Nov 2011 at 23:39
Post #502
sticking with the 306 rack or using a nice xsara quickrack?
Posted 21st Nov 2011 at 23:49
Carl Chambers
Post #503
you got a Xsara one going cheap?
if not I will stay with the 306 one Smile
atterz wrote:
Parts for sale?
yeah lots of parts for sale, what you after?
Carl Chambers
email; pugnacious.peugeot@yahoo.co.uk
C.M.CHAMBERS CARS
Peugeot Specialist
Tel; 01379 586101 after 6.30 or 07889 082466 anytime.
pugsport-racing.co.uk
Posted 22nd Nov 2011 at 21:03
Carl Chambers
Post #504
Been making the o/f engine mount this week and the rose joint bottom arms
first the mount, start off with some 4mm plate and a 40mm square box section;
as I had some spare un-used 205 rear beam mount I cut the top bush mounts off a scrap 205 rear beam and turned the down to make them look nice.
after a lot of cutting and welding you end up with this and you can see its a lot lighter than the original mount;
cut the bottom alternator mounts off the old engine mount;
and fit the new mount complete with new alternator adjuster;
Then the front suspension, as I using the Gaz coilover from my 205 I need to make some rose joint antiroll bar links cause the standard 205 ones dont fit;
I then started to copy the BTCC car rose joint bottom arms, the wishbones ball joint holes were made bigger as per the BTCC ones;
you can see the special rose joint in the picture that came off the BTCC car so I cut up some old bottom ball joints in order to make my own.
these will be welded and fitted over the weekend hopefully, and then I can put the engine in and finish the mounts off.
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 2nd Dec 2011 at 20:34
steve954
Post #505
carl if you want any small bits shot blasted and powder coated let me know.
stevie
09 308 gt140 cc
03 octavia vrs
IF IT AIN'T BROKE, IT AIN'T A GTI6
Posted 4th Dec 2011 at 14:50
Carl Chambers
Post #506
Engine mounts all done;
just got to re-paint everything now.
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 8th Dec 2011 at 21:05
steve954
Post #507
oooh can i have a look sat
stevie
09 308 gt140 cc
03 octavia vrs
Posted 8th Dec 2011 at 21:11
Carl Chambers
Post #508
yeah no problemThumbs up
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 8th Dec 2011 at 21:15
Post #509
hmmmmmmm INNNNNTERESSSSSTINGThumbs up
Posted 8th Dec 2011 at 21:29
Post #510
Why not just use some mounts like I had made which would utilise standard mount points? They are just as light. I do think I have a contact who has 306 btcc bits in a barn or something as he was offering me carbon stuff from them and a radiator or something not long ago (although I am sure with your other btcc car you've accumulated contacts)
Posted 8th Dec 2011 at 22:25
Carl Chambers
Post #511
Yeah could have done but just did it this way as thats how it is on the BTCC car?!
Any info on the BTCC stuff would be good, I have a few contacts but very few spares. Carbon bits for this car would be good, pm me detail if you want?
cheersThumbs up
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 8th Dec 2011 at 22:28
steve954
Post #512
i think carl is just copying bits from his touring car! plus he has a engineer in the unit next door so i guess things are being done cheapLOL
edit to slow Doh
stevie
09 308 gt140 cc
03 octavia vrs
Posted 8th Dec 2011 at 22:31
roberts_306
Post #513
Would not mind some BTCC bits myself
www.pugsport-racing.co.uk
Posted 8th Dec 2011 at 22:38
Carl Chambers
Post #514
edit to slow Doh
yeah having a bloke next door whos a bloody good welder and likes making stuff is very handySmile
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 8th Dec 2011 at 22:39
Carl Chambers
Post #515
Engine mounts painted;
rose joint bottom arms done, as are the rose joint anti roll bar links
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 16th Dec 2011 at 20:58
Carl Chambers
Post #516
Got my MSA go racing pack for Christmas so got so light reading to do before my ARDS test!
Samco induction hoses and carbon air box fitted low down this time;
oil breather catch tank fitted and engine harness re-routed through the bulk head
cooling fans completely removed and oil cooler mounted, plus from MSA tow strap fitted
rear tow strap fitted;
and cover trimmed so it pokes through
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 28th Dec 2011 at 20:37
atterz
Post #517
Everything you do is to a high standard, ive loved reading through this project! Will be good to see it race!
Posted 28th Dec 2011 at 21:38
bellcp306td
Post #518
Yes a very high standard of work
WOW is all i have to say.
Where did the road go!
Posted 30th Dec 2011 at 10:55
Carl Chambers
Post #519
thanks for the positive commentsSmile
Between Christmas and new year I have took the time to get a great deal done with the car, mainly the wiring!
out has gone all the car original wiring and fuse boxes etc!
here the big heap which does wiegh a few kgs!
so now the car has totally been re-wired from scratch front to rear, with only the standard engine harness staying, though that was trimmed down as much as possible! Its was no way an easy task but glad its been done! Now only the very basics that are needed are left in the car.
A dash from a kit car mag has been used with has rev counter, oil temp, water temp, 3 shift lights, speedo, fuel gauge and high temp warnings, as well as lap timers, yet was very cheap and no where near the cost of a stack dash!
switches that remain are,
headlights, indicators, rear fog/high vis light and wipers around the dash
ignition, fuel pump and starter in the centre dash. the brake bias valve and electric kill switch are also in the centre dash.
As you can see I have used standard 306 switches as I have loads of these and they power up through relays in where the upper glove box once was. plenty of carbon fibre was used to mount everything and blank holes off!
car is all fully re-wired and does now run again!
electric cut off mounted in the wiper trim, the second hole is for the fire extingisher which I will be buying very soon.
then some minor jobs where to drill the bonnet pins and the tailgate these were a pain as to where they has to go and the angle they were at! but it all worked in the end.
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 2nd Jan 2012 at 20:46
steve954
Post #520
very nice carl, i will have another peak sat if i may? i bet you use this more than the touring car in the race seriesThumbs up
stevie
09 308 gt140 cc
03 octavia vrs
Posted 2nd Jan 2012 at 21:05
mike rallye
Post #521
very nicely done. looking spot on Thumbs up
Posted 2nd Jan 2012 at 21:10
roberts_306
Post #522
Looks like I will invest in one of those digital instruments Smile
Posted 2nd Jan 2012 at 21:22
Post #523
would be interesting to see how much it weighs when you've finished Smile
Any plans to use lighter brakes as well?
Posted 2nd Jan 2012 at 21:36
roberts_306
Post #524
Lighter brakes would be a benefit but at what cost, if cash was spare then I know Carl would put them on and same goes for me. Wish Id kept the 6 pot Tarox I had now
Posted 4th Jan 2012 at 22:44
fatlapit
Post #525
k sport any good??
Posted 5th Jan 2012 at 17:50
